28
Everything posted by jhm
Looks like I have cut springs... what now?
jhm replied to AydinZ71's topic in Brakes, Wheels, Suspension and Chassis
Some people will sand the paint on the shocks, if the fit's too tight. Wire-brushing the inside of the strut tube can help also, exspecially if corrosion has built up in there. Don't forget to pour a little oil in the strut tube (I use cheap motor oil, but most any kind will do) before you do final install of the shock -- this will help prevent corrosion in the future and will also help with heat dissipation from the shock when it's being worked hard. Good progress...glad you're enjoying it! -
I think I've mentioned this once or twice previously, but DP Racing and Ground Control both make true bolt-in camber plates that incorporate 2.5" top hats in their design, to avoid this issue you're currently having. I'd definitely consider them for usage in your front coilovers. You could try the teflon sheet idea, but that would obviously be a wear item; and the fitted bushing and bearing solution already mentioned would be better. Yes, the spring top perch is AKA the spring top hat.
Ideally, you don't want any non-fitted metal-to-metal contact in the system....looks like you may have some of that occurring between the top hat and the lower face of the camber plate? It's not as critical in the rear suspension, where there's minimal twisting of the strut/spring as the suspension articulates through it's range of motion....but a definite no-no in the front, which is constantly twisting due to the simple act of steering the car. That's one issue with this style of camber plate, which doesn't have an integrated spring top hat in the design like some of the other bolt-in camber plates. You can mitigate the interference by inserting a thrust washer in between the top hat and the camber plate; just remember that any additional hardware length you add is reducing potential suspension range of travel. The OEM thrust bearing in the front stock strut setup is very durable, but fairly thick when compared to some of the ultra-thin thrust bearings available aftermarket. Try it this way, and see if it's a problem. It may work just fine for your purposes. If it turns out to be problematic, there are some other tricks you can try (e.g. T3 makes a nice 2.5" top hat that has a thin integrated thrust bearing in it's design). https://technotoytuning.com/nissan/260z/camber-plate-upper-hat-system-datsun-260z When piecing together coilovers (or any major system in the car) from different parts and vendors, there's always experimentation and testing required to find the right combination that works for you. I actually enjoy that process, because you're kind of making something out of nothing. Good luck with it.
I used a 3-way splitter, too...similar to @Miles. Crazy thing though -- I had a hard time finding one with deep enough threaded female ports...eventually found a supplier on eBay (from Latvia!) that had the one I needed. Looks like they're still available if you can't source one locally. https://www.ebay.com/i/264460358871?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=264460358871&targetid=934793862176&device=c&mktype=pla&googleloc=9008565&poi=&campaignid=10460107080&mkgroupid=106723174707&rlsatarget=pla-934793862176&abcId=2146001&merchantid=113613716&gclid=CjwKCAiA-_L9BRBQEiwA-bm5fsnFoomhpGU_ZHHRbK5CmpL-LxTRPXGb-dFDufeT6EE0ghXgev3c3xoCErwQAvD_BwE WRT to your question regarding disc brakes on all 4 corners, you may need a larger bore MC (swapping reservoirs on your current 7/8 MC won't do anything.) Depending on which disc setup you choose for the rear (and also if you're considering swapping in larger front disc setup), you typically will need to upgrade the MC to 15/16 or 1". LOTS of good reading in the FAQs on this exact topic.
