Imo your converter is too tight. You need at least another 1000rpm to start with. I've never found that retarding timing works very well with an automatic. I used 32-36deg's timing, 13 ish or so afr's and the boost would come on hard. I also put the car into second gear to give it a higher stall and then dropped in low as I launched. I had full boost almost instantly. I now have a holset he351 that reaches full boost about the same time my foot hits the floor. I'm getting 1.6 second launches and running high 6's in the 1/8th at 20psi (low boost). The other thing you could do is go with a smaller exhaust which I've also tried on that turbo. You'll get boost a lot earlier but you give up a lot on the top end. That is with a bored stock turbine housing. An actual stage 3 turbine housing would probably boost almost as soon but you'd gain back some top end as well. With your current setup ironed out you should be running in the tens or low eleven's with good tires. It's unfortunate that L28 guys aren't drag racers as there's not much info to work with. Keep us posted with how it goes.
