Leon
    24
Everything posted by Leon
  1. A "velocity stack" is nothing more than an extension of an intake runner. The only difference being the ends, having a taper and bell-mouth. This improves pressure wave reflection. I have the calcs somewhere but don't have time to dig them up. They involve knowing your valve timing, air temperature (for speed of sound calc), and runner geometry among other things. I guess the question is, are you willing to give up X amount of performance for ease of packaging? Runner design will have a huge effect on your engine, as SKiddell points out.
  2. If you are getting ES LCA bushings you may not have to worry about shimming with washers since their bushings are over-sized. I had to sand my outer LCA bushings to fit the strut. Good luck!
  3. Runners have, or should have, a design rpm range in which there is a VE boost caused by pressure wave resonance. Runners should also be designed with as few pressure losses as possible, meaning as straight of a shot into the combustion chamber as possible. I think it makes more sense to design runners with those criteria in mind, and then adapt a plenum. If I were putting so much effort into designing an intake manifold I would be working with an ITB setup. IMO, it would be easier to get right and you'd get better performance in the end. I don't mean to sound harsh, so take it for what it's worth. More power to you if you keep this up and get a nice design out of it.
  4. Agreed. I'm not convinced that strut flex has any noticeable effect on camber. It may give piece of mind if that's what you're after, but in the end it's just unnecessary unsprung weight, IMO.
  5. Contact Derek, I think he still sells them. You do need to know what thickness you need though.
  6. The straighter the runner the better. Bends introduce pressure losses. All of your concepts have bends in them, and in my opinion, the performance cost of the bent runners outweighs any advantage for the sake of a "better" plenum. It just doesn't make sense to me to design the runners around a plenum and not the other way around. My 2 cents...
  7. Ouch, I don't like the look of that! South City huh, I'm in San Bruno. Just pulled the pins in my 260Z earlier this year. Hang in there!
  8. Running that rich for 20 minutes will definitely make the manifold glow! You're dumping tons of extra fuel out of the exhaust ports some of which then burns in the manifold.
  9. I plan to do data-logging on my triples when I get the new exhaust in and the WB02 finally installed. It may depress me enough to go to EFI.
  10. I don't mean to be overly critical, but I think you need to slow down and work on driving technique. Have an instructor ride along with you and see what they think. I think that will do much more for you than trying to play with suspensions settings. Tune the driver first, then the car. Good!
  11. No way. Given the description of the rust, I wouldn't pay more than $800 and it would probably end up a parts car. As you can see, I'm not very ambitious when it comes to fixing rust!
  12. The ARB does not affect traction on launches, but only in cases where there is lateral weight transfer. More bar means more weight transfer, thus a greater tendency to lose traction with a rear bar since you are taking load off of the inside tire. You mention understeer, but when do you understeer, during transients or steady state (think slalom or sweeper)? I would experiment with different setups as you've begun to. Try with/without rear bar and with/without front bar, with having rear bar and no front bar being most prone to oversteer. Also try different alignment settings. Set rear toe to zero and see how it feels, then set front to zero and see if behavior improves.
  13. How is color dependent on the location of the job? Paint it whatever color you want...
  14. The FSM has an alternator test procedure located in the EE section. Look it up in the FSM pertinent to the year of your alternator. In fact, read through the EE section on the charging system of your car as it will help you get a better grasp of what's going on and proper test procedures.
  15. Have you measured the voltage at the battery when the car is running? When revved to about 3k rpm? It should be around 14.5 volts if your system is charging. My 260Z had that problem. I traced wires, cleaned some connections and all was good. These cars often have issues caused by poor electrical connections.
  16. Leon
    432 CI's
    I remember watching that... Terrible video, but a really nice car.
  17. Nice, that is going to sound amazing! I love the sound of twice pipes on these engines.
  18. I've been excitedly following your build and don't remember if you mentioned what you're doing for the exhaust. Out of curiosity, what are your exhaust specs if you don't mind sharing?
  19. I am running a stock exhaust manifold which helps keep the temps down. I also plan to make a heat shield out of scrap stainless as wondersparrow did but I plan to fasten it to the lower carb-to-manifold bolts. Should keep everything nice and cool, plus I won't have to be as paranoid about possible fuel leaks onto the exhaust manifold.
  20. Here's a good article by Steve Dinan, which echoes what I've explained. Click on "Dinan's E90-92 M3 Exhaust." From his Exhaust Theory section:
  21. Is your right side LCA bushing installed correctly? Obviously, there is an issue and it should be fixed rather than band-aided.
  22. Incorrect. I don't know what you mean by "non limiting factor." Every change in the system will have its effect, no matter how much of an effect it is. Of course you will gain more if you match a cam and an exhaust to your intake, but simply changing the intake will still have a very noticeable effect. Volumetric efficiency will be affected any time the intake is altered geometrically. Using triples compared to other carbs, resonance effects will be stronger with the individual runners and there will be much less restriction, especially when comparing venturi sections with SUs. Therefore, there will be a considerable gain in volumetric efficiency when going to triples. In no way will VE not be affected by a complete change of the induction system.