You certainly can use some thick rubber to sandwich between the strut tower and the top of the camber plate, but I personally don't think it's necessary from a structural perspective...the structural function of the rubber in the stock isolator is primarily to allow for angular changes in the top of the shock as the suspension moves through its range of motion. The monoball joint incorporated in the aftermarket camber plates accomplishes that function. If you do install some kind of rubber pad between the strut tower and the top of the camber plate may help cut down on the road noise vibrations transmitted through the camber plate; but you need to accept the fact that any metal camber plates are going to be much noisier than the stock rubber isolators.) FOL. Need to ensure that it doesn't flex so much that it induces angular changes in the suspension geometry. Maybe polyurethane might be a better material, from that perspective, if you decide you need something in there. The reality is that it's just one more rattle (mixed in with many other random rattles) and you only notice it when driving on the street....it's irrelevant once you're on the track. -
Yes, you will definitely want to replace the stock isolators with something that gives you adjustability and more negative camber. Those Silvermine bolt-in camber plates are certainly some of the cheapest (lowest cost) you will find, and there's nothing wrong with them (I've used similar ones on some of my cars); but their range of adjustment is limited. IIRC, I could achieve approx 1.5 deg in the rear and maybe 2.5 in the front with them (with moderate lowering, adjustable coilovers, and stock control arms). If they meet your needs, go for it. If you think you will want more camber adjustability, take a look at the bolt-in units from Ground Control and DP Racing. I've used both and have been extremely happy with them. As a bonus, they both allow a limited degree of caster adjustment. https://www.dpracing.co/datsun-z-front-suspension-1 https://groundcontrolstore.com/collections/s30/products/no-cut-camber-caster-plate-z-car-pair There are other "bolt-in" plates available that will give more range of adjustment, but require cutting the strut tower; so you'll want to avoid those. P.S. Hang on to those stock isolators and don't throw them out. At some point down the road, either you'll want them or someone else will. -
The unit with the brass electrical bullet connector on top is the brake malfunction warning switch....it's intended to detect an imbalance in pressure between the front and rear systems. Someone must have removed the wire lead at some point. The other unit is the OEM distribution block/proportioning valve. If you're planning to install an aftermarket rear proportioning valve, you can either remove the OEM unit or gut it. Since you're already planning to run new lines from the MC, may be best to just remove it....it will clean up the engine compartment and reduce the total potential points of failure/leaks. If you decide to remove either (or both) of these; don't throw them out -- keep them and put them up for sale. Folks are always looking for these for restoration projects, particularly on forums like ClassicZCars.com and "S30 Life" on FB.
Drum brakes for a racing application
True statement IMO. I have shied away from cross-drilled rotors, because I know too many people that have suffered cracked rotors due to the cross-drilling. I like slotted rotors, but the plain-jane pancake rotors are fine too....just use some good pads. I prefer Carbotech for track (and Porterfields for street), but that's just my own personal preference because I've found a good combination that works for me with my particular setup. There are several good high-performance pads available to choose from. I'm not at that point yet....still get the clenched butt cheeks when the pedal goes to the floor. -
It largely depends on what you plan to do with the front discs (if anything) and what type of events you plan to run.... Start by reading all the "brake upgrade" threads in this sub-forum and in the FAQs if you haven't already done so. You'll find a TON of great info. The stock front discs and rear drums are actually a pretty well-balanced system, and work ok for most types of short duration racing (e.g. time trials, auto-x, etc). Longer events will quickly overheat the system and you will find yourself looking for better braking longevity during extended high-speed use. You'll find the fronts overheating/fading (and possibly boiling the fluid) and the aluminum rear drums will expand and lost most of their effectiveness. It's an old S30 trick to pull the rear parking brake up one or two clicks when this starts to happen. Some people have preferred to go with cast iron drums in the rear because they expand less (but are significantly heavier than the stock ali drums.) If you're not planning to upgrade the fronts with bigger, vented rotors and calipers, you should probably leave the drums in the rear IMHO. Don't forget that bigger calipers in the front and/or disc brakes in the rear will typically necessitate a larger bore MC. If you leave the drums in the rear for now, Porterfields are probably some of the best shoes you can get....the generic off-the-shelf shoes (e.g. Centric, etc) from the auto parts chain stores are not worth your time. -
There's a company in the UK that's producing hard-to-find replacement body panels, and the rear slam panel is one of them. Looks like they do pretty nice work. There may be other vendors doing similar work; but I just happened to notice their ad the other day on FB: username was "Kim Mays" on the "Datsun Parts and Needs" FB page. Here's a link; but may not work for you if you're not a member of the group: https://www.facebook.com/photo?fbid=1661652560538618&set=pcb.1655145461187252
To anyone who has had their windshield out....
