Mayolives
    6
Everything posted by Mayolives
  1. Alan, It does it's thing in both directions. As to inside wheel more than the outside, I' m not that good to be able to interpolate the info. My guess would be both wheels about the same.
  2. Alan, The shocks are at Koni but I havent got the results. It hops mid corner and on exit when adding power. It bounces and chatters before the curbs are hit. JT has experienced it from within. No one has commedted on a view from outside the car.
  3. I'm using STP 4-Cylinder Oil Treatment. It has a high zddp content and doesn't cost a fortune. I'm not suggesting that it works better than the Comp. Cams product. I suspect their product is well tested and top notch.
  4. Alan, Other than John's "oh ♥♥♥♥" screams coming from the passenger seat, there are no sounds associated with the hopping deal. The outer P car 930 cv shaft ends were touching the frame on compression and after hitting a curb, especially if I had the left set occupied, so I raised the rear end about 3/4". The chattering deal does seam to be more pronounced with extra weight in the other seat, but not much. The Koni tech guy suggested too low tire pressures could be causing it to hop. I normally run my 275-16 Hoosiers at 27/28 lbs cold, and even a bit lower during very hot summer runs. 265-16 710 Kumhos are my favorite and seam to respond better at even lower temperatures.
  5. Hot pepper jelly can be made with most any jelly recipe using peppers to replace the fruit. My latest batch was made with a combination of small Thai peppers, cayenne peppers and the large cow horn peppers. I normally add some red or green food coloring for looks. Cream cheese and crackers with a dollop is this stuff is really fine. Is this Hybrid Z. org? What have we become? Is there a gear head recipe section in the making?
  6. I have received some good information from those who have responded to this thread and from others whom I have contacted. Koni technical gurus have informed me that the 8610 dampers are only adjustable for rebound. Now I have a number of items to physically check on the car but I suspect the Koni dampers are not the culprit that is causing my problem. They all appear to be in good working condition but I have shipped them to Koni to be dynoed. My search is now centered on the suspension components and where they are mounted, the ends of the axles where the go into the differential to see if they may be moving in and out as John C mentioned, binding issues, weather or not the parts are bottoming out, rear toe alignment and lastly, checking the Quaife to see if there could be issues causing it to load and unload improperly. The search is on and I'll share my results as they present themselves.
  7. Most better race car drivers are adept at left foot braking techniques. The benefits are many. However, there are some top notch professional drivers, Mark Martin comes to mind, that reportedly don't left foot brake. Most of us were taught to use the right foot from day one, and getting the other one trained takes a lot of practice.
  8. Mixing and matching t/o bearing related parts is a crap shoot. Stick with one set up and the matching part numbers from Nissan for that set up and you can't go wrong. Do it correct the first time and be done with it. This is by far easier than needing to pull the gear box out again to correct a problem.
  9. The oil from the turbo drain line is not moving with high pressure. Any reasonably substantial connection, either threaded and clamped, will suffice. Also, please make an effort to use better punctuation and grammar when posting. Yes, we are just dumb ass gear heads but we deserve better.
  10. Adjuster On Top End Ring Tacked On Bottom End For Better Fitment Length
  11. Alan, Good to hear from you and before I go any farther, the z car crowd misses you and your hot rod at East Coast events. Hopefully you will get it together soon and come out to play with us. I have contacted Koni but they have yet to respond and I suspect they will also tell me these shocks are only externally adjustable for rebound, just like you have stated. However, thats not what I barganed for and what I was told when I purchased them from Ross at Modern Motorsports. Where do you suggest I send them to be checked? You stated that you were at #400 and #450. Are you refering to spring weights? My car is balanced very well having nearly identical corner weights with full load and driver in place. In that condition it weighs 2560 lbs. Are you suggesting that I go up on my spring weights? Thanks again for your help. I know that you have ben there, done that.
