Mayolives
    6
Everything posted by Mayolives
  1. Nice car! The video gives me the "I want one to daily drive" feelings. Long live the z car.
  2. QUOTE: "I am going more for function over form." What am I missing here? If you are stripping it, i.e.; removing it, why would you put the undercoat back on the car? If you are repairing rust or doing some kind of body work at the wheel well area, I would re undercoat it with the rattle can stuff from an auto parts store. If, on the other hand, you are removing it to lighten your can, repainting will do the job.
  3. I agree with Mark. This seller is good to do business with and you can't go wrong with the suede wheel. I purchased a Sparco adapter and liked it better that the less expensive other ones offered due to the Sparco piece being tightly splined while many of the others are 5 sided and feel loose and have play in them when installed.
  4. My 03 Dodge 2wd is a dully and has an auto transmission. If I drive very conservatively at our just above posted speed limits on the interstate, I can get about 20 mpg. When running at 75 mph the mileage drops to about 16 mpg and when towing my 24 foot, V nose enclosed trailer with z car inside, the mileage drops by about 5 mpg. I have about 100K on the clock and with the exception of a minor transmission problem, the truck has been great. I love my diesel!
  5. This is an intriguing thread. All the ingretients are present. A new track car build. Help from your father who raced. Topped off by trying to locate the original car your dad owned. Please keep us up to date!
  6. Yes, the circlips stay in the differential. I needed to install them after the Quaife people forgot. I gently and gingerly slid them in place with a long screwdriver. It needs to be done with a "watchmaker's" precision.
  7. Looks like you really got your money's worth! I would jump on that deal.
  8. Alan, I had to cancel my trip to VIR due to a transmission problem with my truck. (speed sensor) Apparently it rained up there for most of the day so I really didn't miss much. I hope to take the car over to CMP later this month and test the new setup.
  9. Amboy Dukes: Journey to the Centre of the Mind.............Truly one of my favorite classic tunes. Yea, I'm old. Rock on!
  10. With the engine at TDC, the first two cam lobes should be pointed like this.
  11. Mark, Although I haven't had the opportunity to try it yet, I've been told that both front Koni 8611 dampers can be adjusted in about half an hour. Knowing how Murphy's law normally applies when I need to get things done at the track, that easy to do, remove and replace a couple of bolts, could turn into a not so easy to do, pain in the a## deal. I like your idea and plan on stealing it! Thanks again.
  12. After several seasons of chasing summer overheating problems on my track car, I removed my front mounted Setrab oil cooler and replaced it with a C&R oil to water heat exchanger. I mounted the new piece on the right side of the engine below the spark plugs for ease of plumbing and it has helped to lower the coolant temperatures considerably and the oil temperature has stayed about the same. By removing the oil cooler, that had been mounted between the intercooler and the radiator, the incoming air has one less thing to pass through, and subsequently now keeps things a bit cooler.
  13. QUOTE: None of that applies to anyone here on this message board because our ham fisted driving masks the lap time difference. Johnc is correct again. Few of us will ever experience the true potential of what our cars are capable of doing on the track. My "ham fisted" driving is always in the way
  14. Coolant leaks, especially external ones, are easy to find with a little patience and a pressure tester. Don't over do the pressure when you pump it up. Ten pounds should do the trick. If it's internal, you will need to dig a little deeper and ask better, and more specific questions.
  15. Hopefully, I have discovered the cause of the chattering and hoping issues I have been experiencing. One of the rear 8610 dampers (RR) was bad and not functioning on the compression side. Also, I have installed Koni 8611 dampers that will allow me to adjust both rebound and compression. Thank you JohnC, at Beta Motorsports, for the fast service and installation advice. I'll be able to test the new setup, that includes lowering the rear spring from 350 lbs to 325 lbs, next Monday during the Asphalt Ventures track day at VIR. Yahoo. Alan, Thanks for the pictures. Now I remember seeing your setup and braces, but it was years ago and at that time I probably didn't know what I was looking at.
  16. It would appear that you have found a good deal. I'm not sure what your plans are for the car, but IMHO, chase to body problems first. The rest will be easier.
  17. I haven't used the A6 Hoosier but have used R6 (275-16)and Kumho V710 (265-16), both purchased new and for road course use. As stated above, the A6 have the reputation of not lasting through many heat cycles and are normally used for autocross applications. I get about the same lap times with either tire when new. After a few heat cycles, the Hoosiers may still look good but are really slick and lap times go up. The Kumho V710, on my car, will last longer, stay softer and faster, through more heat cycles that the Hoosier tire.
  18. jnddragracing...........QUOTE:Max Torque: 605.20 Rear Wheel Man..........I would kill for that kind of torque in a road race z car. I could even keep up with the real fast guys like JT1, Mark and TitaniumZ. te he he
  19. The FSM has an excellent step by step guide for the job. Read it a few times and "puppy" along with it. You can't go wrong. There are a few hidden bolts here and there but the manual points them out. Pay particular attention to correctly dealing with the timing chain and how to hold it in place or you will create a few more hours of additional work when you reassemble the engine. Buy your parts from Nissan and don't cheep out on a little better prices from the auto parts store. I would suggest having the head checked out at a good machine shop when you remove it. Take your time and ask intelligent questions if you get stuck. It aint no biggie.
  20. Quote: I run some additional tubes with rod ends from the frame rail down close to where the back of the control arm bolts to the plates coming down from the top. They come in at about a 45 degree angle when looking in from the rear. I did this to more firmly lock the whole assembly in place side to side. Alan, Do you have any pictures of the support tubes you added? I don't remember seeing them before. QUOTE: How long have you been running the new halfshaft with the 930 P car cv's? Did this start after the new halfshafts? Mark, The shafts have been in there for a while. I converted to the 930 "P" car ends so that I could easily find parts when needed. The Nissan turbo four bolt ends are becoming scarce. The hopping deal started before I changed to the new setup.
  21. Alan, I normally run a bar but removed it at CMP when working to find the cause of this problem. It didn't help the chattering but I sure new that it was missing. I plan to put the bar back on the car.
