Mayolives
6
Everything posted by Mayolives
Phantom.....To my way of thinking; worn valve guides or valve seals should produce smoke at start up. I have none. Is my logic correct? There is no water in the oil. If my head gasket was bad, wouldn't that have show up during my leak down test? When I did the leak down, I purposly pumped about 125 psi into each cylinder and could not make the water move in the radiator. I would think that much pressure should have exposed any head leak or any crack in the block that would push water into the jackets. Am I missing something here? JT1.......Do I need to remove my head in order to check the guides and seals? Is there any other way. I'm really trying to avoid that. Just my lazy, slack ass speaking to me.
grumpyvette.........QUOTE "on deceleration only tends to indicate valve seals, or worn valve guides" I did another hot compression test today with all cylinder around 150 plus or minus 3 points. So that's all good. Also, I did a leak down test on all cylinders and all are nearly the same. This tests should rule out problems with rings, guides, valve seals and head gasket. I bit the bullet on removed the turbo system and found a very, very small amount of residue in the downpipe so I will have the seals replaced in the Garrett and try it again along with retuning the tech 3r. In my earlier post I mentioned using some coolant. Could I be leaking coolant through the turbo and that causing the white smoke? My cooling system uses a 25 psi cap. During the leak down tests, I put compressed air to each cylinder and could not make the water in the radiator move or bubble. TonyD.........You were correct about an exhaust leak causing the bad breathing condition in the cabin. The gasket between the Garrett and the downpipe was gone with the wind!
Tony D quote "1/4 a quart over a three-day track event? That's not oil consumption." Yes, I'm not concerned about the amount of oil being consumed. I know that's normal. Perhaps I should have said more about the visible smoke. It's more than a puff. It now is more like a cloud. Enough to cause a black flag last weekend because the corner workers thought that I might be putting oil on the track. They did allow me to run after I assured them that I wasn't leaking any oil. I have a catch breather system plumbed with a -6 line from the valve cover to a can with small top breather/filter that sets on the fire wall. I have another one plumbed with a -10 coming from the driver's side of the block to a can with small top filter/breather. The one from the valve cover had about an inch of blow-by oil in it but not nearly full. The lower can was empty. Tony, you refered to an "oil mist eliminator on the block PCV vent before it goes to the suction line of the turbo" What is that? Please tell me more. Thanks, Tom.
cygnusx1...............I do use some water due to radiator (S&R) being a little undersized. I have always pushed water into my oversized catch can located under the spoiler. I don't' think the smoke is from coolant because it seams to lay in the air and not dissipate quickly like water vapor normally does. Also, I'm using Wilwood brake master and clutch cylinders without a brake booster so the smoke can't be from brake fluid.
DC Water Jet's 202mph Z-Car
Mayolives replied to Tony D's topic in Windtunnel Test Results and Analysis
Tony, What width tires are typically used on these cars? They are really "tucked" under the body work, especially the front. Man, that thing looks like it's going 200 when setting still! I just can't imagine it going faster without the slick front end shown in the 07 pictures. -
My track car has a two year old turbo engine with 2380 all track miles on the clock. I'm blowing whitest smoke only on deceleration. No smoke on start up or acceleration. Compression ranges from 148 to 143 on all six. Oil consumption is slight using only 1/4 quart at a recent three day track event, which is normal consumption since build. Turbo is a GT35-R and I run 18# boost at maximum. Also, I'm using Electromotive Tech3R fuel and engine management with all their bells and whistles except the cold start fuel enrichment part. So where is the smoke coming from? I'm getting smoke in the cabin that burns my eyes. Turbo oil seal? Any thoughts would be appreciated.
The answer lies in the old adage about risk verses reward and what's at risk for YOU and YOU only! Think about it. Can YOU risk taking the chance and then being able to be happy with any result? The decision is easy. Weigh the effort required to properly disassemble and clean your head against the effort required to repair what could happen if you decide not to take a closer look. Aint it a bitch!
