Miles
    37
Everything posted by Miles
  1. Go here for his website: http://www.frpautomotive.com/
  2. Yes the black and yellow wire goes to the starter only.
  3. Assuming a 240Z with a 350SBC engine and HEI distributor here is the wiring as per JTR: Green-White wire: Attach to fuel pump side of the oil pressure switch so the fuel pump will operate during starter operation. This is wire 1 on the JTR diagram. It ties into the wire (2) that goes to the fuel pump. This wire energizes when you move the key to the start position. If you turn the key part way to start just the fuel pump will come on which I use when the car has sat for awhile. Yellow-Black: Oil pressure sending wire. Black-White without protective sleeve: Tach terminal on HEI distributor. Black-White with protective sleeve: Bat terminal on HEI distributor. Yellow-White: Water temp gauge White-Red Thick: Alternator White: Positive terminal on starter Black-yellow: starter terminal The green wire can be found in the wiring harness between the glove box and the side of the car. It has a bullit connector that you can unplug and attach a wire from the output side of the oil pressure switch. The other end of the green wire is taped with the wires that attach to the fuel sending unit. I installed a Painless fuel pump relay between the oil pressure switch output and the green wire inside the car.
  4. Could be that the master cylinder (MC) push rod that goes between the booster and the MC is adjusted too far out. The factory setting per Haynes, is 0.138 in - 0.157in (3.5mm - 4.0mm) between the face of the mounting flange and the tip of the push rod. You do not have to remove the MC to make this adjustment. Just remove the MC mounting nuts and pull it forward to access the pushrod (7mm). Be carefull not to drop the reaction disk (small rubber disk between the booster and the push rod) inside the booster (see brake section for info on the reaction disk). If the pushrod is adjusted too far out, the MC piston can't return far enough to open the fluid return port in the MC and pressure will build up locking your brakes. First thing you should do before making the push rod adjustment is to relieve pressure in the brake system by opening the MC bleed screws (10mm). If the fluid is under pressure (indicating push rod is adjusted too long) fluid will spurt out when the bleeder is opened. This step will relieve the pressure and free up the brakes if the push rod is adjusted too long. Is your E-brake dragging? Did you adjust the rear shoes to tight?
  5. Summit Racing has the Wilwood 1 MC as well. Let us know how the Wilwood 1 " MC works out.
  6. How close to the floor is the pedal during hard braking? From your post it sounds like the pedal must be firm once it engages.
  7. What make and model car? Where exactly did you find the part? Being detailed and specific will help members with your questions.
  8. Take your time and shop around. Check all of the systems. A clean unmolested electrical system is a plus. Buy this book if you intend on owning a 240Z,260Z or 280Z: How to Restore your Datsun Z-Car by Wick Humble. It explains, in detail, how to completey take apart and re-assemble a 240Z etc. Available at Motor Sports Auto (MSA), Amazon (cheaper) or at Black Dragon. This book will save you hours of research. It will also give information on what to look for when buying a Z car.
  9. Most likely the widow frame needs to be adjusted. Remove the door panel to expose the bolts that secure the stainless steel window frame. There are bolts on the front and rear door edges as well as on the inner facing panel. Loosen all of the bolts and move the frame around until you get the best fit then snug the bolts down. If the frame doesn't move then you have missed a bolt. Be sure to test that the window rolls up/down freely and fits in the frame. Just play with it until everything fits. Buy this book if you intend on owning a 240Z,260Z or 280Z: How to Restore your Datsun Z-Car by Wick Humble. It explains, in detail, how to completey take apart and re-assemble a 240Z etc. Available at Motor Sports Auto (MSA) or at Black Dragon. This book will save you hours of research.
  10. Why not just fix the heater/defrosting system so it works?
  11. tightywhitey185 If you go with a stock MC let us know how it works out.
  12. Electrical system intact/not modified by previous owners.
  13. The bottom line on the 280ZX MC is that the companies that rebuild them are no longer doing so. But you will find many parts stores and on-line sellers say that have them even though their suppliers no longer support the 280ZX MC.
  14. Look here for 280ZX MC replacement: http://forums.hybridz.org/index.php/topic/102754-a-one-inch-diameter-brake-master-cylinder-for-the-s30-z-cars/ There are several threads in the brake section concerning the Wilwood 1 inch MC and booster upgrades.
