evildky
Everything posted by evildky
  1. I assume you have good plug wires and that cross arcing isn't an issue? also the rotor and cap in good condition? it always puzzeled me how any engine can be so sensetive to a 1 or 2 degree rotation of the cao in relation to a rotor than has a half inch wide electrode at the end, just wondering is the car can be originating form off center due to damage or wear or whatever from my experience when the cas fails it's intermitant for a very short time befor ecomplete failure
  2. the tokiko's mr2 struts are popular and what I'm running, read the sticky at the top, lots of info there
  3. yup, and the steel ones are called JIC by the way, and you cna get them at hydraulic hose fittings shops cheaper than a/n
  4. the t5 bolts to the stock block and backing plate
  5. I don't know the part number, we're talking 5 years back, but yes the horn worked
  6. all the manual trans backing plates are the same, the auto's have the extra removable section at the bottom to access the torque convertor bolts
  7. I don't recall which wire set fomr the 6al you use but yes it works wiht the 75-78 electronic distributor, or you can use the white wire and hook it to the earlier points style distributor
  8. I think you ahveto pull the diff and e brake handle to get the out, I got tired and cut mine, I planned on replumbing anyhow
  9. stock brake distance or time is irrellivant, either they had posession of the lane and you hit them, or you had posession of the lane and she pulled dout in front of you, it's obvious you hit her but the question is wh had posession of the lane
  10. the zx with the r200's got cv's, at least the later ones did, the driveshaft will likely need to be changed, the pinion flange on the R200 will almost definitely be different form the one on the r180, there are a few different r200 flanges so maybe one fo them will work but the r180 flange won't fit the r200 pinion
  11. I had one that simply would not com out, I welded the shaft to the gland nut, then cut flat spots on the shaft and wiht the aid of a 4ft pipe and a pipe wrench I finally got it
  12. same roof in both cars, the seats are different as are the seat brackets, the fornt brackets on the 280 might be a touch lower, most aftermarket or later model seats are thicker in the bottom than the stock seats, so if headroom is an issue stock seats are your best bet if you still don't fit, cut out the seat brackets and fab lower ones or just bolt the seat to the floor
  13. sometimes fuel pumps fail when warm and work when cool
  14. I took my grant wheel and adapter form my 280 and bolted it right in my 240Z
  15. blasting won't hurt the threads, and if oyu get paint in them when you paint just run a tap through them before you assymble
  16. If I Recall Correctly I'm getting older and me memory ain't gettig any better
  17. your stock pinion mount will work IIRC you just turn it around, the mustache bar needs to be form a 75-78 280Z manual trans or 2+2, those are the models that came wiht the R200 IIRC
  18. the FP autocross cars run stupid high compression ratios and are getting 250 ish whp on race fuel, not sure if they are getting all the gain from head shaving or block decking or both, tom holt is one of the FP guys and hybrid z member
  19. open your wallet, an L31 stroker will ve the most potential to make power, but if you bargain shop you might be able to put together an engine for around $2000, then another $600-800 for tripple webbers
  20. lol, I don't remember who all I happen to line up with but there are always some very fast Z cars at SEZ or DNI now I guess. I think that was when I ran the 12.6 with the slipping clutch after adding an intercooler and upping the boost, it's had a few mods since . My point was on a budget of almost nothing 12's are wthin reach with only a $3-500 turbo donor and a ceap intercooler. I don't see an n/a running as fast for a similar budget, and I don't see a V8 going much faster for the same budget. Granted Andy Nelson has built a V8 Z and few other cars that run mid 10's for $2000. He also just set a couple of land speed records at Maxton (not a $2000 car), and wait till you see what he's building for next years GRM challange. But Andy shops swap meets, he's an engineer and gets the results he gets by building for a specific goal.
  21. lets nto forget about the turbo swap, I did a junkyard L28ET swap and ran 13.010, if I had better slicks ir were willing to take the sawzal to the car I could have run a high 12
  22. I had the craftsman version, it works great for cutting tube or bar stock, useless for sheet, and you have to keep adding consumable lube stocks, and mine died after only a hardful of uses and of course craftsman warranty on power tools is less than stellar, so I'm back to the chop saw
  23. the S130 T5 is stronger than the KA trans, the peopel who swapped to the ka after swapping to the ka foudn them to be mroe fragile than the T5, the T5 also starts out with a much better shifter
  24. eastwood sells a tank cleanign and sealing kit that inclludes metal wash and oyu supply your own etchign acic also adding some nuts and bolts to a length of chain will give the chain more bit int he cleaning process