jhm replied to Ironhead's topic in Miscellaneous Tech
Have had the windshield out of my last two 260s and did not have any such hole in driver upper corner of the frame. -
Coilovers and struts. $1,000 budget
The Tokico reds were my favorite stock spring replacement, but they are NLA unless you find a set used. Eibach also makes a "performance replacement spring", but I would avoid a progressive spring if that's all they offer for your car. If budget is a major factor (as it is for most of us!), take a look at the Vogtland springs on eBay....they seem to be a decent option as a shorter/stiffer spring. Even cheaper....years ago, people were using stock Chevy Chevette springs....google search for those discussions here on HybridZ. The cheapest option is to cut the stock springs; which a lot of folks have tried with varying degrees of success. Take a look at the tracks and venues that you plan to run at before making final decision. A spring that works well for a flat, smooth auto-x pad might be a terrible choice for a rough road course with heavy curbing and elevation changes. -
Not sure I understand what you mean "make a new plate for the shock tower top"; but there are a couple of camber plate options that allow you to move the top mounting point of the front strut assembly "rearward", in order to achieve a slight bit more caster. DP Racing, K-Mac and Ground Control bolt-in camber plates are a couple examples. EMI plates were a very popular option years ago, but they are NLA (new)....might be able to find some used. If you use the camber plates to achieve increased caster, you are doing so at the expense of decreased static camber. A more effective technique to increase your caster is with adjustable TC rods. To make any significant difference, you would need to use these in conjunction with a front LCA that incorporates a monoball mounting (i.e. not the stock rubber bushing). You can fabricate your own monoball LCAs, or purchase them pre-fabbed from vendors like T3, Futofab and Apex Engineering. The advantage of more caster in a track car is that it allows you to run less static camber (for better braking performance) and still achieve good dynamic camber characteristics on the loaded tire during turning. For a street-driven car, I honestly don't know what the benefits of increased caster might be....perhaps better high-speed stability? Keep in mind that increasing the caster will result in heavier steering at low speeds, because the wheels are having to actually "lift" the front end as you dial in steering input. Hope this helps.
Springs and shocks constitute the major expense in switching to coilovers (camber plates, too....if you're replacing the stock strut isolators with aftermarket camber plates.) If you're intent on purchasing a coilover "kit", I would press the vendor for details on those component -- what make and model of each? I've seen plenty of kits that cheap out on one or more of the key components, to keep overall kit price down. But you pay for it in lost performance. If you don't mind doing the work to section your struts, you can usually piece together your own coilovers for less than what you would pay for a complete kit of the same quality. This also allows you to select exactly what pieces you want vs what some vendor has pieced together. One feature that's nice on some of the kits (e.g. BC Coilovers) is the ability to adjust ride height without compromising bump & droop travel. You could incorporate this into your design if you're building your own coilovers; it just takes more fab work and some additional hardware expense. For shocks, I've had good luck with Bilsteins but switched to Koni yellows last year that @Ben280 described (I went with single adjustable, mainly for budget reasons....got a killer deal from ECS Tuning.) Tokicos are fine, but not for higher spring rates; and may not meet your needs for EP class. You can still find them used sometimes on eBay and various forums. For springs, I'm partial to QA1, Swift and HyperCo; but there are many fine spring manufacturers out there and everyone has their own preference. Camber plates: I like DP racing and Ground Control...but plenty of other good options to choose from here as well. I run XP and am not familiar with EP requirements; so be sure to thoroughly research what you can and can't do classing-wise, if you haven't already done so. Good luck with it! -
ClassicZCars is always a good resource for these types of OEM restoration/rebuild issues. Found a couple threads that may help. One guy swapped his passenger and driver lock barrels; others had suggested repairs depending on the specific issue. I'm sure there are other discussions on that forum regarding this topic since it's such a common problem for these old cars. https://www.classiczcars.com/forums/topic/56706-possible-fix-for-worn-out-door-locks/ https://www.classiczcars.com/forums/topic/35066-78-280z-door-locks-worn-out/ Looks like ZCarDepot offers replacement locks; may be other vendors out there as well, like MSA, etc. Sometimes these new lock barrels can be rekeyed to match your existing key, or you can just live with FOL of having to add a new key to your keyring. What year is your car? https://zcardepot.com/products/door-lock-cylinder-set-with-keys-77-78-280z?_pos=3&_sid=9e230f569&_ss=r
No, I only have one Z at the moment. The point I was trying to make is that I've owned several over the years; but I've never been willing to spend a big chunk of money on a nice one...opting instead to buy junkers and restore them myself. It's a satisfying process to build your own car, exactly the way you want it, vs buying something already pre-built.