  12. Man..........And I thought that I was fast, back in the day. Thanks for the vid. That car really rocks!
  13. I need advice about how to adjust my Koni 8610 red shock absorbers. Each shock has a small wheel on the top end with holes in it. This wheel can be turned with a small straight tool. I use a very small screw driver or one end of a small allen wrench. The adjuster can be turned about 2 1/2 rotations. According to the adjustment procedure from Koni's site as copied below, that single adjustment knob, as they call it, adjusts both rebound and compression. How can this be? When I adjust the knob in a counter clockwise direction, it definitely softens up the suspension and the opposite happens when I adjust clockwise. It would appear that I am only adjusting the rebound and I would like to adjust both the rebound and the compression. The problem I'm trying to cure is a "chattering" or hopping condition of the whole car when exiting a corner at the limit with the hammer down. These shocks are on my road race car and I'm running 350 and 375 lbs coilover springs, MMS rear adjustable arms, AZC front adjustable arms, Quaife differential with the rest of the alignment set at John Coffee's recommendations. I just don't understand how to set both adjustments with only one adjustment knob. I know that I can read but the instructions are as clear as mud. Any advice from someone with an understanding of how they are to be adjusted or what I can try in order to cure the chattering condition would be greatly appreciated. FROM KONI WEB SITE: Adjustment Procedure 8041, 8042, 8241, 8610, 8641, 8742 Series Rebound Adjustment Procedures Externally Adjustable. These dampers can be adjusted, literally at the turn of a knob, a technique borrowed from Formula-1 racing where KONI dampers have dominated the field for years. One can switch back and forth, in most cases in a matter of seconds, from a comfortable "touring" setting to a more firmer setting for a sporty drive. By means of a knob damping forces can be altered to driving conditions or personal preferences. REBOUND ADJUSTMENT DIRECTION Clockwise = Softer Counter Clockwise = Firmer COMPRESSION ADJUSTMENT DIRECTION Clockwise = Firmer Counter Clockwise = Softer
  14. Defying expectations at Fall Carlisle Hagerty News/ 2009-10-07 Carlisle PA was chock-full of cheap and cheerful cars not often seen at auction, in contrast to Monterey where it has become increasingly difficult to find anything under $50,000. Many of the cars in Pennsylvania appeared in fine shape and ready to enjoy. These were a few of our favorites: 1. 1972 Datsun 240Z: Early Zs offer a ton of looks and performance for the money and are particularly rare on the East Coast, where most of them biodegraded some time during the Ford administration. This one, presented in the right shade of Datsun Persimmon Red, looked to be a nice example still wearing its stock – and really unattractive – wheel covers. It was right on the money, selling at $9,500. Both buyer and seller should be happy with this deal.
  15. Replacing your TB with another, even larger one, without substantially upgrading the rest of your engine, will accomplish nothing. It may even slow you down. Do yourself a favor and research this site for lots of information on this subject.
  16. Aeromotive 11101 pump, 13101 regulator, 12301 & 12304 fuel filters. High quality stuff with a price tag to match. You still only get what you pay for and there is no free lunch being served today.
  17. After spending the weekend at Carolina Motorsports Park with Mark and all the other good people who run with the Tar Heel Sports Car Club, let me be one of the first to say Mark's z car is a piece of work! In addition to being extremely well built and good looking, it's rocket ship fast. Mark is a talented and experienced driver and walked away with top honors (FTD). He now breaths the rare air with those who can get around CMP at the blinding lap time of 1:40. Trust me, there are only a few cars, other than open wheelers, who can do this. If only I could find a few more seconds hidden somewhere in my car, I might be able to run with him again. Congratulations Mark. You are the man!
  18. Too much!....That's really some dangerous stuff. Kids, don't try this at home.
  19. The proportioning valve is relatively sensitive and by dialing the valve all the way in one direction, you should be locking the front brakes not just reducing the input to the rears. What are you using for master cylinders? Do you have separate ones for front and rear? Was the valve new when installed? Have you tried to re-bleed the brakes?
  20. I'm not a fan of fast rag tops, but your vette is really nice and looks like a lot of pedel to the metal fun.
  21. MB has be making bad ass cars for a long time and their ongoing involvement in motorsports is well documented. My 1993 500E rocks.
  22. Austin, Your car is really nice. I saw it some time ago, when we met at the wind tunnel test facility. Since then you have made many improvements and I'm sure it's even nicer today than two years ago. Many gear heads are infected with your obvious perfectionism. I have a dose of it and it drives me crazy at times. A true project car, like yours, is NEVER completed and can always be improved. I could not depart with my car (cars) unless I absolutely had to for financial, reasons, etc. But if circumstances allowe, I will always find another project to undertake. Yes, its important to keep your life in balance, but I'm not sure that one can devote too much energy to something that makes you happy and keeps you out of other, worse traps that can rob your life and times. These are my ramblings to add to your thoughts. You're a smart guy and will make the correct decision.
  23. A better way to determine which heat range works best for your particular set up would be "reading" the plug after running it for a while. There are many good articles available on the subject both here on HZ and the web.