  15. May be that your combination switch either has a broken wire or dirty contacts. It is easy to repair. You will need a schematic and a volt meter to check out if it is getting power etc. You can repair it or replace it, but you might as well learn how to do both since this is a common problem. Look here: http://www.kamikazer...ombo_switch.pdf This is for a 240Z, but it may be close to the same wiring. http://forums.hybrid...__1#entry669320
  16. I installed a Retrosound radio in my 240Z. It failed within three months. Retrosound sent me a replacement with no hassle. That was over a year ago and no problems since. Also, the faceplate it came with was cut at the wrong angle. Evidently the kit was supposed to include a template to trim the faceplate for a 240Z, but was not included. The installation kit allows you to custom fit to any car. Sound quality and radio reception are about average. Wiring was easy. I ran the output through an amplifier located under the passenger seat. I ordered mine directly from Retrosound. If you order from Retrosound ask them to include the 240Z faceplate template as others have complained that it was missing from the kit. The reason I ordered from Retrosound is at that time, MSA and Black Dragon did not have the latest model in stock and they could not answer questions about the radio. The radio is made in China.
  17. One thing we want to avoid is creating a kluge by over complicating the brake system without understanding why the Toyota - 240SX swap isn't balanced. Kluge = an assortment of ill fitting parts forming a disgusting whole. What is needed is to find a solution as to why the Toyota 4x4 - 240SX combination doesn't work . It's not an engineered brake system to begin with. What would have to change to improve the performance of the Toyota 4x4 - 240SX swap? Things others have tried include more agressive pads, various front - rear pad combinations, larger master cylinder/booster combinations etc. And, of course, competent installation, bleeding, booster rod adjustment and etc. The 240SX rear brake set up is proportionly undersized when mated with the Toyota 4x4 front brakes. For example, my 91 4x4 4Runner had large drums on the rear so the front and rear brakes were better matched. A member (Edan, Silvermine Motors) seems to have come to the same conclusion, and came up with his big Mustang rear brake kit. So, go to a larger rear caliper/rotor combination or go back to a smaller front caliper/rotor combination for better front - rear balance. At this point I am considering going back to the smaller stock fronts with Porterfield R4-S pads, and a stock MC. I already have a 280Z booster and proportioning valve installed. Or doing the whole thing over with ArizonaZ brake kits.
  18. Try the Z Barn. They used to sell the R200 and a mustache bar for the swap. Frome Z Barn used part section: We have put together a kit to swap an R180 differential to an R200 for the 1972 to 1978 models. It consists of the appropriate mustache bar, an Energy Suspension polyurethane mustache bar kit, and an OEM differential mount. For 1970 and 1971 models, you also need a longer drive shaft (DT 1002 or DT 1016) and a rear "aft" crossmember (SU1221). http://www.zbarn.com/zbarn3.htm
  19. Re: Larger rear calipers Silvermine Motors (member owned) sells a big Mustang (2005?) rear caliper kit for the 240Z. http://www.silverminemotors.com/main.sc
  20. I installed a Wilwood proportioning valve when I did the Toyota vented 4x4 and 240SX swap on my 240Z. I have the proportioning valve wide open to the rears and the rear brakes still do not do much work. In an effort to improve performance I installed a 1" Wilwood MC, a larger 280Z booster and Porterfield R4-S pads. So far there is not much improvement. However, having the proportioning valve might come handy if you start experimenting with different pad combinations etc such as using more aggressive rear pads. One member I talked to said that he gets better performance, as compared to one of his cars with the Toyota-240SX swap, from stock front brakes, good pads, 240SX rears, and a 280Z booster. On another car he has stock brakes with a 280Z booster and sees better performance as comapred to the Toyota-240SX swap. Recently, I spent some time reading old posts for the Toyota-240SX swap and the front-rear bias problem is a common complaint. There were some posts indicating the swap works well for others. So there appears to be a solution. The Toyota-240SX swap doesn't appear to be a balanced system. If someone out there has a Toyota-240Sx swap that works well, i.e. more balanced, speak up. What did you do to resolve the bias problem?
  21. The Tilton 7/8 clutch MC is the tried and true solution for the T5 clutch set up. It is listed in the link I provided above. Tilton 7/8" MC TIL-74-875U $80.00 Summit I have used it on two 240Z builds in which I also used the plastic Camaro slave cylinder without problems.
  22. Try Black Dragon http://www.blackdragonauto.com/zZxCatalog.htm
