jhm
Super Moderators
    29
Everything posted by jhm
  1. Suggest you start by reading all the FAQs -- plenty of good discussions in there on how to accomplish all the mods you are considering. You can try reshaping the rear flares, as JonMort suggested. If you do, I would consider adding a similarly-styled flare to the front....for both functionality and aesthetics. If you decide to replace, replacing the rear quarter panels is a very common repair. You can get the panels used from a donor car or new from one of the vendors that produce reproduction body panels. Good luck with it. Your car appears to be way further ahead than many project cars are at the start.
  2. Looks like you've built your own fuse and relay block inside the engine compartment....are any of those circuits switched?
  3. Ah, sorry -- did not realize that your car was equipped with air conditioning. My bad.
  4. Joost, it's been a long time since I've had the stock ventilation system; but IIRC, all air flow is controlled mechanically (i.e. via cables between the dashboard controls and the blower assembly). Those old cable systems can get gummed up and not work smoothly, the cables can break over time, or the flapper valves internal to the blower can stick or get jammed in one position. Any of those issues could be why you're not getting hot air to your windscreen defroster vents. It could also be as simple as the heat ducting hoses falling off the heater blower or the plastic defroster ducts up at the base of the windshield. Any of these problems should be easily fixable by disassembling/cleaning/repairing/adjusting/etc as necessary without any great expense. Do you have the FSM for your car? It gives a pretty good description of the cabin heating/ventilation system. http://www.xenonzcar.com/s30.html Cheers.
  5. Unless you plan on using an electric water pump, I don't think this will really achieve your intended goal. The fan will continue to run after you shut the engine off; but will really only effectively cool the fluid in the radiator vs cooling the engine. I'm surprised this setup worked on your Alfa, but I know pretty much zero about most Italian hardware. Maybe the smaller Alfa engine block and overall cooling system was small enough to be affected by the cooler fluid in the radiator. Regarding your second question, you could install switched and unswitched "hot posts" (using relays of course) to power a variety of high-draw accessories, like your electric fan, AC/heat blower fan, etc. This approach gives you a lot of flexibility in your wiring strategy, and provides max amperage directly to accessories without running through the fragile OEM switches and wiring harnesses.
  6. And there's a nifty driveline angle finder in the Tremec Toolbox app for your smartphone.
  7. Cool stuff....thanks for sharing! I love perusing old/original documentation, like those Datsun comp parts brochures.
  8. jhm
    Hi Searching
    Are these what you're looking for?
  9. After you decide what you want, here's some useful links for sourcing the correct unit: https://forums.nasioc.com/forums/showthread.php?t=1969700 https://forums.nasioc.com/forums/showthread.php?t=2597453
  10. Wheels out of balance seems to be the obvious answer, in most cases. Other possibilities include flat spots in tires, rims that are bent, worn steering rack bushings (the mounting bushings that are used to clamp it to the front crossmember), worn steering coupler, worn out shocks.
  11. Sorry, I didn't watch your video earlier; but just watched it now. Looks like you have a Voltmeter, vs an Ammeter (i.e. "Amp Gauge")....is that correct? Two different gauges that measure two different metrics. Typically, a voltmeter will react much less to changes in system amperage draw than an ammeter. From your video, I'm guessing that the engine was NOT running when you filmed the video? Is that correct? If so, I would try the same test again but with the engine running (and the alternator charging). You should see much smaller (and possibly none) fluctuations in the voltmeter reading, because the alternator/voltage regulator will keep things more stable in your electrical system. And obviously, the voltmeter should be reading somewhere in the 13-14 V range with the engine running. If not, there's a problem with the battery charging subsystem. Hope this makes sense. If not, feel free to ask more questions.
  12. Yes, completely normal. Any change in system draw will cause the Ammeter needle to move around.
  13. Not sure from your photo, but is it this sensor? https://www.carparts.com/details/Nissan/280Z/Replacement/Coolant_Temperature_Sensor/1976/SET-RB31280001-2.html?utm_source=connexity&utm_medium=cpc&utm_campaign=affpla&TID=zlaaff
  14. I may have misunderstood your original post. Is the rust inside your strut tube (where the shock is installed), or on the underside of your strut tower? My earlier response assumed it was the latter; but now I'm thinking it's the former. Sorry, my bad. As Newzed stated, you can remove the rust mechanically; or use a liquid chemical product to neutralize the rust. After it's cleaned up and painted, a little oil inside the tube will help prevent future oxidation and help with heat dissipation.
  15. If you wanted, you could put one PU bushing on the "front" of the TC cup, and leave your new rubber bushing on the backside of the cup. This minimizes the risk of damaging the cup due to the inflexibility of PU. Regarding your second question....I don't know what your definition of "quite a bit" is; but how about removing the rust, painting, and if necessary, weld in some reinforcement sheet metal? It's a pretty simple shape, so it should be easy to cut and fit the reinforcement pieces.
