NewZed
70
Everything posted by NewZed
brake calipers not properly working
NewZed replied to Danochumongs's topic in S30 Series - 240z, 260z, 280z
One down. OReilly Auto is not known for the high quality of the parts they sell. Take the MC back and get a refund or get another and try again. The pedal can't go to the floor unless the seals stop sealing, therefore... Throw a few capital letters and some punctuation in to your posts also, it will improve your thought processes and make these types of problems much easier to solve. It's like exercise for the brain. (edited for mellowness). -
More amps (amperes, not amplifiers).
The pedal slams to the floor because, probably, your master cylinder seals are blown. Was the "new" MC old? Corrosion happens and will destroy the seals. The brake light goes on if there's a pressure differential between front and back. There might still be a big air bubble in your lines. Check that the bleed valve for the calipers is on top, not on the bottom. The calipers are reversible. -
That Dirty Jobs guy is everywhere.
PCV tube. You don't want any coolant going in there.
Did you measure voltage at the starter or are you assuming there's no power because it doesn't turn? There's a lot of basics missing here, like the battery's charge level, condition of the battery posts, any actual voltage measurements, etc. Sounds like you just have a dead battery or dirty terminals.
The part that's not clear is what you mean when you say the pump doesn't work. If the pump turns, then the problem is most likely not electrical. But you're theorizing, above, about blocked fuel lines which implies that the pump is turning but no fuel is flowing. In your first post you said that the pump hasn't "fired" since you parked the car. What does "fired" mean? You said that the ground is connected, but you didn't say that you confirmed it's actually grounded, electrically. If you have 12 volts at the positive terminal, take a separate jumper or piece of wire and make sure that the negative terminal is grounded back to the battery. If the pump doesn't turn, don't worry about blocked fuel lines. You'll have to listen to the pump to find out if the pump is turning, or measure the voltage drop across the terminals like Domzs suggested. Listening is easier.
transmissions that work with our engines
NewZed replied to Rusty Bomb's topic in Gen I & II Chevy V8 Tech Board
Might get better information from a Chevy V8 forum. -
http://forums.hybridz.org/index.php/topic/19918-the-ultimate-turbo-faqbeginners-guide/
'77 Z, switching some things up with a new motor
NewZed replied to zacward's topic in S30 Series - 240z, 260z, 280z
Thought you might have a second pickup coil and wonder how it gets used. No biggy, enjoy the old EFI system. -
Maybe there should be a separate "Automotive 101" sub-forum. Then the "serious" forums won't get muddied up, but there will be a spot for the simple questions. Pinned at the top of the 101 forum could be the links to the xenon sites for FSMs, and various 101 type links, like "how an alternator works" and similar. Simple posts can get moved to 101 instead of exiled to the Tool Shed. Win-win.
All of the sensors are described in the FSM. Some have interesting functions. Have you looked under your distributor cap yet? -
I miss the Tool Shed. It doesn't seem to be getting much use any more.
(Edited several times after staring at the drawing) The attached picture suggests that full droop actually lengthens the half-shaft and suspension compression shortens the shafts (I'm using "half-shaft" to describe both styles, CV and u-joint). This might explain a few things. A car lowered to allow compression beyond the factory design could bind the shafts. The drawing is from the 1976 RA chapter, but I assume that the 240Zs are the same. Someone with some drawing skills could probably calculate the amount of movement based on the arcs of travel of the link and the axle. More food for thought - It could be that Nissan designed the loose rubber mounting on the differential to allow sideways movement under extreme suspension compression to avoid binding. I've always wondered why the mustache bar rubber was so loose.
The attached picture suggests that full droop actually lengthens the half-shaft and suspension compression shortens the shafts (I'm using "half-shaft" to describe both styles, CV and u-joint). This might explain a few things. A car lowered to allow compression beyond the factory design could bind the shafts. It could also be that Nissan designed the loose rubber mounting on the differential to allow sideways movement under extreme suspension compression. The drawing is from the 1976 RA chapter, but I assume that the 240Zs are the same. Someone with some drawing skills could probably calculate the amount of movement based on the arcs of travel of the link and the axle.
Pics are too tiny. But there are several ways to wire in the internally regulated alternators, if it charges and the charge lamp works and the battery doesn't drain itself it's probably "right". Have you checked output? The amperage at idle of the stock 60 amp alternator is on the edge even when all of the electrical connections are clean. Keep cleaning connections, everywhere, including grounds, and the dip will get smaller and smaller. Start with the fusible links. It is possible to make a stock alternator work with no dimming. But after 35 years the small corrosion on every connection adds up to some sizable wasted amps. Relays on the light circuits help also and will save your combination switches.
