Bernardd
Everything posted by Bernardd
  1. Great numbers Tim. Is this a twinscroll turbine housing/header or the same sfp header you used in previous setups?
  2. Nice to see what that hotside setup spools at. That's what I want to move to in my next setup. Good #'s btw.
  3. I run a stock bottom end and dyno at 422hp and have run mid to low 11sec 1/4s for a couple of years. I've run out of fuel flow or I'd be up around the 480rwhp. I might be at the edge of what the L can take but quite a few others are up around the same level with stock bottom ends.
  4. 1983 280zxt 2+2 -engine= stock bottom end, 185km on the clock -turbo= jy h-trim t04b compressor, t3 .82 stage 3 hotside -Exhaust system - 3" as well as muffler bypass behind rear wheel - How much boost- 21-23psi -ECU= I ran the time in my sig with a nistuned z31 ecu/z32 maf, i dyno'd with an infiniti m30 ecu/z32 maf - autospeed dc motor controller with an m15 and a m10 nozzle methanol setup. -CC injectors - z31 ecu/440cc - latest setup = m30ecu/nippon denso injectors flow tested@670cc -IC - dual grand national cores welded together with 2.5" piping both sides -HP= 422hp on a mustang dyno @ 21-22psi I should mention that I have a built cyl head, but I'm not sure on the specs. I get about 5psi by 3k with max setting hitting around 4k. In my opinion the L28ET is sufficient to run any zcar into the 10's with the earlier cars having very low 10sec et's available to them with very little work.
  5. Bottom end has not been balanced.
  6. I bought the head from Jeffp so I'm not sure what was done to it. The intake is stock.
  7. h-trim turbo w/.82 stage3 hotside, 680cc inj, z32 maf, Infiniti ecu c/w nistune, dual grand national core intercooler, 255lph high pressure fuel pump, diy progressive methanol inj and a built cyl head w/ custom elgin cam.
  8. 422hp at 6800rpm 366 ftlb's at 5200rpm This was on a mustang dyno and running 21-22psi. No scanner at the moment to post up the graph. Bernard
  9. Are you experiencing a large pressure drop? What are the IAT's like? IMO those two things determine if there is a need for an upgrade.
  10. what i meant was hall effect? sine wave? stuff like that. can it be modified to accept other signals? i believe that code was able to use the 2.3L wasted spark config as well as the syty/sunbird dizzy signal.
  11. what kind of signal(s) are needed for the ecu to be happy? crank + cam? stock cas? what kind of datalogging do you use? any extra pwm outputs on that ecu?
  12. Have you checked to see if you're getting the timing advance at 4300 that your commanding?
  13. In 3rd gear (jatco automatic) I see 5psi at 3k with full boost before 4k.
  14. The 280zxt doesn't need a computer to control it. It needs turbo modulator with a hose connected to the manifold. If you have the safety switch worked out then you are good to go. The other wires are for the kickdown switch which isn't NEEDED but is for downshifting when the pedal is on the floor and you're below a certain speed. If you have a nonturbo auto you will also have a lockup solenoid. Your transmission should be checked out if it's slipping, it could be a number of things causing that.
  15. I like to drive around with the boost set on "absolutely freaking kill" psi. It makes the world a better place. Lol
  16. I have the controller beside me in the cabin. With my controller, I can turn on the pump by adjusting the controller to see if the afr's go rich.
  17. Application: street/strip (mostly) Engine: l28et Turbo: T3/T4 (H-Trim/.82 stage 3) Boost: 18-26 psi Fuel system: z31 ecu Air fuel ratio: ~10.6-11.6/1 Spark plug: NGK bpr 8 Timing at max boost: ~24@5.2k/27 6.5k+ Meth injection: Autospeed diy controller kit Start injection at 2.5vdc/~3psi (maf based) max at 4.5vdc/~15psi Nozzle size: M10 (10 GPH; 630ml/min) + m15 Fluid: 100% meth (hic) 100% water will require the least amount of tuning and fluid. More meth requires more fluid but also yields the greatest power. IMO it is a small price to pay compared to an extensively built engine/DBB Turbo/MLS headgasket/etc etc. Methanol is very forgiving with regards to rich afr's. I didn't lose power until I got to 10.6 afr's and didn't really gain anything leaner than 11.5-7. I have my tune setup to rely on the meth to keep the engine together. I watch the wideband closely and when the boost is set on high, I always test the pump before boosting.
  18. any chance one could pickup the old cas or at least the optical wheel?
  19. http://videos.streetfire.net/video/The-Fastest-Mile-25679-on_163711.htm?ref=dc19c322-112d-4e2f-af82-9a880005c6ba Saw this linked on another board. Gotta have some steelish 'nads for that ride.
  20. You'd probably be best off asking coolingmist. I would run at least an m15 sized nozzle or nozzles to start.
  21. Agreed. You want to make sure your ecu can drive that injector and I would buy another/larger nozzle for your hp level. I would at minimum use the m10 and m6 supplied and you might find you need more.
  22. I've got the deltagate welded to the stock manifold and with a 7psi spring it creeps up to 10 or so high rpm.