  16. Sounds like a loose connection somewhere in the ignition circuitry; judging from your statement about driving over a speed bump. WRT your question on the ignition switch/lock: no, I don't believe that would contribute to your issue. Once the ignition switch is moved to a particular position, those connections are completed and it doesn't matter whether the key is in the switch or not. My key is very worn, as well, and I can remove it from the switch anytime without any affect.
  17. Hey Joost- Sounds like the problem started after you fixed some coolant leaks in the vicinity of the fuel rail? If so, maybe relook those repairs to ensure the repairs themselves weren't the cause of your issues? Have you had to refill your coolant during these tests, or is it maintaining a constant level of fill? Liquid in your exhaust during first couple minutes of startup is not all unusual, as NewZed pointed out, and can even be caused by nothing more than atmospheric condensation (usually from the previous shutdown). If this is what's occurring, it will be water only. If you can detect actual coolant in the liquid in the exhaust (I don't know how one can definitely do that), then you likely have a problem. A good way to monitor engine temperatures is with a simple IR thermometer, especially if you're not confident in the temp gauge readings. You can use the IR unit to check temps at various points....radiator, coolant lines, engine block, etc. Good luck with it.
  18. Good question. Was wondering the same thing myself. @RTz, @SuperDan, @stony, @tube80z
  19. Not a website, but this may help some with parts list and prices. (You need to be a FB user.)
  20. No, the d-shape is to keep the shock shaft from spinning whilst tightening the top locking nut. I don't know about Koni Yellows, but the stock hole should be compatible with the shaft on KYB, Tokicos, Sachs, and other popular strut inserts made for the S30. Bilsteins are an obvious exception, due to the large shaft diameter and top locking nut.
  21. Have not seen that company previously; but I don't follow drifting. Do you know what manufacture springs and shocks they use? (I was not apparent from the website.) One way that vendors are able to offer kits inexpensively is to use generic components manufactured on the cheap. Are you sure you want those spring rates? Perhaps they're optimized for drifting; but would not be practical in most other applications for multiple reasons. Finally, are their strut tubes manufactured from aluminum? It sounds as though they are; which makes things a bit trickier than usual when welding them to your stock steel strut tubes.
  22. No, the holes in the stock strut top isolator are not threaded; but they do need to be enlarged to accommodate Bilstein shocks. They should be fine as-is for KYBs, Tokicos, and other shocks with stock-sized threaded shaft at the top. The author also pointed out that he could have tapped the enlarged hole to match the threading on the Bilstein (as @thehelix112 had), but decided it was not necessary for his installation.
  23. I think stock spring rates were in the 100-120 lb/in range (when new). Tokico advertised rates were 140/160 (240Z) and 185/200 (280Z). Don't know Eibach and Vogtland advertised rates, but you may have already dug that up. (I'd be surprised if they were significantly different from Tokicos.) So go from there, based on your existing experience with the Tokicos and Eibachs. Keep in mind that a longer spring will be more compliant than a shorter spring of the same rate. You can go longer than the lengths I suggested, but may need a spring compressor if you go much longer than 8 or 9" uncompressed length. Not a big deal if you don't mess with it often; but kind of a pain if you pull the suspension frequently. I like Swift, HyperCo, and QA1 for springs....but that's purely a personal preference. Everyone has their own favorites. Proper shock valving (both compression and extension) has a much bigger impact on ride comfort and suspension compliance than pure spring rate. Lots of good choices to choose from in shocks. Here's a nice write-up which retained the stock rubber strut isolators. They used a Cosmo coilover kit; but you could use whatever kit you like, or fashion your own from individual piece-parts:
  24. If you really don't want to cut and section the strut tubes, it's still entirely possible to build your own adjustable coilovers using universal parts. (I think Mike Kelly used this kind of setup for a long time on his car.) This is especially true if you have no plans to significantly lower your car. 2.5" coilover sleeves, 2.5" springs of your preferred spring rate (7 - 8" uncompressed length should work well), and top hats. Make sure your front struts still incorporate some kind of thrust or needle bearing capability. Some guys have even done this while retaining the stock rubber strut top isolators for ride comfort and noise abatement. Stick with quality-made springs and avoid the generic eBay specials. The advantages are multi-fold....adjustability, limitless choice of spring rates, and much easier to work on.
  25. What side axles are you using with the STi R180; and are you sure they're properly seated in the LSD? Also, it sounds as though you've driven at least a few miles on the rebuilt half-shafts...so you're reasonably sure you can rule them out as source of the noise? I had an issue with worn inner bushings on my rear LCAs causing a rattle/clunk; but that was only under heavy load. Sounds like your issue is happening under any loading condition. It still may be worth checking if you haven't already done so. Finally, if your car is sitting 2-3" higher than stock, that's really high. Definitely worth lowering it closer to your intended ride height and see if the problem persists.
