It is a "at what price" vs "do I need it" issue. A choice!
I use synthetics because I have seen the difference quality lubricants make in 25 years of turning wrenches and playing in motorsports.
I spend good money to put something together right; I will spend good money to protect it.
Don’t forget about air & oil filtration, fuel dilution and moisture.
All of these and more play a very important part in any lubricants serviceable life.
Educate yourself so you can make informed choices.
One thing to look at is full synthetics are designed in a lab to operate within certain parameters.
Petroleum oils / semi-synthetics are pumped from the ground and chemicals added so it can be a useable lubricant.
Not all lubes are made the same.
There is a simple & informative test you can do on what ever lubes you choose to see how they hold up.
An oil analysis
The tests return a good amount of data as to what’s going on inside the engine, not just the properties of the lubes.
Do a test at the beginning & end of your oil usage to get good start & end data.
You might even find some other issues with your equipment.
