DuffyMahoney
Donating Members-
14
Everything posted by DuffyMahoney
Duffys E31 Flow Testing 63" Static 15" Static 63 Degree Shop 45 Intake Valves 36.5 Exhaust Valves DSI Big Valves LIFT Manometer CFM LIFT Manometer CFM Porting By Andrew Kazanis of Mad Greek 0.05 50 35 0.05 14 35 Date: 2/22/2020 0.1 45.25 60 0.1 13 55 0.15 41.75 90 0.15 12.1 80 0.2 36.5 125 0.2 11.5 95 0.25 33 140 0.25 11 115 0.3 31 160 0.3 10.7 125 0.35 27 190 0.35 10.5 130 0.4 23 220 0.4 10.3 135 0.45 21.5 235 0.45 10.1 145 0.5 21 235 0.5 10.1 145 0.55 21.2 230 0.55 10.1 145 0.6 27 190 0.6 10 150 Datsun Flow Testing Data.xlsx
Datsun Spirit valves are in my E31! Next is flow testing. Thanks for all the help Andrew Kazanis Details: New guides, bronze guide liners, reamed to size, seats cut, three broken studs removed.
I will make the cap nice looking. Somesort of SK logo. I will keep it simple, but add some flare. The casting is pretty rough, first step is to knock that down. My local engine shop has a huge vibratory polisher. I might try that first.
My oer/ SK intake plan is going to be perfect. Basically I’m looking for a clean way to do iac and pcv. I will have a plate machined to cap this faux balance bar. Then tap each runner for 1/4 or 3/8. I love the oer/ Sk linkage. The IAC and PCV will be done on the bottom out of sight. This is what the Sk/ oer intake look like under that cap. Casting is a little rough for my personal tastes. I will use a Bosch 0280140551 IAC.
I did the same, but i ended up hating the B&M so i went back to stock with fresh bushings.
Steve Bonk cam, he is a high end cam regrinder.
- 25 replies
- turbo
- twin turbo
(and 2 more)
Tagged with:
I am offset grinding a LD28 crank to get me 84.5 stroke. I will use eagle toyota rods and custom pistons from rebello. Then Datsun spirit valves on a ported and polished E31. 88.5 bore on either an F54 or N42 block. I will be going NA with 45s ITB. Bonk cam. Should be fun and I think it will be close to a 3.2L.
- 25 replies
- turbo
- twin turbo
(and 2 more)
Tagged with:
Looks pretty awesome. Nicely done.
Fell down a Rabbit hole of mods to a good running car.
DuffyMahoney replied to tioga's topic in Nissan L6 Forum
We purge tig weld a lot at work, (I own a brewery) it uses a lot of gas, but welds are amazing. -
Nicely done! I like the head cooling mod and the push to lock a lot. -
List of Options for Crank and Cam Position Sensors
DuffyMahoney replied to cockerstar's topic in MegaSquirt
I have a brand new hoke trigger for sale. If anyone is looking, for a stock 240z pulley. -
Techno Toy Tuning 240Z Micro Big Brake Kit
DuffyMahoney replied to Miles's topic in Brakes, Wheels, Suspension and Chassis
Interesting. If you have the money the zcargarage kit is pretty amazing. -
This might end up being more expensive then the Z Car setup. Which I have. Curious what they will use for the ebrake. -
I did the same thing, works perfectly as my home signal for my EFI system and full sequential. I found a NOS one on ebay.
Well my stock original 1971 series 1 tach works with my fully sequential r35 coil on plug Efi system (haltech elite 750) . I literally ran the coil positive out from the ecu through the white wire with a red band then out to the coils through tachs white wire with a black band. Nothing else was needed. Added about 15” to my entire positive for the coils. I like how the tach feels and reacts the same as it always has. This would work on any 240z tach and a rb swap or aftermarket Efi with COP and fully sequential. I don’t know if it would work on wasted spark or not. Thanks Dirk Stoop for pushing this way vs the others. Where I got the idea https://www.viczcar.com/…/9515-getting-a-240z-tacho-to-wor…/
I finally got my fully sequential ITBs to fire and run! She is a little rough. But pretty amazing base tune and help from Richard Boyk! I can’t wait to get a fully dialed tune running. Worst part is my fuel pump is super loud.
I gave up on mounting the fuel pressure regulator on the engine bay walls, I hated the amount of hoses that crossed over the engine bay. I ended up buying a radium -6 direct mount FPR (very nicely made). Then I had an adapter machined to match the 14mm fittings that the Jenvy fuel rail uses. I should be able to split both sides of the FPR to my 7mm return and my 5mm return. I think I came out great. Very neat design by radium, it can be mounted in any direction.
I am going to attempt to move my FPR to the drivers side and use it. That way I am hard lines under the car. I will T the return from 7mm to 5mm and return via the stock 5mm line and the 7mm vapor vent line. Then use the 5/16 to feed the ITBs. Hopefully it works! I bought some 7mm efi fuel hose from belmetric. So that should give me a good amount more flow. Hopefully my push lock fittings work with it. My FPR mount was waiting to fail, i cut a lot of the strength out. So I will need to fabricate another and put it in my stock coil spot. Should end up looking pretty clean and simple.
I took to a local radiator shop. They actually said they did it all the time. I was told its a common thing for radiator shops to do.
The black tank is mine. The other was some image from google. I had mine, acid cleaned, then sealed. Then the exterior is powder coated.
My stock lines are 5mm return and 8mm supply. So the Return gets a 3/16 line. Which is pretty tiny.
