Mayolives
    6
Everything posted by Mayolives
  1. Justin, I'm always reluctant to recommend anything. My car sets low and the 10" springs work for me. Good luck!
  2. QUOTE: Avoid using a citrus based degreaser on aluminum. A simple way I've degreased a head is to mostly fill a 5 gallon bucket with Simple Green and stick the head in the bucket for a couple days, turning it 180 degrees on day 2. __________________ John Coffey johnc@betamotorsports.com BetaMotorsports, LLC
  3. I believe it was John C that recommended using Simple Green and a five gallon bucket. I submersed one end of a P90 into it and the other end the next day with very good results. After the bath I rinsed it with water.
  4. Justin, I needed to exchange my 8" for 10" after running out of adjustment on the front. My Ground Control plates are welded,struts are sectioned and spring rates are 350/375.
  5. THK Powergrid is a vendor that advertises in Grassroots Motorsports magazine. (http://www.powergridinc.com) They make adjustable end links for bars. I talked with them months ago and was told that links could be made for my track car if I would supply them with dimensions. Somewhere between my busy life and my lack of knowledge as to how to adjust them for my needs, has lead me to not contacting them again. Perhaps someone with real setup knowledge will chime in and describe the merits of having the ability to adjust the end links.
  6. I removed my 500e from storage today. It had a half tank of 93 octane that is at least 18 months old. After dealing with a dead battery, it started up, revved fine and idled smooth. I drove it for more than an hour and it ran just like it should.
  7. BJHINES....Ding Ding..........Thanks John. Good information.
  8. I normally don't even read "sappy" threads, especially on Hybridz. But here I am reading and responding, twenty some odd years after meeting my lady and love of my life that happened at first site. There have been numerous others since her, but all have had engines, rubber to meet the road, occasionally left me down and were comparatively, short lived love affairs.
  9. John, All your work looks very nice. Tic..Tock...........Let's get that thing together soon. We need another zzzzzzzzmonster in the paddock. Any chance you will have ut ready for the THSCC event at CMP?
  10. Remove the inside nut and then use a slide hammer. Most auto parts stores will allow you to borrow one if you need to.
  11. QUOTE "The one question I have is what are the Wilwood rotor numbers so that we can purchase replacements from say Summit racing? I believe they are UL-32 rotors and the part numbers are 160-5845 and 160-5846 but just not sure. What do you all say?" You can easily measure and then compare you findings with Wilwood's published dimensions and then determine which part you have. However, Arizona Z Car, can supply you with any needed replacement parts at a price that is similar to the other suppliers you mentioned. Why not "dance with the one who brung you" ? Dave has always come through for me!
  12. A few days ago I had a conversation concerning this subject with Roddy at Speed Design Inc. (titaniumZ). I always respect his input concerning aerodynamics and race car fabrication in general. I ask his opinion about the effectiveness of the 2 1/2" tall roof strips that run lengthwise on the roof of car of tomorrow and more importantly, could I install roof stripes on my race car to improve aerodynamics. Apparently, NASCAR mandates these stripes because wind tunnel test would suggest they help prevent the car from flipping when turned sideways during a spin or accident. However, Roddy thought they may help to clean up the air and prevent "spill-over" which may provide more down force on the s30. So, are the drip rails a mini version of the COT's roof strips? Could they provide more stability at speed? My guess would be an added roof strip could work well on a drag race car traveling in a straight line but could possibly slow down a road course car that maneuvered lots of corners. Without wind tunnel testing, all the above is merely hot air and "guess-tamation" on my part.
  13. I have Arizona's six piston setup on the front and their four pistons for the rear of my track car. They have been, without a question, rock solid and predictable at the limit with aggressive Wilwood pads. I'm even happy with rotor and pad longevity.
  14. QUOTE "there seams to be a major design flaw" Please tell us more about the flaw.
  15. I like your story and perhaps it will encourage someone here. Apparently you have recently joined the forum, but man..............you need to work on spelling and punctuation. Reading your post was annoying as hell!
  16. I like it and my thanks to MSA for support of the sometime unloved zx. My 82 would look real good with that peice installed!
  17. What kind of power will you be making? If you plan to make a bunch, I would plan on running larger feeder and return lines. The pump manufacturer can recommend sizes for you. I running a -8 from the Aeromotive pump and a -6 for the return. (http://www.aeromotiveinc.com)
  18. Absolutely gorgeous work. Like someone said above, Ill be looking at these pictures for the next few days. Those cars make mine look like junk. Sorry, Titaniumz, I didn't mean that.
  19. Roostmonkey................What is the capacity of your surge tank?
  20. I've been using AZC's five lug alumnium race hubs on my track car for a couple of years. I originally bought them because they were alumnium and would help to lower the rotating mass number. They are a quality part but I did manage to spin a few of the long wheel studs in the hubs. They are on a road race car and see many tire/wheel changes. I reinstalled new studs and set them in JB Weld and have had no problems since. I'll point out that I also spun a few of the rear wheel studs in the steel axles. I then spot welded those in place. This problem could have been caused by poor splines on the ARP studs. But........All is well that ends well.
  21. I daily drive my 82ZXT when I don't need my diesel drinking Dodge. It's a GL model with some suspension mods, upgraded headlights, better rotors and brake shoes with performance tires. With the exception of the quirky air conditioning system, It's a fun car to drive and doesn't beat you up too bad like my 280z cars did. It's not a Mercedes but it's leather seats are reasonably comfortable, it's fast and gets mid to upper 20 something mpg when I can keep my foot from making boost.