Wilwood caliper damage (PICS)
Mayolives replied to mark's topic in Brakes, Wheels, Suspension and Chassis
Woo now. I'm in the VIR 2:10 club with no problem whatsoever with Dave's 6 pods on the front and 4 pod on the rears. I've been running Wilwood "H" pads for the last year with at least 20 track days on them and they still have a way to go. Mark, I don't know whast going on with your setup and would defer to Wilwood tech support and have a conversation with Dave to get their take on the situation. -
SKIB....After studying the tables found at OREGON ADMINISTRATIVE RULES, I seriously doubt that your car is actually illegal. Have the sound level checked in accordance with the guidelines outlined in the tables and if I'm correct, plead not guilty and show the results to the court. Those sound levels are apparently the law in your state and the decision of your car being too loud is NOT up to the desecration of the police. Let us know how it turns out.
Johnc, Afetr looking at Dow's web site regarding IMPAXX energy absorption foam and I think a number of us are looking forward to hearing more about it. Hopefully you will share information about IMPAXX and how we could use it. Most of us are making plans to go fast without providing adequate protection from the "what ifs" that can ruin the day.
How is the Economy affecting your Hybrid Project?
Mayolives replied to JustinOlson's topic in Non Tech Board
Real estate and residential construction have been my livelihood for many years. Needless to say, my income has taken a big hit and future projections aren't too bright here on the Beach. I have curbed my spending habits and look closely at what is essential and what isn't. My race car will continue to be meticulously maintained but upgrades are mostly on hold until the black cloud passes. However I will add, the longer I live, the more I know there is wisdom in the saying, "all things will pass." My point? Things WILL get better with the passage of time. Hang in there and keep z faith. -
What should be my "plan of attack" with building the Z
Mayolives replied to icapture's topic in S30 Series - 240z, 260z, 280z
It's the same old story and sorry to say, but it all boils down to dollars and cents. The body work should come first but if your wallet can't stand it, there's only one alternative. SAFETY first and bling thereafter. Think about how to stop a fast car and make it handle. That's my two cents worth. -
Some good advice above about replacing vac lines. I found a bad one under the charcoal canister that, when replaced, really helped my "extremely overwhelming," as you put it, auto climate control system. These systems can be a real head banger.
Rubber Bands.....................I'm going to be nice because you are a newby. There is lots of good information here. Do some reading. Do some searching. Then if you feel the need, ask a more definitive or clearly defined and formulated question.
Truck freight is normally the least expensive. You would need to secure your clean, drip free, plastic wrapped engine to a pallet and deliver it to shipping terminal. It would also need to be picked up at the destination terminal. It worked for me.
Help: engine does not keep idle unless key turned
Mayolives replied to Hailstorm's topic in Nissan L6 Forum
IMHO, your ignition switch needs to be replaced. -
Great Vid!!!!!!!!!!!!!!!!!
My Complete LS1 Install Documemtation with Pics
Mayolives replied to a topic in Gen III & IV Chevy V8Z Tech Board
Please send a copy to mayolives@aol.com. Thanks, Tom. -
Easy John, are you referring to Red Bird's Bling? Just joking. But I agree with your comments about the installation above. I have had fuel starvation problems, usually happening after hard braking followed by a right had corner, i.e., turn one at VIR. I installed a .5 gallon surge tank on my firewall under the bracing. It's feed directly from the pump into the side, top fitting on the tank and then out the bottom to supply the fuel rail. I tested last month at Carolina Motorsports Park with no apparent starvation. I do have safety concerns due to having it in the engine bay and may move it to the rear whenever I decide the best way to fit it. Here are a couple of pictures of my installation. I did it as "blingless" as I could. (The black AN hose, "dangling" in the picture, is the turbo cooling line that I disconnected for some other project I'm attempting to complete.)
Yasin, I had a similar problem when trying to fire my new engine after we installed it. I even had the factory Electromotive rep. on hand to help solve the mystery. Timing, fuel pressure, injectors firing, etc. were spot on. I finally suggested that we try feeding it some gas manually. Lo and behold it fired up and all was good! Yes, it sounds "off the wall", but it worked for me.
http://hosetechniques.com does not offer radiator hose for our car's sizes.
Any recommendations for a silicone radiator hose supplier?
Phil Hill, Racing Legend, Dead At 81
Earl's performance plumbing and advice when you need it can be found at http://www.anplumbing.com
