- Today
My doors are not the same shape as the stock doors, mine are slightly carved outwards towards the widened rear 1/4 panels. Thanks for asking
I’ve been struggling with these Apex rear axles. They require OEM 370Z axles, no aftermarket and not G37 ones. I ordered used ones on eBay, which they recommend, one wasn’t OEM because it had 6 bearings, OEM has 8. So I think I have correct axles and after struggling for a while with the side that has the internal snap ring I looked at the donor axle and the groove is deeper than the new ones. So not sure if new ones have an issue, or if I still don’t have the OEM 370Z axles. Sent Apex and email, we’ll see what they say. -
APEX said they would have a set made up by friday but haven't heard from them. Added a photo showing the APEX control arm length issue. Other bushing is lined up and its about 1/2" short. Put the rest of the rear together so i could sit it on the ground with the wheels and tires. T3 r200 short nose kit and rear sway bar. Got my tires in so got them mounted and installed for some motivation. Since I am using 300zx rear drum ebrake. I decided to use a 240sx ebrake handle (since I have this combo in my 240sx). Modified the handle to fit in the stock Z location. Mounted the cable holder thru the floor. Made a couple small brackets to hold the cables in the correct spot. Adjusted and works great. Also added a couple photos of the brake setup. - Yesterday
Hehe! I've been told visitors to Norway enjoy the nature and scenery. Living here I don't think much of it. And finding other places in the world more exotic🙂
Welcome to the forum! We visited Norway a few years ago: Oslo, train to Bergen, boat to Rosendal (beautiful place that looks like a Jurassic park ) Norway is probably one of our favorite places in Europe.
the way the bottom pipe comes down it is on a bit of a cant. I will install once welded and then slide a slightly larger pipe over it and hold it level and then mark the inner pipe with a sharpie. then when I cut it, it will be a level cut to continue on with the exhaust!
05-01-2026 ATLAS Z UPDATE. Happy May Day! Today I spent some time modifying the intercooler piping to add my new TurboSmart Blow off Valve (BOV). In doing that, I also removed all the piping and added a port on the intake side for a water/methanol jet, and got the intake pipe set up with a 8AN port on the bottom for the PCV setup I am making with twin catch cans, and the 1.5" angled return recirc pipe from the blow off valve I mentioned before. I used a 45 bend and then cut it on an angle and kept adjusting the angle until it was just what I needed. I also got most of my exhaust ready for welding, the bottom portion I am going to do after the top is done.....I need to be able to make the bottom fit just the way I want. All of the intercooler piping will be polished and the entire exhaust will also be polished. 3 inch, mandrel bent stainless with the Evil Energy polished muffler. PICS:
- Last week
I finally found some hours to start making the wiring not look like a rats nest. Instead of fuses and relays, I am using a small PDM. So that complicated things, I am also using a buss plug for 5v sensors and all ground wires.
Wow it’s been over a year since my last post on here. Again the insane time toll that work is taking on me, mixed with some family and personal health the past year has really made it hard to get much done on the car. Boy turning 30 hits hard doesn’t it. I also reached a point where I realized I just need to build a rotisserie because 15min doing any work on the floor pans these days has me walking like a 80yr old the next day. I have decided that I am going to bite the bullet on a ZTrix Subtle Z body kit because I like the stock body style more than flares, and want to be able to have room for a good set of 245 rims and tires. This should also speed up some the body work I dreaded most which was going to be trying to get the rear quarters looking good without buying full replacement panels, and my car has genuinely never been in good enough shape to be worthy of keeping the original body metal.
Congratulations on your new purchase, and welcome to the forum! The car looks like a really clean original example -- interested to see how it unfolds as the project progresses. Thanks so much for sharing; and I hope you enjoy your Z-car as much as we do ours!! 😜
jhm started following My journey with a Euro '73 240Z
looks like a great starting platform for whatever direction you decide to go with it.
Thx! I don't really know at this point. I do enjoy restomod builds. But I am not sure where this 240z is going. Firstly I think I am going to get the car roadworthy and drive it a bit. And see where that takes me. I just received a large box of parts, mostly related to cooling, fuel, vacuum and brakes. All rubber hoses are dry and brittle. And there are small drips on the floor, under all areas where there are fluids in the car And I need seatbelts. The tires are replaced already. The import and approval process is going smoothly. From the road authorities I have now received a confirmation that the car is formally imported and entered into the Norwegian registry systems. For now linked to the VIN only. Next step is to get insurance and register the car to me, and getting the Norwegian registration number. The process is much simpler when transfering cars within the EEA (European Economic Area) system, than from US or Asia. As the EEA states are aligned and following the same processes and regulations. Hopefully I can have the first little test drives on the road within days.
