Miles
    37
Everything posted by Miles
  1. Another approach for bleeding the clutch MC/slave is to open the slave bleeder screw and let gravity flow fluid into it. Put a pan under the slave, remove the cap from the MC, top off the MC with fluid, open the slave bleed screw and let it drip for about an hour while keeping the MC topped off with fluid. Don't let the MC empty out. After about an hour, close the slave bleeder. Pump the clutch once or twice and, assuming that the slave and MC are not leaking and that you have the correct size MC, the clutch should work. In your post you said that you are using a 5/8 MC. Did you mean 7/8? Look at post 7 here: http://forums.hybrid...__1#entry920425
  2. It is not an $8k car. Maybe$2k to $3k if it was clean and loaded with upgrades. It looks like a scarab install with the engine forward. For $8k I would expect the body and interior to be in better shape. Also, the 350 trans is not the best choice. A 700R4 auto or a T5 trans would be better. Keep looking.
  3. You should have the stainless steel trim piece inserted into the seal before installing the seal on the hatch. It may be difficult to install the trim piece after the window is installed on the hatch. Ditto windshield.
  4. I have done two hatches/windshields and did not use a any sealent. The glass shop I go to doesn't use sealent either.
  5. Rebuild the head and get the car running well. You will be in better position to sell the car.
  6. Just a hunch. The only time I have seen all four wheels drag or lock up is when the piston in the master cylinder does not return all the way to its' resting position. This will keep the return ports covered such that pressure in the lines builds each time you pump the brakes. Eventually the brakes will drag and/or lock up. This is usually caused by an improperly adjusted master cylinder-booster push rod. To relieve the pressure take a 10mm wrench and open the bleeders on the MC. If pressure has built up you will see fluid squirt out and your wheels will now spin freely.
  7. Buy the video "Just SUs" from Z Therapy. It explains the operation and step-by-step proceudre for tuning SU carbs.
  8. The best info on SUs can be found here: http://www.ztherapy.com/
  9. If you are not up to speed on setting drive shaft angles, you could take the car to a shop that specializes in building drive shafts such as an off road shop, driveline shop or possibly a transmission shop and have them check the angles for you. The shop may be able to find and correct the angles for you by shimming the transmission and/or differential mounts as appropriate. The shop could also check drive line balance as well. It is the little details like this that make or break a build project.
  10. When you inspected under the car did you try turning the drive shaft, half shafts and wheels by hand while listening for noise/slop?
  11. Could be any number of things. Need to get it up on a rack and inspect everything. May be something simple.
  12. As johnc suggested, search the Driveline forum for driveline vibration/driveline angles. In addition, note that there can be other sources of vibration that mimic driveline angle vibration. What happens if you are parked in neutral and rev the engine high? Any vibration? Try it in neutral with the clutch in and then out. Just curious. Another source of vibration are driveline parts touching the body. For example, when first built, my 240Z with SBC and T5 trans the whole car would vibrate at high RPM while driving. The vibration always started just before the shift point and got worse as RPM increased. I suspected that my driveline angles were off. Upon inspection, I discovered that the T5 Hurst shifter housing was touching the trans tunnel under load transfering engine and driveline vibration to the body. Put the car up on a lift and look for witness marks where driveline components might move and touch the body or other parts. Use a crow bar and move components around to see if they touch/rub other parts. I had to trim off about 1/4 inch of the shifter hole on the driver's side to eliminate the vibration. Since you didn't build the car, a complete inspection of driveline angles, engine/trans mounts, half-shafts, U-joints, suspension etc would be a good place to start.
  13. What do you mean by console l light? Instrument lights? Brake warning light?
  14. I bought one from a local dealership in 09. May be NLA now, but check with a dealer.
  15. If you are going to do an engine swap buy the Jags That Run Datsun Z V8 Conversion Manual http://www.jagsthatr...tsun_Z_V-8.html The JTR manual will answer most of the questions you have, including electrical, engine wiring, cooling, brakes, drivetrain suspension etc. for a 240Z engine swap. It includes engine wiring instructions. Most of the members here are more than willing to help with your questions, but you will need to research the forum so you can ask informed questions. I have done two 240Z V8 projects and found most of the information I needed by searching and then posting questions for clarification or to fill in the gaps. Based on my own experience, the JTR manual is the how-to book that you should buy and read at least five times followed by searching the forum extensively before you start your project. Especially check the FAQs and pinned posts as they cover just about every basic question that has come up concerning 240Z modifications. Good luck with your project.
  16. Buy a copy of How to Restore yourDatsun Z - Car by Wick Humble no matter what direction your project is going. Also, buy the Datsun Z V8 Conversion Manual from Jags that Run (JTR) even if your not planning on a V8 swap. These books saved me countless hours of research and do overs. JTR link: http://www.jagsthatrun.com/index.html
  17. See if this helps for the Autometer fuel gage. I found it by using the search function: http://forums.hybridz.org/index.php?showtopic=61300 As for the lights you may have a bad combination switch or you pulled some wires loose. All of your questions have been covered before extensively. Best way to learn about these cars is to search. You need to be more specific and detailed in your posts so other members can better understand your technical questions. Such as the year and model of your car. Some posts contain step by step instructions and parts used, but you have to search for them and it may take several old posts to get a complete picture of what to do. 72_240z_wiring.pdf
  18. What are your plans for the build? Restoration? Restomod? Race?
  19. What engine and mounts did you use?
  20. See if this helps. 72_240z_wiring.pdf
  21. Did you search or look here? http://forums.hybrid...-of-you-wheels/ American Racing Ansen Sprint wheels look good with any color. See picture.
  22. Buy the book. It is about $39.00. Read it at least five times before you decide to start your project. Note: the book assumes that the reader has auto mechanics knowledge.
  23. Motor Sports Auto (MSA) sells SU rebuild kits and parts: http://www.thezstore...TZS/CTGY/SFC01B I found some SU related videos on Youtube that may be of interest to you. Go to Youtube and search on SU carbs. More info here: http://atlanticz.ca/...bs/su/index.htm Click on pictures to enlarge.
