29
Everything posted by jhm
Is this measurement the same across all s30 cars?
jhm replied to fusion's topic in S30 Series - 240z, 260z, 280z
Yes. There used to be a bolt-in harness bar available that bolted in right above there; not sure if it's still produced. just curious...why are you asking? -
If you're not concerned about maintaining the OEM wiring configuration, you can pull your input for the voltmeter from any good 12V circuit in the system (assuming that the voltmeter is working correctly). If your voltage regulator is not working correctly, that's another issue altogether, and you probably have bigger problems than a non-functioning voltmeter.... @ELbrown33, you're going to need to be more specific with your question. If you need help with a specific electrical issue, you may want to start a new thread, to avoid confusion with the ongoing discussion initiated by the original poster on this thread.
There's a member here that's producing the 3-piece spoilers for a pretty nice price. Otherwise, you can google search and find quite a few for sale used (eBay, etc.). For flares, there's a consensus building that most of the best fitting flares are coming from Japan these days...and the price really isn't that much more than one would've paid for something like Retro-Specs. I know someone that ordered from here recently and was very happy with the product and delivery timeframe: RHDJAPAN.COM. Hope this helps. Hide or report this.
What suspension are you running?? These kinds of wheel widths/backspacings will have significant interference with the stock strut spring perches. I also suspect those wheels & tires will have intereference issues with the frame rails on the front at full lock.
Rustylions Powder Coating | Powder Coating nj Prices
jhm replied to Rusty Lions's topic in Miscellaneous Tech
This post appears to be spam or trolling; and if not, should be listed in the Vendors section IINM? -
Yes, one bolt on each side to mount the engine when using the stock front crossmember. This should be the case for any engine swap that uses the stock crossmember. (There are aftermarket crossmember that may have a different bolt configuration.)
https://technotoytuning.com/
FYI for ALCON -- T3, Futofab, DatsunRestoMods, Ground Control and Apex Engineered are all having Black Friday/Cyber Monday sales and specials. Please fee free to add any others that you're aware of. Thanks, and happy shopping!
Which lowering springs to buy?
jhm replied to Phantom Z's topic in Brakes, Wheels, Suspension and Chassis
Only you, the owner/driver, can answer the question of Eibach (or any similar lowering spring) vs stock. Do you want stock ride height and softer ride, of do you want lowering and firmer suspension? Tokico is another good lowering spring, but they're pretty hard to find at this point. Vogtland seems to get good reviews, but I have no personal experience with them. Here's a link to one vendor for the high-quality bump stops referred to above. Pricey, but worth it if you're serious about good handling: http://www.fatcatmotorsports.com/FCM_bump_stops.htm -
Yes, those definitely appear to be OEM-style rubber bushings. Where did you source them from?
Depending on what flange your specific R200 has, it often needs to be swapped to match your driveshaft (or the flange on the driveshaft needs to be swapped to match the diff). See the attached photo for reference data. Also, if you haven't already done so, I would read all the relevant threads on this topic in the Drivetrain FAQs. Tons of great info in there. https://forums.hybridz.org/forum/83-drivetrain/
Lots of discussion on FB on this exact topic. IMHO, Paulo was a victim of his own success. He's a small one-man show, and got way behind on orders over the last year or two; and then had the misfortune of a major fire in his facilities (as mentioned above). It will be quite a while, if ever, if he gets business back on track. I know of a few people that have ordered from RHDJapan recently, and have been very happy: https://www.rhdjapan.com/
The voltmeter wiring is really pretty simple. What year/model is the car? Has the voltmeter EVER worked for you; and if so, when did it stop working? If a PO replaced ammeter with voltmeter, they may not have done it correctly. An easy diagnostic is to remove the gauge, and hook it directly to a good battery. If no reading, then the problem is the gauge. If it does read correctly, then you'll know the problem is in the wiring somewhere. A lot of the multiplug connectors in the various harnesses can easily get corroded and/or loose and cause issues like you're experiencing with the voltmeter. Good luck with it.
