Leon
    25
Everything posted by Leon
  1. Good work! I'll have to check out that steering wheel sometime, the purchase is on my radar.
  2. I used EPS Plating in Hayward because they were local. They did a small batch of Aluminum fuel fittings for me that turned out really nice. I think it was something like $70 for the stripping and plating. I did get them polished at the metal finishing shop across the street to get a glossier finish.
  3. Really sorry to hear about the car, but your journey with it has been freakin' awesome! Hope to see it back on the track badder and stronger than ever.
  4. I'm with you on all 3 counts! I'm running triples and Megajolt crank-triggered ignition in a Z, it's one of my favorite upgrades. All said and done, it ran me maybe $500. I know Lazeum on this forum is also running a similar setup. That BHJ damper sounds like an awesome piece.
  5. Damn, that sucks! Sounds like the distributor drive gear spun on its shaft. There are some good threads on pinning it so it doesn't happen again. Or, convert to crank-triggered ignition...
  6. Sweet! Let me know how it turns out.
  7. Steve, tried to PM you but it said you can't accept any new messages. Send me a PM with your email or phone #.
  8. I'm not very familiar with Mikunis but Keith has modeled them up. You can contact him through the group.
  9. There is no challenge. This is just another opportunity for him to show-off his awesome Z and make it look like he actually does some work on it...
  10. First thing I'd do is check whether there are any air bleed holes above the fuel level. If so, plug them. Use a toothpick, Loctite, etc. Then, you may need to up-size some lower bleed holes to get more air in, which will help accelerate the fuel faster during tip-in conditions. I'd also try to contact Keith Franck, he knows a lot more than I do when it comes to this. I'm just relaying Keith's findings.
  11. Hell yeah it is! Although I would argue that the less radical the cam, the easier to tune. Long duration cams cause a lot of reversion in the low and mid range (if radical enough) which requires more fuel in order to have enough fresh mixture within the cylinder. My stock-cammed L24 took well to leaning out my idles and progression circuit. I know that Keith has done some work with the Mikuni PHH, but unsure of how far that was taken. Strange that you had issues joining.
  12. Holy crap! What the F was the PO thinking... Those are just carb isolators, you can find them in many places including Pierce Manifolds (yes, they deal in Webers). http://www.piercemanifolds.com/product_p/99005.145.htm http://www.piercemanifolds.com/product_p/z70-216.htm
  13. Franckly (LOL), F11 e-tubes are just about the worst in DCOE applications. They have bleed holes ABOVE the fuel level, which only serves to delay tip-in (read: flat spot). This is why you're running such a fat idle. Keith documented this on sidedraft central, the F7 e-tube is the one to go for if you're staying with Weber e-tubes. The one caveat is that it won't deliver great mileage because it's impedance is too low (small OD). Most (if not all) of the Weber e-tubes were designed for downdraft applications and work really poorly in the sidedrafts. This is because the height of the auxiliary venturi passageway is lower on sidedrafts. Transition has everything to do with the e-tube, this is what most don't realize. The e-tube/air jet combo controls WHEN the main circuit is able to kick in, and how strong that kick is. Most people just use a fat ass idle jet and/or accel pump shot to cover that issue up. This obviously causes problems elsewhere. Again, I recommend people register with the Sidedraft Central Yahoo Group, if not just for the sake of taking a look in the Files section. In there you'll find Keith's White Paper on tuning these carbs. While some of the info can use some updating, the majority of it is very much true. It's a thoroughly scientific way of setting up the carbs, skipping the typical guess-and-check and he-said, she-said methods.
  14. That S30 is fhptom's, who is a forum member.
  15. Welcome to the area Josh! Just in case you don't already know, 1976-and-newer cars need biennial smog testing, in case that affects your search.
  16. One of those 360 vans was at JCCS this year!
  17. Thank you, Takashi! Yeah, by the time I saw that they make everything in brass, I had already committed to stainless. That's exactly what I'd go for if the goal was to do it cheaper but keeping the vintage look. You know, during my initial design stage, after looking over the design of the stock rail I really wanted to braze on the fittings. I ultimately went with compression fittings because they're easier to work with, and soldering stainless seemed like a pain. Brazing fittings is definitely something I'd like to try to make a smoother-looking rail though! My next one may just be brass/copper...
  18. Long-time PO of the car (had it since '89) replied this morning with, "It came with the car. I looked around and at least at one time Motorsport Auto in OC carried one that looked just like it (from catalog photos). Otherwise its probably almost as old as the car!" Sorry man!
  19. Sent email to PO, we'll see if he remembers where it came from.