I've had a dozen old Z's, and have never been willing to shell out the big bucks for a nice clean driveable car. They've all been crappy rust buckets, and I spend a couple years restoring/rebuilding them. Your best bet now is to do as much research as possible so you know what you're getting into before spending your hard-earned cash.
280z spring rates and sway bar combinations
jhm replied to nick-james's topic in Brakes, Wheels, Suspension and Chassis
There's actually quite a few discussions along these lines; but you may have to search for them using Google search....the website search engine isn't the best. Just be sure to include "HybridZ" in your search string. First thing you need to do is figure out what you have currently. If there are no markings on the springs, use an online spring rate calculator to estimate the spring rate. Open up the struts and see what kind of shocks you have. What sway bars, if any, do you currently have? What condition are the bushings in? What size wheels and tires do you have (and what brand/model tire)? Do your current coilovers incorporate camber plates, or have they retained the stock strut isolators? (The stock isolators actually do a very good job damping out road noise and vibration. And I'd recommend you corner-scale the car, to determine your corner weights (primarily to determine your F-R distribution, since there's typically not a large variation in L-R distro.) Are you planning to keep the car for a long time? If so, it's worth spending some $ on quality parts that will last a long time. Finally, decide what your budget goals and constraints are, if any. Next....if street use and compliant ride really is your #1 priority, start compiling list of what changes you'll want to achieve that goal. For a compliant ride, I'd go no stiffer than 200-250 lb/in spring rate. (Even softer if your local roads are in rough shape.) A longer spring of the same rate will typically be more compliant than a shorter spring of the same rate. Are you planning to lower the car? If so, realize that doing so often compromises streetability and the fact that you may need to section the struts in order to retain good bump and droop suspension travel. Shock damping rates play as big a role in ride comfort as spring rate does, so don't ignore shock selection when considering your spring selection. Adjustable shocks are nice; dual adjustable (compression & rebound) are really nice, but often not necessary. Keep in mind that each shock manufacturer has a different design for their shock adjustability. (e.g. Koni single adjustable shocks function differently than Tokico single-adjustable, etc, etc.) Shocks are an area where one can spend a fortune, so factor that into your budget decision process. Tire selection is also extremely important, from both a performance and ride comfort factor, so plan to spend some time (and money) deciding which tire brand/model/size best meets your performance and comfort goals. You'll have to decide for yourself how stiff a sway bar front and rear you'll want. For many street-driven cars, the stock sway bars are fine, especially if you freshen up the bushings with some good PU pieces. BUT, PU can also transmit more road noise and vibration vs rubber....so you may decide to go with a mix of PU and new rubber bushings. I'm sure I'm missing several other items here to consider; just trying to highlight some of the major decision points. You may want to peruse some of the member's builds to find those with similar setups and goals as yours to see what's worked well (and maybe not so well). Good luck with it. -
In case you've not seen this, there are some great ideas here for chassis stiffening: https://imgur.com/a/R27sh Will SCCA be the sole sanctioning body for the events you plan on running (i.e. are you planning to run only SCCA-sanctioned events); and what types of events/classing do you plan to run? Interested to follow progress on your build.
