stony
Super Moderators
    10
Everything posted by stony
  1. Ok its been a while but if i remember right arn't the skylines front sump pans? I know when i went to a l28 in my newman i had to swap pans and pickups. i was kinda thinking that the front sump pan that come on the rb25 out of a skyline would work. is this not true?
  2. The only reason I did my rb26 was because I was in Japan. There is no way at the time i could have afforded to due it in the US. I go the entire drive train plus a crapload of other stuff for the swap for less then what you can get an rb26 with a cut harness from ebay. If you want to do a rb25or rb26 right and have 450-500 HP you need to have 10-15K in the bank easy. I think if you put that kind of money smartly into a v-8 swap you’d have a faster car all around. My 2 cents
  3. Where is it leaking from? there is alittle drain hole in the of the pump.... if its coming from there teh waterpump is bad.
  4. sure your waterpump is not cracked? If you got your engine out of a front cut that was wrecked in the front the waterpump is the first thing on the motor to break. either cracks the waterpump or breaks off the mounting tab on the block.
  5. Ok here we go same track differnt car Visually much faster but slower time and much higher MPH. http://www.exvitermini.com/movies/899run.mpg The r31 had to be running on a shorter track or something
  6. Hmmm well heathcote is a 1/4 track in austrailia. is there such thing as 1000ft track? It for sure dosnt calculate in any of the ET calculators. its off by about 20 mph atleast
  7. http://video.google.com/videoplay?docid=-6264514049701182371&q=r31+rb26 I posted this a long time ago but i cant find it I came across it today and noticed something that didnt seem right 8:56 @ 137 MPH:burnout: Should the MPH be alot higher for that kind of ET?
  8. Hey just a suggestion....... nbefore you start running it hard. run your breather hoses. if for some reason you push a little oil out the breather on the turbo side will drip directly on the rear turbo downpipe and may (worst case) cause a fire and will for sure stink up the car.
  9. J can you email the video to clint.stoneham@elmendorf.af.mil i cant access streetfire from work here in singapore ;< either that or load here on the hybridz server
  10. BTW google search rb26 z32 swap gets a crap load of hits. might find info in there.
  11. Last 2 reponses deleted... The swap in question has been done but there is no kit that i know of at this time. The rb26 will fit but will require lots of fabrication.
  12. OMG i just happen to have a amost perfect s13 for this. i say almost perfect cause i got it for free without a motor.... wait... that makes it perfect !!!!!!
  13. I did some readon on this car.... THIS IS NOT AN FD... its a full tube chassis raceprepped car with a carbon body bolted on.
  14. Is that dog wearing a SHIRT?????
  15. Modified stock IRS kept breaking. decided to go with a backhalve 8.8 should hit the track next summer i hope ;>
  16. Sorry thought Jamie foxx in the was enough:bonk:
  17. Update.... no pics though. My kirkley aluminum seat is in, all the tin you see in the previous pics is now stitch welded in and the shifter mount is welded in and shifter mounted.
  18. http://www.glumbert.com/media/roast Jamie foxx = extreme language..... watch out for the kids!!!! I have watched this 10+ times now and every time i laugh my ass off.
  19. Just curious. I will be there for a month starting on the 8th of october and would like to see something other then orchid towers. Something on the lines of car racing of any kind.
