NewZed
    71
Everything posted by NewZed
  1. Post up the instructions for the Speedhut gauge. The white wire on the right of your picture, with the loop in it, is the one that the current passes through to the ignition system. It's the current that causes the 240Z tach needle to move. But there is also a voltage sensing tach that just has a wire from the negative post of the coil that terminates at the tach. You need to know what type Speedhut is using. Here's a bigger diagram than the tiny snippet you posted. https://www.classiczcars.com/files/file/1-240z-wiring-diagram/
  2. Here's the 71 wiring diagram from the Owners' Manual. It's a green wire with a 20 amp fuse. Finding it and using it is discussed off and on over the years on various forums.
  3. I wonder why somebody hasn't designed a solid replacement. All steel.
  4. You guys are right about the stock parts. Crushing the control arm ears would not happen. With those parts it's just the simpel safety factor of breaking the bolt and having it slide out. I'm still a fan of thinking things through to the extent that a person can. It's more than just "throw out the spindle pin and slap a 5/8" bolt in there instead". With the PU bushings that most people install when they remove their spindle pin the control arm ends slide forward and backward on the bushing. Does the nut and bolt need a proper sized washer to support the bushing or control arm surface? What size should it be? Worth thinking about. Most of the PU bushings are too thick to fit in the gap. Should they be trimmed or should the control arms be spread to squeeze it in there? Why didn't the PU guys get the PU part right, so that it fits? Is the sleeve that they supply right? The first guy's post was about the InvincibleExtremes setup. Might be far from the crusty old stock Nissan bonded rubber parts. You'd really have to see the parts to know if the Nissan design is being followed. There's an assumption that he does do but so far it doesn't look like anyone has actually got theirs together yet.
  5. The control arm will be moving in relation to the hub casting as the suspension moves. The bolt and nut will be clamping the "ears" of the arms against the hub surfaces. Regardless of whether the arm ears deflect enough to make the surfaces contact my point is that the bolt is an axle, or think of it as two separate axles, one on each end. There is rotation around each of those axles. Again, over-thinking, but that's part of the point of a forum. To be clear though, I think that gnosez is talking about the simple act of replacing the spindle pin with a 5/8" bolt, no mono-balls or rod ends. You might be talking about a different application.
  6. Torque specs are set to get proper clamping force from the nut and bolt. But this application uses the bolt as an axle. It's not meant to clamp. You'll be clamping down on a moving bearing surface. I don't think the common torque specs apply.
  7. 1976 has a switch in the AFM that controls the fuel pump relay. When you start the engine cold the idle speed is higher and air flow keeps the switch closed. As idle speed drops air flow does too and the switch might be closing. You can check that possibility by taking the black cover off of the side of the AFM and manipulating the counterweight by hand. Ot you can just watch the switch, it is just two very small contact points attached to a piece of stiff wire. You can bend the wire to adjust the switch if needed. Another check is to just turn up the idle RPM and see if that makes a difference to keep the pump running. Here's a picture. Don't mess with any of the things shown in the link, he's showing how to fix an AFM that has been messed with. https://www.atlanticz.ca/zclub/techtips/afm/index.html
  8. Here's some overthinking - it should really be a 16mm bolt.
  9. I was responding more to gnosez's comment about "over-thinking". He has a tone of superiority, but really he's just a guy who decided to use a bolt, apparently because it's easier and cheaper. Nothing really superior about that. It's just a choice. The whole point of these forums is to generate things to think about, but the value of those things is opinion.
  10. Most of the discussion about the spindle pin and locking bolt is about why Nissan did things that way. And, as often mentioned, just because something didn't fail doesn't mean it's better. There are many areas on the Z where you could just use a cable or a chain or drill a hole and use a bolt. In the end the car owner needs to know what they're trying accomplish and take responsibility. The internet is full of all kinds of starting points to think about but it can't decide for you no matter how many posts are posted.
  11. It's the cost of parts needed to bring up the value that will get you. Nickels and dimes. Mustangs and Chevys have a huge aftermarket network making parts. The 280ZX, not so much. If you're really thinking about investment then a simple spreadsheet of costs should throw some light on it. Here's a couple of web sites that sells ZX parts, for starters. You could probably just get it running and clean it up for a small profit. But restoration will be expensive. http://www.zcarparts.com/ https://zcardepot.com/collections/280zx Look at the quality versus price on your future competition and estimate how much you will have to spend to get there. Good luck. https://bringatrailer.com/datsun/280zx/
  12. You can almost certainly get it running but almost nobody makes a profit restoring these old cars. Get it running >>> yes, make a profit >>> not likely.
  13. Actually, he does have a kit. I didn't go far enough down the page. https://zcardepot.com/products/r200-differential-rebuild-bearing-seal-kit-280z-280zx-300zx?_pos=61&_sid=f9b96a786&_ss=r
  14. I've never seen a kit. This guy, below, has parts you might need. They're pretty durable and don't often even need rebuilding. The Factory Service Manual has a section on rebuilding the diff. https://zcardepot.com/search?q=differential&type=product
  15. https://zcardepot.com/products/oil-pump-drive-spindle-oem-280zx-turbo-81-83?_pos=17&_sid=d035dc3a5&_ss=r
  16. I always thought that they were connected but never figured out exactly how. I would have put this in the other post but there is no Edit function.
  17. That's not good. The BrokenKitty site is still active. http://www.brokenkitty.com/index.htm
  18. Does it have stock drums in back, and disc up front? Might be that the PO went with a different MC bore if he did some brake mods. Since the MC is not what came on the car it might be that it's already "newish". It looks new. If things work right, maybe just leave it alone.
  19. Looks like you're missing the spacer/adapter also that goes between the booster and MC. https://zcardepot.com/products/brake-master-cylinder-booster-aluminum-spacer-plate-240z-260z-280z?variant=19279175647345&currency=USD&utm_source=google&utm_medium=cpc&utm_campaign=google+shopping&gclid=CjwKCAiAyc2BBhAaEiwA44-wW3ZsP-H-fUnyxq-qimqBGJrRq33HmeIh_yfhvkh2NYyYrS1l8tYQjRoC0U8QAvD_BwE
  20. This is the 280Z with the 3UZ swap? You should put your car info in a sig or just mention it every time. Looks like the PO had some skills and made a different master cylinder work. That stack of washers on the top bolt is a clue. Try to find out if the booster is correct for the car and look at 280Z master cylinders.
  21. Don't overlook the LSX engines. Fairly lightweight and powerful. And transmissions. That's the other spendy part about more power and different engines. And rear end. Big torque and sticky tires and you'll want more back there.
  22. If you browse around you'll find that the "turbo" motor is really only different in that it uses the P90 head, which has no liners in the exhaust ports, a J pipe, and a turbo exhaust manifold. People have bolted the turbo parts on to either of the other NA engines and made them work just fine using aftermarket engine management. If you want to make 350+ HP you'll need aftermarket engine management. So, all you really need are the J pipe and the exhaust manifold from a 280ZX. There might even be aftermarket suppliers for those parts. That's how I'd break it down. Just see what you can find and started piecing things together. If you find a whole car and the price is right, why not? The rest depends on how deep you plan to go in to the engine. Too many possibilities to make a recommendation. Here's a member who has some opinions. But, if you're like most people who start a project your plans will change along the way. you just need a jump off point.
  23. Here's some stuff. Still relevant, but there's newer engine management now. It came from here: https://forums.hybridz.org/forum/90-l-series/
  24. It sleeps with the Edit function, apparently. And the fishes.
