ZT-R
    4
Everything posted by ZT-R
  1. What is the model of the controller? I would recommend you putting it on the turbo housing or right after the turbo. That way if your charge pipe blows off or something you willnt boost the hell out of your turbo. Typically your will see about another pound or so when you hook it up directly to the intake manifold due to pressure drop and stuff.
  2. My timing sux, I should have waited on my build another 2 years, probably could do it for 1/5th the price now...
  3. Have you tried propane to try to find a vac leak? Your brake booster line and check valve ok?
  4. 72. I know ES made 2 different ones, i have the correct ones but still sloppy.
  5. Has anyone tried this steering rack bushing? Ebay Link I tried shimming my energy suspension ones but it is still moving some.
  6. I would recommend 4.11 ratio. I have a 3.69 and i dont come out of second until 79mph. 134ish in 3rd and saw whatever the top of 4th was on the dyno. Way to much gear with the R34 trans and 3.69 I think i run out of downforce around the 165+170 range.
  7. What battery are you running? Will that odyssey battery replace a red top optima? My Z is electronically endowed.
  8. It looks like with the right bends you can fit that inside the stock interior panel. Does that seem accurate? If so you could do the stock tank and this... hmmmmm
  9. Where your lugs tight when you took them off? Caliper mounting bolts tight? I have seen caliper mounting bolts loose and make clunking noises. Even if they are snug they will do it. Make sure they are tight...
  10. yup, I did that on my stock hood to clear my intercooler...
  11. I have a red optima battery currently, but I have alot of electronics in my car. No system yet but i probably will put (2) 10" subs in there at some point. I would build a box for it if i where to do it.
  12. Has anyone moved their batter to inside the wheel well, pretty much right under where its mounted in the S30? I need more engine bay room.
  13. Looking good. Im thinking the same color when I go to paint. No time soon.
  14. Go with a LSD right away, save time and work. Mine will light up 17x11s with 180 compound like it was nothing. I couldnt imagine one wheel. Granted mines a rb26 but none the less...
  15. Yea I like the euro ones too. But I kinda like the 2000gt ones too, just for the rareness and me and you have GT-R engines so its kinda ok to do...
  16. Dont have to, but it makes things easier to work with.
  17. Good luck i have been looking for years.
  18. How did you fit 11.5s? Are those the bamf cf flares? They look like the msa ones. i have 17x10.5 on there right now and i have about 1/4 inch of room between the tire and the inner fender so i couldnt possible have any better backspacing. I called John the other day and he is gonna send me some 3.5" lips so they will be 17x11. I think this will completely fill the gap, but if im wrong i would like to know before he sends them out. Do you have any pics of the rear fender flare vs rim width? BTW I love your gas cap, send pics of that too.
  19. Antilag Action. 3k=12psi soft, 16 psi hard