04-30-2026 ATLAS Z UPDATE: I changed up my air intake to a 4 inch pipe setup, with 45 degree bends to get around the engine obstructions, and I realized I really needed to add a Blow Off Valve (BOV) for my turbo. I went with the compact Turbosmart unit, which is a 50mm piston with a 1.5" discharge diameter. Today I got the pieces cut, but still need to do some more before taking them for welding and then more than likely go back to getting them polished out. PICS:
320 to the wheels is really not that much. I had 400 for a while, then 600, now back to 300, all this with no form of structural bracing. Did I ever launch on slicks on a prepped surface, no, but surprisingly I never had any issues putting the power down. If I were to pick I'd say around 500whp is the most I'd ever want to be. For 425whp, just get an LS3 and call it done.
- 5 replies
- advice
- performance
(and 2 more)
Tagged with:
Welcome! Always great to have a new member and another project. What kind of modifications are you planning?
Did I see you putting anti-seize on your spark plugs? YOU HEATHEN lol Looks great so far. I am impressed how low the atlas ended up sitting. Though too bad the hood still needed modification ( I am guessing it is the length versus the point where the hood slopes down faster? That's what I kept running into when I was sizing swap options. A few people doing other swaps pulled their engines into the cabin, but... I kind of want to minimize cutting. That chrome paint did a really good job.
280Z Restomod Progress
dmoralesbello replied to dmoralesbello's topic in S30 Series - 240z, 260z, 280z
Hello again forum friends. It's been a good while since I've posted, basically because I've just been enjoying my amazing Zcar and only doing basic maintenance. However, I think the time has come to consider moving on and letting someone else (very lucky) enjoy this wonderful vehicle and all my work and effort. I have contacted BAT to put my 280Z up for auction. If anyone is seriously interested in the car before it goes to auction, please let me know. It would be great if a fellow forum member would be the next owner. -
Man, I was literally on this thread right now. So if that is where you get the oil pressure for the gauge, where do you get the oil pressure for the ECU? Where do you get the Oil Temperature for ECU and for gauge? I have 2 temp sensors and 2 Pressure sensors for ECU, and Gauges.
ZT-R replied to primaz's topic in Nissan RB Forum
do you have pictures to share? i need to redo my external pickup baffled and trap door McKinney pan as im getting oil starve when hard on brakes on long straits. -
i run my remote oil pressure gauge off that port, that's directly what the oil galley is seeing.
Ill take a set of the doors if your selling. I have me a custom cf wide body but its very subtle. everything will be painted too.
Hello fellow enthusiasts! A family man from Norway here. I got into full-size cars late in life and have been part of the vintage Porsche scene here in Oslo, Norway for around a decade. A project I recently completed is a 5-year nuts-and-bolts bare metal restomod of a 1985 Porsche 944. But now I got myself a 1973 Datsun 240Z. For a long time, I've been Japan curious. Dreaming of visiting the country. Enjoying Japanese cuisine, Studio Ghibli films, various Asian art, the Initial D anime, and following Larry Chen and other Asian car culture YouTube channels. But being in my fifties I am not identifying with huge turbos, vivid car liveries or oversized exhausts. Eventually landing on an older icon. The 240Z. I am a self-taught car restorer and mechanic. And everything I know I've learned from online web forums and old static web pages. I am establishing this thread on Hybridz as I feel a desire to give back and contribute to the continued hub of knowledge and insight in car culture in general, and to the Z-car community in particular. I want to share a full journey, that is readable as a full story. I find that the continuity is harder to do properly on Instagram, FB or similar. But I am planning on sharing updates both here and on Instagram. The car I am now the owner of was first registered in Switzerland in June 1974 and has all the features of what is described as a "Final European Spec". I do not have any written documentation on the Swiss registration. But I -do- have what looks like an original dealer sticker in the rear windshield. And the letters "SWI" written with a crayon on the glovebox mount bracket. The car has lived in the Netherlands since 2001. And now it has moved to Norway. I have little written documentation on the cars life, but the dealer told me it has been sitting for several years, before it now was put on the market. Tires were like hockey-pucks, hoses are dry, bushings are worn, shocks are shot, seatbelts are missing, and there are some rust issues. The car is now red, and the original color is orange 918. But the car is what I describe as "complete". Most the original components are there, apart from the front lip. And it has not been "wrenched to death". I am really looking forward to a long journey with this car. Here are a few images of the car when it was delivered to me. And from today's visit to have the car approved and registered into the Norwegian vehicle registry systems.
Ditto. Seems slower to load than previously -- I've also noticed it's worse with some web browsers vs others, depending on what operating system you have. I'm only guessing here...but it may be due to the fact that our hosting site has certain updates available, but they all cost $ and we don't have the funds to pay for them. Dan's been running the forum on a shoestring budget for several years now (often paying for operating expenses out of his own pocket); and as a result, our software's not fully up to date. Anyone wishing to make a donation to help keep HBZ up and running can do so here: https://forums.hybridz.org/clients/donations/
Who's Online 2 Members, 0 Anonymous, 839 Guests (See full list)
