tube80z
Super Moderators-
30
Everything posted by tube80z
Strengthening Front Anti Sway Bar Mounts
tube80z replied to 260DET's topic in Brakes, Wheels, Suspension and Chassis
Not really. For the front your idea sounds good. I'd weld in a doubler plate (could be a large washer to the tube). If you wanted to make it stronger you could wrap the frame rail so the vertical edge was caught. In the back I'd just drill a hole in the upright and bolt a male heim on both sides. You can weld a washer as a doubler spread the load out. My local bolt store sells uncoated steel washers that are good for this. Cary -
Springs, Bars, and Load Transfer
tube80z replied to johnc's topic in Brakes, Wheels, Suspension and Chassis
Thanks for the info Keith. I'm not sure if it's easier or harder to do this for autox versus a road racer. Up to now I mostly used subjective feedback, a stopwatch, and tire temps. After going to Claude's seminar I invested in enough datalogging to be able to measure this on the car. I have yet to put this in actual practice beyond experiments in the shop. And from playing with this you can use ordinary linear rotary pots and linkage and seem to get data that's good too (low buck version). Where I'm really headed is being able to get real-time tire temps via IR sensors, which should help answer some of these questions. On the GC advance designs. Do you think the issues you've seen are unique to road racing? Why I ask is that I find them to work very well for me in a SoloII environment but they weren't valved right when I first go them. They feel much better than the tokicos and Koni (DAs) I've used before. Cary
If you think this is harsh you should see corner carvers In the back nothing is usually done. You can only change the angle of the control arms by moving the inner pickup points or the outers. Both require a lot of fabrication that most aren't willing to do. That aside as long as you don't get them past flat you usually won't see any issues. You can adjust the front to make it work with the new rear. It was a definite improvement. As far as setup goes I don't think you'd have anything that different than an autox or track car. I think you really want something that is close to neutral and easy to drive and it will be adjustable anyway. Watching the D1 guys in Fontana a couple of years ago it seemed like they needed to be able to get under their competition and then control the angle as they were very close. Steering may be the area where you'd diverge from the normal thinking. I'm thinking at high slip angles parallel steering would be better than any ackerman. I'm also wondering if fiddle brakes might be something worth looking at as those would likely have more control when you are really sideways. Cary
Anyone done away with Strut - Spindle pins?
tube80z replied to gearheadstik's topic in Brakes, Wheels, Suspension and Chassis
To clean out the holes I use a steel brush on the end of a drill. Seems to work and is easy and quick. I usually spray a little WD40 or similar on it to help get the gunk out. The last two I took apart definitely galled in this area. I put them on my lathe and used a file to flatten them down. Then loads of anti-seize as they went back together. I think when people tighten the wedge too much it does this. My race car was put back together with 5/8 bolts. When torqued they don't seem to move at all in the strut housing. I usually inspected them a couple of times a year. No wear issues that I could see. Cary -
Recommendations for AutoX Slicks
tube80z replied to heavy85's topic in Brakes, Wheels, Suspension and Chassis
Formula V works wonders too. Use that when the tires start to go off. Cary -
With 13 inch R25As I get two years before they cord. It took a set or two to figure out how to do that. I run two complete sets (8 wheels and tires) and rotate and flip the tires. I have a log that I keep of all running and keep the pairs matched. Yes it's a lot of work to do this but when you have a tight budget it makes all the difference. Typically I run 10 to 12 autoxs and 2 to 3 hillclimbs a year. Proper storage when not in use is important too. Cary -
WOW this would help with making headers or cages....
tube80z replied to 80LS1T's topic in Fabrication / Welding
I don't know about ultimate strength. I've seen fit up with gaps filled on a number of cars and some of those have survived big wrecks. But I can tell you that I did a few basic tests before I started putting my car together. I fit a couple of tubes very well and did a basic torsion test. I fitted some poorly and did the same test. The results for me were that the poor fitup had different torsional strength in one direction versus the other. My guess is that this may have had something to do with the weld wire being stronger/stiffer. I'm not sure. But for my car I tried to get the fitup as good as I could without spending too much time on each tube. Cary -
Dyno with stock damper? I am I taking a risk?
tube80z replied to violacleff's topic in Nissan L6 Forum
Another sign of impending doom is bits of rubber on the hood and inner fenders. I've lost a number of them over the years before moving to better alternatives. And when the bolt gets loose on the front it's a good idea to pull the motor and check the flywheel bolts. You'll sometimes find that those will loosen up too. And vice versa. Cary -
Controversial idea...
tube80z replied to OlderThanMe's topic in Brakes, Wheels, Suspension and Chassis
I don't think increased damping is really the issue for a Z. As far as offroad vehicles go many of the multiple shock installations are to control certain speed ranges. Cary -
The poor man's rear toe-in adjuster
tube80z replied to blueovalz's topic in Brakes, Wheels, Suspension and Chassis
Thanks Jon, that seemed to have jogged the memory. So there's no reason lower cost clevice or solid joints could be used if someone wanted to save more money on this "poor" adjustment. Cary -
I can't remember why heims were used. Since this slides more or less in a straight line couldn't something solid be used? Did we already discuss that and I'm too stupid to find it? And a trick you may or may not know. If you need really fine adjustment use two different thread pitches rather than left and right threading. Cary -
A DIY way to do this is put paper behind the car and shine a light head on and outline the shadow on the paper. Then add up the area on the paper to see the total area. The basic idea is to see how big a hole you're trying to punch in the air. Cary
Jon is right. It's an easy experiment to prove with yarn tuft testing. Cut some pieces and tape it to the hood and see how the air moves with the hood open and closed. I used to think this would help until I watched the yarn go into the engine compartment. On my race car I put holes in the inner fenders in front of the strut tower to allow air to escape. I then added gurney's to my fender flares that could be moved out if I needed more airflow. And in front of the radiator I used a box to help slow the air as it hit the radiator face. Also make sure to use the stock belly pan or add an upgrade. If I wasn't in FP at the time I would have made a duct that came out the hood for the radiator. Louvers in the front section of the hood would probably have a similar effect. Cary
I use the Davies Craig with pump controller on my race car. It seems to work as well as the belt driven pump did for me. I don't know how long the pump is rated for continuous duty. It does make wamring up quicker and is nice to circulate the coolant when it's turned off hot. Cary
Dual master cylinder sizes with 4 psiton calipers
tube80z replied to a topic in Brakes, Wheels, Suspension and Chassis
If you're brakes are pushed on equally by a rod that goes through the brake pedal you might see if you can get a copy of Race and Rally car sourcebook. In it they have a low buck bias adjuster that would be easy to build. Cary
