I am also intrigued by this. So, having another p90 just lying here doing nothing, I figured I would give it a shot. What I am attempting is to see if I can increase boost by adding the Singh grooves. My bottom end is a 3 liter stroker that uses a diesel crank and custom pistons. The pistons used were designed so that they could be used in many different engine configurations thus they are not specifically for a turbo application. The main drawback to their design is they are flat tops that sit 1mm down in the bore. If you look at the Singh site you will see he says for the grooves to work optimally, there should be 2mm piston to quench pad clearance which is what I have with a 1mm HG. What I should have done was to groove my existing head and test, unfortunately I grooved the new head and also had it cleaned up to match the existing head. When I install the new head, should I see any improvement, I will groove the old head to make sure I see the same type of results.
I will report my findings, whether good or bad, on this site.
Joe
