jeffer949
    9
Everything posted by jeffer949
  1. Lol thats all i have to say about that. Have fun trying to jimmy rig it together. Oh btw an EXPERT as you put it would tell you to do it correctly with an aftermarket ECU.
  2. Wait............................................... Let me get this straight. Your running a t3/t4 turbo on the stock electronics?? And then you just expected to tweak the afm a little bit to get it to run correctly?? (goes into corner and beats head on the wall for a minute) K Im back now. Of course your gonna run lean. Your new turbo is flowing more air than your ecu can support. How do you suspect it to get enough fuel. You made no changes to the fuel system. If you up the air going in you HAVE to up the fuel going in also. You cant just bolt on a big turbo and expect it to run correctly.
  3. 1100kpa is 16psi? dang i must need to go back to school. lol thats something around 145lbs of boost!!!! That must be a hell of a motor you have!!!!! and one BIG turbo!!!
  4. Im willing to help you out but you do need to do your homework also. Its all on this site. spend some time searching the turbo forum. You will find all you need
  5. I read the original thread and it looks like we might get some pics. The cage builder(the guy that build the guys cage) is going to get in contact with him.
  6. Rebuilding the stock t3 is easy. The rotating assembly is balanced independently of the other piece. That means that the compressor wheel is balance by its self, and then the turbine wheel is balanced by itself. Then they are just bolted together. It is a good idea when taking them apart to just take a sharpie and mark them so there is no question.
  7. John i would just like to thank you for your past couple threads regarding roll cage construction, and the wrecks that have brought alot of attention lately. I am no where near needing a full cage but these past few threads have opened my eyes to how crucial they are when you actually start racing. i raced motocross for 13years and did a bunch of track days on sport bikes and have even gone down at 120mph on an R6. So I always kind of thought of a steel box around me as good enough. Honestly I always thought of Roll cages as a little over kill but I dont any more. Its amazing how much more damage is created with the additon of the mass of a vehicle. On a side note i think its kinda childish that he doesnt want pictures of his car posted. Let people learn from how his cage was constructed so every one can be safer
  8. The more i look at this swap I think I might do it when I get tired of the L6 or it blows up. Its between the 2jz-gte and this. I only want around 600hp and from some of the research that sounds very doable on this motor. Well time will tell
  9. copy of what? wangan midnight? if so just dl them. they are on torrents.
  10. I couldnt count either. And currently my car is running like crap but hopefully some magnecor plug wires that are on order will fix the problem. But for a good while before i wrecked my car it was running great. And i mean great. It was so much fun. completely dominated my friends modified twin turbo S4 that he has like 25k into. When i get down int he dumps this may be sad but i throw in wangan midnight. lol Gets my heart pumping, and gives me the drive to do some more work on the zed.
  11. Id leave it for now but once its up and running with it cold take a pair of hemostats and pinch off the hose and see how long it takes to warm up. Then do the same for it open. I would imagine it has something to do with putting a bypass on the system so that it doesnt put a huge load on the water pump from it trying to push water where it cant go with the thermostat closed.
  12. Hey your in my neighborhood. I just moved here but If you need help with the zeds let me know. Honestly if you want 200hp the cheapest way is probably going to be a turbo swap. And as for reliability, it doesnt get much more reliable than the L6 engine. Yes you can get 200hp N/A but it will take some head work and your going to need a flat top piston motor to start with. Write me a pm and we can talk maybe even get together sometime
  13. Could just be so it warms up the engine quicker.
  14. Im running a surge tank with the stock unbaffled tank
  15. Hrrm didnt know this. Wonder how much it will help in the 1/4
  16. why do you need the trigger wheel? why not just use the distributor?
  17. Most spacers have one side that is taller to cover that.
  18. I would make it as wide as the exit hole and have it follow a nice gradual and maybe even flow it into the vents you have there already.
  19. well just do the math 60% of 205mm and 60% of 195mm. I think you will have to have some sidewall. I would be more worried about getting the size that will look correct and then focus more on buying a quality performance 14" tire. Oh btw 10mm in tire size looks bigger than you think
  20. Hey challenger a few weeks ago i was at a meet and a guy had 14" rims with 195x60x14's and honestly the tires looked way to small. didnt fill up the wheel well at all.
  21. Start with the body and get it to where you want. Everything else bolts to the body. So get it looking and modified the way you want and then start with the parts that bolt on. Engine should be last in my book. (not saying I followed my book) but if i had to put it on paper which way to do it i would do body/paint suspension/brakes interior engine
  22. cool stuff but can i suggest you change the font or the color of the font on your web page. Its really really hard to read. But I did like reading what i was able to read. Seems this is going to be one of the wildest s30's ive ever seen or even heard about
  23. Here is a picture of my set-up. The "ideal" place is as close to the TB as possible as you want to keep as little air as possible moving the wrong way. The air bounces off the TB plate when you close it. You want to give it a place to go out as soon as possible so you dont put any back pressure on your system. That being said there are some circumstances where you do need to put it farther away. For instance turboing late model mustangs requires you to mount BOV before the MAF but you cant have it right next to the MAF as it will cause alot of turbulance and cause the wrong readings. Most set ups I've seen for those cars have the bov on the endtank of the intercooler. Then there is just the reason of space. Sometimes you just cant fit it where it should go.
  24. There is supposed to be tension. Now your diaphragm should be air tight. If it isnt you more than likely need a new one.