About 1/3 to 1/2 way down JMortensen's "Differential/..." page there is a comment about the NA 300ZX CV shafts being too long. Sounds like you got a pair of those. There's also a comment about the six bolt adapter at MM. I'm fairly certain that the six bolt pattern for the Z31 NA is the same as the six bolt pattern for the S130. You could get some 280ZX CV half-shafts and they should fit your MM adapters and be the right length. The 280ZX turbos and some NA cars came with the CV shafts. It does get confusing, especially if you start looking at hybrid CV shafts, hub options and differential setups. Lots of options and none very easy. http://forums.hybridz.org/index.php/topic/49194-differential-cv-lsd-hp-torque-r160-r180-r200-r230-diff-mount/ From the page: "The CV shafts first made their appearance in the Z line with the 280ZXT. This car got the tripod style CVs which have 3 large rollers arranged 120 degrees apart from each other. The 280ZXT CV’s are more durable than the halfshafts and are a good upgrade. www.modern-motorsports.com makes an adapter which allows the CV shaft to be bolted to the companion flange on the stub axle (the wheel side connection for the halfshaft). The 280ZXT CV plugs into an open or CLSD R200. These CV joints have bulky housings and can interfere with rear swaybar end links. Some have simply put smaller end links on to get around this issue. 280ZXT CV shafts: Resized to 20% (was 512 x 384) - Click image to enlarge The Z31 got a different, stronger CV shaft. In addition to being stronger, the housing for the CV joint is smaller in diameter, and this means that it interferes with sway bar end links less. There are two different Z31 CV shafts. The normally aspirated Z31 uses a 6 bolt shaft. For whatever reason, these shafts are too long to be used in the S30 chassis. Don’t get NA Z31 shafts. The Z31 turbo shafts have 4 bolts, and they are the right size to fit into the S30, using companion flange adapters from www.modern-motorsports.com."
Most people spend days, months or years trying to figure their engine problems out. You are outside the lines with the turbo on the NA EFI system which may be why you didn't get much feedback. It's the "asking for trouble, you're on your own" path. Plus reporting voltages for the AFM and CTS test doesn't really mean anything since the tests describe measuring resistance. I'm not a turbo guy but the fact that you're boosting early seems to suggest a problem with the turbo and boost control (of course)(Edit - had written something else but it was backward thinking). Reporting RPM instead of MPH would probably be more useful too.
Which part of Oregon are you in and how far are you willing to drive. If used is okay... - http://www.picknpull.com/check_inventory.aspx?Address=97225&Lat=45.506451&Lng=-122.775622&Make=Datsun&Model=280&Distance=200 http://portland.craigslist.org/clc/pts/3349040887.html
The R200's generally are loose and have some play. 2 degrees doesn't sound like much at all. I assume that you mean you can rotate a half shaft 2 degrees of play. Loose u-joints will make a noise also, look for rust around the bearing seals. Loose diff mount. Loose lug nuts. Loose mustache bar nuts. Loose half-shaft bolts. Loose strut mounts. Something loose rolling around in the tool compartments behind the seats. These have all been implicated in noise from the rear. Autocross isn't supposed to be that hard on the driveline is it? It's not drag-racing.
My point wasn't that you would get a ticket for not registering but that you could get pulled over for the out-of-state plates so the officer could ask you if are new to town, to inform you about the registration law. Once you're pulled over they can start looking at other things. My general rule of dealing with law enforcement is to avoid giving them any reason to get involved in what you're doing. Not that I don't respect what they do, but I like my privacy.
An out of state plate is an easy reason to pull you over. They only have to see the plate twice, eleven days apart. Even if your car is legal, getting pulled over can lead to unintended consequences. Food for thought. You'll be watching your back for a year.
Been digging through the CV shaft length threads and found couple of dots to connect, if anyone is still looking for the way around having new shafts cut. In the thread linked below NZeder posted a picture from an FSM showing a factory CV assembly with two tripods, for the NA VG30E. Apparently they'll work, but the Birfield/double offset combination must be stronger. Post #57. Found the same diagram in the 1989 RA chapter. I've noticed that all of the threads trying to find a combination of factory parts to use just peter out and fade away. http://forums.hybridz.org/index.php?/topic/65177-300zxt-cv-issue/page__hl__cv%20shaft%20length__st__60
I guess a lot depends on how and where you drive the car and where you live. I just put a 3.9 in my NA car from 3.54, with the 3.062 ZX first gear, to get more pickup from a stop and when I'm on the hilly streets of Portland OR. Otherwise, on the flat roads outside of the city it was nice to have the extra speed in first to wait on the shift to 2nd. Out on the flat plains of Texas Ben might find that a 3.9 is wasteful. In San Francisco, he might be hating a 3.54. As for why the factory put the 3.54 in the turbo cars instead the 3.9, it could be to make the car less likely to burn the tires from throttle alone in first gear. Detuning for the masses.
