Leon
    25
Everything posted by Leon
  1. Right, those would be the main issues.
  2. There will always be fuel out of suspension, it is called the "Tau layer", and it will contribute to an uneven mixture. A V8 (downdraft, central manifold) does not compare to the L6 (sidedraft), your analogy is not applicable. Uneven runners also screw up the resonance tuning effect and may add some extra vibration due to power variations between cylinders. FWIW...
  3. The FSM is your friend. A quick look tells me that the green and white wires could possibly be for your turn signal flasher.
  4. Hey, it was about as safe as I could make it!
  5. Use Google for searches. Type in keywords and follow them with site:hybridz.org. This makes the search site-specific.
  6. I'm with Zed, sounds like a lack of fuel in both cases. Check fuel pressure while driving. Just make sure that everything is tightly secured. FWIW, I had an issue that only popped up on the freeway. I'd be driving along just fine until I got to a hill. It would start misfiring and loosing power. It was tough to tell whether it was ignition or fuel related, since it appeared to coincide with warmer weather. However, the problem continued to get worse so I attached a fuel pressure gauge to my windshield and confirmed that pressure was dropping to zero right before the condition appeared! I replaced the filter by the tank and deleted the factory helper pump (260Z) and all was good again.
  7. Simply awesome! I would love to own (or at least drive ) an NSX someday.
  8. There is no good (performance) reason to mount the turbos as far from the energy source as possible.
  9. Good points, but I do like how the seat brackets raise the front of the seat up. Gives me better thigh support.
  10. Leon
    my edis setup
    Damn, I'm taking waaay too long to finish my MJLJ install! BTW, this is Derek's setup.
  11. Great input, Stepan. I will definitely look into Kirkey. Got any photos of your seat? Thanks John, that is another good alternative.
  12. Any luck, Stepan? I installed some Nismo knock-off seats in my Z and they don't quite cut it. They're too small for me, while at the same time placing me higher in the car. Good for someone below 6' but not for me. I'm planning to sell them off once I find a good alternative. It's tough to find a comfy seat that also sits low enough to fit me (6'2", 190lb), especially with a helmet. I really like the classy, classic race seat look (a'la "Speed" Seat from ZCCJDM) but am worried about comfort, not to mention price. Besides, I'm leary of buying seats without trying them out first. I did sit in a Corbeau A4 at a local speed shop and really liked them comfort wise. The back was taller, placing the headrest in the right spot and the shoulder bolsters fit me better as well. However, I'm betting that they're going to sit me pretty high in the cabin. Still searching...
  13. Looks like a decent starting point, good luck with the project! Oh, and it is against forum rules to mention "restoring an NSX" and not posting pictures in the accompanying thread.
  14. I have a 4.375 R200 CLSD sitting around and can check what mine is like. I haven't had it apart, but not sure on its history. I'll just have to remember to do so after I get home from work...
  15. Remove the needle from the piston and you'll take the needle and nozzle out of the picture. If it moves freely with the needle removed, you'll know for sure that it's a needle/nozzle issue.
  16. I'm with you on the backpressure deal, but exhausts are "tuned" to a certain harmonic resonance not velocity. I think Mike meant that the engine is not "self-tuning" nor the fuel maps readily adjustable and thus the engine cannot be altered much before fueling problems show up, he just phrased it poorly. With that said, I don't think a free-flowing exhaust would hurt an otherwise stock ZX. The header, maybe, but not the exhaust post-collector.
  17. Alex, the "C-cam" is not worth it, IMO. It has a little more duration and less lift, meaning it really isn't getting you anywhere. Might as well toss the cash into your toilet and flush. I'm with Z-Greek, if you're spending money on a cam, spend it on one that makes sense and is tailored to your needs. Isky does regrinds for what it's going to take for you to buy that rusty cam. You will be far ahead using Isky. You'll want resurfaced rockers with any cam change. You can run whatever cam you like with triples. I run a stock 240Z cam with my Webers and the low end torque is fantastic. Runs out of steam by 6000-6500rpm though. Stop by and I'll give you a ride sometime. It's all up to what you want. I bet Ron can set you up with a sweet street cam, all you need is a core.
  18. Not really. Retarded timing increases exhaust temps, not burn temps.
  19. Nice, how about some video!
  20. Took the car off the road for a few weeks and have been taking my time getting it back. Finally put some work in the past few days. I removed the carbs in order to replace a leaky intake/exhaust gasket. In my haste to install the header last September, I didn't replace the gasket. It was very fresh and I thought, "why the hell not". The picture shows why the hell not: Yes, leaks from every port! So I decided to do a mild refresh, since I can't go too crazy with the ZONC show coming up on the 28th. The Z needs to run in order to make it there! I cleaned up what I removed and painted the intake and air filter covers. New soft mounts and bottom gaskets (not pictured) from Pierce Manifolds. Great prices and shipping was quick since they're only 70 miles away. And I installed Dave's billet linkage arms (mock-up photo). One issue I ran into was the middle heim joint caused misalignment of the throttle rod. I "solved" this by removing the middle joint. This will be temporary and I'll get new joints eventually. I'll be on the road and (hopefully) running better than ever next week! There is plenty of work to be done in the meantime and I'm trying to get a few big things done before JCCS.
  21. If you don't like your inlaws, the Yaris is perfect. Otherwise, they'd be much better off getting a used Civic or Mazda3.
  22. The mustache bar looks like the R180 type, the way it bends gives it away. FWIW, the curved transverse link crossmember came about in '72. Looks like a PO did the R200 conversion with 240Z parts.