Don't recall the internals for the clocks on the later years; but like the others have recommended, it's not a difficult process to disassemble these old clocks to clean and lubricate them, and get them working again. Make sure you use a very light lubricant specifically for clock and watch mechanisms. You can also gut the clock housing, and replace the spring internals with a modern digital clock mechanism...either battery or 12V operated. Very cheap upgrade, and very reliable. I recall a few discussions on ClassicZcar.com along these lines, as @jonbill suggested.
Stainless steel brake line problem
jhm replied to RDuff's topic in Brakes, Wheels, Suspension and Chassis
IMHO, stainless steel is one of the most difficult (if not THE most difficult) material to work with for brake and fuel lines. The hardness of SS makes it more difficult to get leak-free connections as compared to softer metals. If the leaks are on the smaller/slower side, you may be able to resolve via loosening and tightening several times....helping the metal to take a "set" within the connection. It also helps to do this with the fixture unbolted from its mounting point (e.g. leave the Master Cylinder unbolted, or at least loose, on the brake booster when tightening the front and rear lines to the MC.) This will help ensure that the incoming/outgoing lines have optimal geometry WRT the fixture they are connecting to. This is particularly important when working with a non-malleable material like SS. Just out of curiosity, what style flares did the brake line kit come with? Also, did you visually inspect all your original hardware (tee connections, prop valve, etc) before installing the new lines to ensure you had no damage on any of the nippled connection points? -
Hardline routing at master cylinder
Yep...as long as the MC has constant bore, can swap the reservoirs so the larger tank services the front brakes, as Miles suggested. Couldn't tell from your OP if you were considering swapping in a Wilwood, or some other aftermarket, MC. Sounds like you're trying to maintain things as original as possible, IINM. Similar discussion on ClassicZCar: https://www.classiczcars.com/forums/topic/21826-brake-master-cylinder-240z/ -
Whatever MC you decide to use, you just need to ensure that your front brake lines are routed to the reservoir designated "Front", and the rear lines to the "Rear" reservoir. Up to you to pick the master that best meets all your overall needs for your build. If you switch to anything other than an original MC for your year, be mindful of the fact that the prop valve and electric safety fail switch may not work as intended. That may or may not be important to you. I hope this answers your questions; but if not, post again with more detail on your car and your goals for it. -
@heyitsrama, Hey Amar, do you notice the fuel leak all the time; or just at the track (e.g. long fast left-handers)? Your fuel cap may not be making a tight seal. If it's a stock cap, you can try bending the little metal tabs to tighten it. If it's a locking cap, many of them don't fit tightly enough to provide a good tight seal. Old BMW locking caps can be made to work nicely, but they're no longer in production and pretty hard to find these days. I have the stock tank still, and have to use the stock non-locking cap to prevent leakage any time I'm at the track....I only use the locking cap for street driving. Regarding difficulty filling your tank....have you modified the stock tank hosing? If so, that may be the root cause of the issue. The tank needs to move fuel freely within itself, and be able to vent air (both for ease of filling, and to prevent pressure build-up during operation.) The stock evap tank allowed this, but lots of people (including myself) remove it. The "hose loop" method mentioned by @Twisted46 usually fixes most of the issue. Good luck with, and good job getting your lap times down!
Settling on two rear end options...
jhm replied to AydinZ71's topic in S30 Series - 240z, 260z, 280z
No, well-built clutch LSDs are actually very effective, especially in racing applications because of they're tuneability/adjustability. Helical are nice because they are quite durable and largely mx-free. The Phantom Grip pos is neither. It's a half-assed attempt to simulate an LSD; but the very nature of its design eats the internals of the differential. Google "Phantom Grip" and you'll see some real horror stories. It may work (sort of) for a while, but it eventually eats the diff. What are your goals for the car (I.e intended usage and application).? That will help determine the best LSD solution for your needs.