Negative Camber Roll Ceter Adjusters (NCRCA)
jhm replied to Twisted46's topic in Brakes, Wheels, Suspension and Chassis
Yep, increased track width will generally improve cornering traction overall. Another thing to keep in mind is that many techniques to widen the track will decrease the effective spring rate (due to the longer moment arm acting on the spring). -
I run 1" adapter/spacers on the rear to increase rear track width. I also have improved my front caster with adjustable TC rods, so the car turns fairly neutral. What size wheels and tires are you running? -
I've been using them for about a year now, and have been pretty happy with them. They improved the LCA geometry on my lowered suspension; increased my neg camber (by about a degree IIRC); and increased front track width by about 2" total. The only major downside I see with them is that they can induce interference between the steering arms and the wheels with rim diameter 15" or less. I would definitely buy them again. -
Agree with JonM....it's usually not necessary. After cutting my front fenders, I rolled a small inner lip to add some structural integrity. Made a big difference. One think to keep in mind: it may actually be helpful to NOT do anything to add stiffness here. For whatever reason, one may want the ability to push or pull the fender in/out in order to gain more clearance or reduce front end width....or just for purely aesthetic reasons. Adding stiffness to the fender metal makes this harder to do.
I had the same analysis of this area as JonM. I've done a lot of bracing in the front end; but nothing forward of the strut towers and sway bar mounts. When I cut out the top portion of the radiator support, I replaced it with a bolt-in section of thick angle aluminum. Figured I could replace the aluminum with steel if necessary; but haven't had any problems in two years...and it makes pulling the engine and trans SO much easier, as well as smaller jobs like water pump, harmonic balancer, etc.
Datsun Restomods - affordable & reliable CV axles for your S30
jhm replied to Dadzsun's topic in Vendor's Forum
Really like how both versions are offered....either direct swap with the half-shafts, or the full unit which does away with the need for bolt-in side axles. Thanks for posting these up! -
The fuel sending unit is located inside your fuel tank. However, before going to the effort of dropping your tank to remove the sending unit, I would do some preliminary troubleshooting.....may be simple as loose wiring in your dash harness, or the gauge itself has stopped working, etc, etc. If you don't have the FSM for your car, you can download it for free at: http://www.xenonzcar.com/.
Sudden Electrical Issues After Audio Amp Disconnect
jhm replied to 280driver's topic in S30 Series - 240z, 260z, 280z
You can certainly try hooking the amp back up to see if anything changes. There's no telling what crazy wiring mods previous owners have down to the car. The main fuse panel in the passenger footwell area are the only fuses you need to check, unless someone has added more fuses throughout the various harnesses over the years. If the amp was somehow wired so as to affect the operation of ANY other components (e.g. your dash lights, your gauges, etc); I'd suggest fixing that immediately. Shouldn't work that way. Good luck with it. -
My guess would be that the amp was installed somewhere in your dash; and in disconnecting it, you disturbed some other circuit(s) which apparently affected multiple components....could've been 12V lines, or grounds, or signal feed lines, or some combination of all three. Don you have full schematics for your car? If not, you can download them for free from Xenonzcar.com. Worth their weight in gold for troubleshooting issues exactly like the ones you're currently experiencing. -
280z Rear end into Series 1 240z help..
jhm replied to 5 Star Rising's topic in S30 Series - 240z, 260z, 280z
Very generally speaking, you'll need the correct mustache bar and half-shafts for the R200. You will also need to swap your input flange on to the R200 so it matches up to your driveshaft. But honestly, why do you think you need to do the swap? The R200 is quite a bit heavier and bulkier than the R180, and if you're not planning to beef up your engine output, the swap is really not necessary. Also, I would open both differentials to verify the drive ratio(s) before starting the swap. My two cents... -
I'd suggest putting the car on jackstands and running it while searching underneath for the source of the noise(s). Clunking noise could be one of a dozen potential issues. Same goes for "grinding" and "whirring" noises. May need a stethoscope-type of tool to locate noises internal to a component. You can run the speed up and down in different gears (including reverse), and simulate load on the rear axle with the foot brake and parking brake. You can also check for obvious looseness in components with the suspension unloaded. Obviously this doesn't fully simulate driving down a road, but it can be very helpful in either locating or eliminating sources of noises/issues. Replacing parts before doing any diagnosis is just guess-work. My two cents...
- 5 replies
- differential
- help!!!
(and 1 more)
Tagged with:
Uh, did you happen to notice that this thread is 10 years old?
