jeffer949
    5
Everything posted by jeffer949
  1. So its not for sale any more I take it then?
  2. ppsshhhhh You only Ran a 10.8 on your first time out? I expected more...
  3. Looks like the rear end has been tubbed or something. The radius on the stock wheel well is very gradual. looks like that one is straight and then a tight radius to another straight piece. Not the best pic but here http://i50.tinypic.com/3357exj.jpg
  4. I'm in line if you choose to ship. Mine are good but I like having spares.
  5. That would be great. Thanks. let me know how much you want for the spring and ill send you some money.
  6. Unfortunately I haven't seen any rebuild kits that include the spring. I'm hoping someone has a junk wheel cylinder laying around that they can rob the spring out of. Otherwise I'm going to have to buy a new cylinder.
  7. No there is a cone shaped spring that goes inside the wheel cylinder and goes on the piston.
  8. I wouldn't recommend running the stock headlights with the stock wiring. I would suggest you put in some headlight relay kits to you get full voltage to the lights. Then the stock wiring is only supporting the load to open the relay's. Just by doing this my stock sealed beams got probably 50% brighter. Then after that as long as you used heavy enough wire you should be able to run what ever wattage you like.
  9. Ya ive scoured that page for many hours. It makes me depressed because i know i will never be able to make a harness like they do. Good info though.
  10. So I've been working on my z and I'm rebuilding the wheel cylinders on the rear brakes. Somehow I lost one of the springs that goes on the piston. Anybody have one laying around? Maybe someone who did a rear disk upgrade? Let me know. Thanks
  11. When I did mine i had the machine shop do the bearing hole only. I used a die grinder with a cut off wheel and a oval shaped bur to get the clearance for the gear. Just kept cutting till i had clearance. On the shift rod I used a 5/8" drill bit and drilled it out. Just made it as square as possible and it followed the current hole. The only thing that needs to be done at the machine shop is the bearing hole.
  12. Try disconnecting the wastegate linkage and moving the arm on the turbo by hand. It should move freely. I had one that was stuck open and didnt move freely. on a spare engine i bought once. If it was stuck open it would take a long time for the boost to build.
  13. On the rubber insert i would suggest getting some off of a known vehicle and molding the console to fit. My 03 Frontier has them. Its nice to be able to pull them out and wash them out in the sink when they get nasty. Having a OEM molded piece fit into the console will make it look more finished also.
  14. How much is a good set worth to you. Just dissembled my suspension and found out I have these. I may part with them for the right price.
  15. They dont list a mid year break for the 260Z. Having an early 260 should i just order the 240Z kit? What are your thoughts?
  16. Turns out the map sensor was bad. Went back to a 250k sensor and it works.
  17. This is a mapdaddy sensor. I have the original one I'll throw in and try
  18. Hmm then why isn't it working... I'll try. Different sensor I guess
  19. I am repairing a v3.0 ms1 that has the solder pads 5 and 6 pulled out of the pcb. I have the whole board working except for the fact that I have no map signal. When I look at the diagram for the v3.0. It shows pins 1,2,and 3 going places. It doesn't show pins 4,5,6 going anywhere and says nc. Which I'm assuming means no current or no connection. But obviously they must go somewhere. I need to know where to jumper pins 5 and 6 to. I'm very capable of doing it I just need some direction. Any help would be appreciated.
  20. Normally I think its rather ridiculous when someone answers a question from a post that is many years old. Not this time. I actually just started working on getting my car back on the road this weekend and this is one thing i was wanting to get resolved as i still had a slight vibration. I clocked the left one at 60deg and it helped. Now i need to do the other one. Thank you for finally providing a definitive answer.
  21. There was a guy that used the Rota RB's in the 17x9 wheel with 245 or 255's all the way around. I think he posted pictures in the Rota group buy way back in the day. He had to roll the fender lips and stretch the fender a bit but they fit.
  22. My "one trip" statement is based on that was the only trip I took on that setup going on roads where I wasn't going 80-85 mph. The same setup went 12.8 at 110mph in the quarter mile so I'm pretty sure it was running well. Quick question. You state you have the hose off on your FPR. Does the z31 not use a vacuum/boost source to raise/lower the fuel pressure in accordance with pressure?
  23. Ive gotten 29mpg on one trip when i was only driving 70mph. Same trans and diff as you. Much bigger turbo(he351cw) and bigger injectors with supporting mods. Im running MS1extra though. I did get like 5mpg once with all in town "spirited" driving. Had to hear the BOV every time i shifted. lol. It could be a odometer that is off. You could have the wrong color speedo gear on the sender.
  24. Looks good Derek. How did your epoxied repair patches last. Any issues?
