68
Bondo will probably be fine, but if you want to use something a little better you can use epoxy and filler. I used West Systems low density filler with epoxy (did West System epoxy and others). So far so good. The low density filler is bondo equivalent. They have higher density stuff for joining different sections of fiberglass together with more strength.
First off, the 510 and 240 shafts are not the same size, so that kinda throws a red flag. Second, no matter what material you use, the Z stub axle is still only 1.250" diameter. 300M is not magic. It's a little stronger than 4340, and Modern Motorsports have had those out for a decade and people with a lot less than 1000 hp can break them. So basically I think their hp claim is grossly overrated. Second, if you use their CVs then you're still using the rectangle flange output shafts out of the diff to attach your 1000 hp CV joints to. That's a serious weak link, If you want max hp capability ouf of stock suspension and stub axles, I think Modern Motorsports setup with the 930 CVs and their own 4340 outputs from the diff are a much better choice. That's as good as it gets IMO and should be enough for almost all the people here, but still won't hold down 1000 hp, we know because we've seen them broken with less. http://www.modern-motorsports.com/datsun-240z-280z-complete-cv-axle-conversion.html
NA 3.1L=>head & camshaft questions. No shortcuts, max
JMortensen replied to zredbaron's topic in Nissan L6 Forum
https://youtu.be/dess7cCGXWs -
No pics, just sound. Worked when I tried it. -
I don't want to steal Mark's thunder, so I'll just share this. I did let the F word slip. Sorry, couldn't help it. L6noise.mov -
Would love to see how that works out. Been suggesting it for years. IIRC, you are a drag racer with a ZX. Need to keep off the bumpstops too. Stiffer springs in rear.
Need help with AZC suspension
JMortensen replied to DMfan's topic in Brakes, Wheels, Suspension and Chassis
If you want to keep the wheels and have the car handle its best, set caster to +5, trim fenders. -
To cut or not cut a lowering spring
JMortensen replied to Jaymanbikes's topic in S30 Series - 240z, 260z, 280z
If you get the spring hot (using a cutting torch) you can ruin the temper of the spring. If you cut it with a cutoff wheel there really isn't much downside to it. Lowering springs and stock springs are both springs, and subject to the same issues with heat. Cut 1/2 coil at a time until you get the ride height you want. -
I can't wait to see what it does. -
Dan mentioned the bumpstops, but I'd like to reiterate: Energy Suspension polyurethane bumpstops are not good. They're way too stiff. Get some decent ones from Koni or FatCat Motorsports or someplace else. They should be a foam bumpstop, sometimes they'll even have a spring rate listed. They're taller, and you will engage them more often, but that's OK, because they're not stupid hard like the ES ones. If you're going to section the struts, figure out if you have a 240 or 280 chassis (260s were split). If you have a 240 chassis, you could section the rears an inch or inch and a half to try and even out the travel with the front end. If you have a 280, you can swap 240 insulators (or 280 front insulators) and skip sectioning the tubes in the back.
Arizona Z Car brakes are awesome
JMortensen replied to crapforum's topic in Brakes, Wheels, Suspension and Chassis
Dan is right, and I had the same experience. Had a Toy 4x4 setup in front and 280ZX in rear and did a driving school. One of the things they did was to experience skidding and loss of control, so they had sprinklers on a large section of asphalt and had us go through and stomp the brakes. Was told afterwards that my rears weren't locking up despite the water. Opened my adjustable valve all the way, still wouldn't lock rears. Finally downsized my front calipers back to stock, braking performance improved tremendously. A balanced huge brake system will have the advantage of being able to stop the car over and over without overheating. A balanced stock brake system will stop a lot faster than your mismatched setup. -
SMH... -
Seem to recall it's a Cannon manifold, has the cast balance tube integrated. -
Congrats. Now that car is going to be a serious contender!
Definitely worth selling, in "slap it on and run it" condition it's probably worth $250 - $300. I sold one off of a parts car that hadn't run in 25 years and I got $150 for it.
anyone know what happened to www.atlanticz.ca/zclub/techtips
JMortensen replied to Kamaka Z's topic in Miscellaneous Tech
In the meantime you can use https://archive.org/web/ to find their old pages. I think you'll lose pics. -
Roll bar question ...
JMortensen replied to VitaminZ's topic in Brakes, Wheels, Suspension and Chassis
No, I never used it. It's way too small to hook harnesses to IMO. They did have a cage that built off of that roll bar and was SCCA legal at one time. Real weird door bars. I don't think it would be legal today. Had a front section that bolted onto the roll bar. -
The other thing to check is that the timing marks on the balancer are correct. I was about 17 and working as a mechanic and had a car come in that wouldn't idle unless it had 50 degrees BTDC timing or something ridiculous like that. I screwed around with it for a while, then finally pulled number one spark plug put a pen in the hole and turned the crank until I found where TDC was. Turned out the balancer had separated and the timing marks on the outside of the pulley had moved relative to the inside.
I thought the requirement was for "like" equipment. 5 points on both sides, for example. Or race seats with back supports on both sides, etc. It makes sense in that some people will have a full containment race seat, and use a stock seat with a stock belt on the pass side. An instructor is supposed to get into the car and ride along at much higher risk, because the participant paid $200 to do an HPDE with instruction. It's about safety for driving instructors. -
How does this have anything to do with a HANS device? Perfect for... ??? Are you aware of how a HANS device works? -
They've been making them that way since the 90s, maybe 80s. Long before HANS existed. -
Used to have one of these Autopower roll bars. I thought it was supposed to be a harness bar, and I thought it was too small to use as a harness bar, so I added another tube between the backstays at about the same height to attach the harnesses to. If you can't weld, you can pretty easily buy a piece of DOM tubing, use a coping calculator like this one: http://metalgeek.com/static/cope.pcgi Easy to grind the tube with that calculator then you can have a muffler shop weld it in for you. -
Comments on my plans for NA L28 race engine build
JMortensen replied to turbogrill's topic in Nissan L6 Forum
200 crank hp? I think that's a reasonable goal without porting. -
The strut tower bar actually prevents the strut towers from bending out under cornering. When you take a left turn for example, there is a strong inward force applied via the contact patch at the right front tire. That tries to move the tire inward, and pull the top of the strut outward. So you lose camber under hard cornering. The STB holds everything in place. Since it just holds the original position, it won't affect the static camber one way or the other. It does also prevent the strut towers from moving together when you hit a bump, but that's its much less important function. What matters is what happens when you're turning. You should make your own. For a chump car, I'd just take some tubing and bolt each end to the strut towers. If you use round tubing, crush the ends and drill a hole. If you use square tubing, cut the ends at an angle and drill the hole. You can do the triangulation to the firewall too if desired, wouldn't be too difficult to figure out.
