NewZed
    72
Everything posted by NewZed
  1. The hose from the valve cover is part of the PCV system. The L shaped metal fitting from the top of the cover is just a press fit with adhesive in to a grommet, I believe, or something similar. It's not threaded. You have to seal that if you're running EFI. If your engine runs clean you can get away with heater hose for the valve cover hose. It only sees fumes if you have more blowby than the PCV valve and its hose underneath the manifold can handle. The flame arrester is an individual call. A piece of brass scrubbing pad would probably do the same job. I think it only sees flame in extreme cases.
  2. You are going to have a hell of a time with that RB25DET swap...
  3. Use Google images and type in "280Z sway bar end links" or cut and paste from here. A bent sway bar could probably affect rear wheel alignment also. And don't forget to check your brake lines. They could have snagged something or been stretched. The wheel lugs too, even though they didn't break, could be stretched or damaged. If the front end went over the curb, parts up there need a good look. The TC rods can bend or get a crack started that will fail later. Even if you get a new shell, these parts need a good inspection if you're going to re-use some.
  4. Doesn't your problem seem similar to johnc's in Post #30 here? - http://forums.hybridz.org/topic/113462-rear-wheel-stub-axle-play-help-needed/page-2?do=findComment&comment=1086574
  5. Maybe, subconsciously, you were just looking for a reason to build another car. You crashed on purpose. Do the doors and hatch open and close properly? If not, you'll always be reminded that the car's not-quite-right.
  6. Not really sure what you mean by rivets. I don't see any projecting rivets on my spare clutch disc and can't imagine any projecting in from the pressure plate to where they might rub. Pictures? (damaged parts are always fun to look at). I have rubbed the springs in a clutch hub on the flywheel bolts when I put it in backward. That was a small block chevy.
  7. The main purpose of Hybridz, as I understand it, is to discuss ways to add pep. Have you browsed through some of the threads? Check out the FAQ's section. Rebuilding an L24 wouldn't be high on anyone's list of ways to add pep though. What does TL;DR stand for?
  8. The only thing that keeps any engine from destroying itself is control of the air supply. If you have too many RPM then you are letting in too much air. Check all avenues for air in to the cylinders.
  9. I had one that leaked through the clutch fork pivot pin (with the ball on the end). The threads are through the front cover. If you took the pin out and didn't seal the threads when you re-installed that could be your source.
  10. Here's a link to classiczcars.com that might work for you. Not really easy though. http://www.classiczcars.com/forums/content/201-honda-wiper-motor-upgrade-240z.html Another option is Philbin in Portland, OR. They'll clean up the motor and replace any broken parts for a very reasonable cost. At least they did for me a few years ago. http://www.philbingroup.com/
  11. You need to measure fuel pressure after you shut the engine down and before you start to know if the fuel rail is draining. If the rail is at zero when you hit the starter the engine will just keep cranking until the rial fills and re-pressurizes. My 76 280Z has not had a cold start valve for the last few years. I went out last week after it had sat for a few days in the garage and it fired right up after about five revolutions. When I had an FPR that leaked down it would take longer, although not as bad as you're describing. You might also have weak spark. Check the grounds on your ignitor (power transformer) and its mounting bracket. During starting spark is weaker since battery power is sucked up by the starter. If you have a weak transformer it might cause starting problems. I had an ignition module once that would only start the engine with starting fluid but ran okay once the engine started.
  12. Be aware that if you go to a typical parts store and ask for 280ZXT alternator you'll most likely get a 60 amp unit.
  13. I wonder if these sellers, and maybe Nissan too, don't have multiple sources for what they sell under their names. I couldn't even find the Beck/Arnley gasket on their e-catalog (which they seem to think is fantastic) unless I had the part number first, 037-3936, and the picture may or may not be correct. But it doesn't show the metal crush ring. Looks like paper too. http://www.beckcatalog.com/# http://www.beckarnley.com/beckarnleycatalog.html Looks better on Amazon. Same company, different picture - http://www.amazon.com/Beck-Arnley-037-3936-Exhaust-Manifold/dp/B000CAVLYC Looks like no way to tell what you're getting, over the internet. p.s. Is "graphite" really the material used on some of the gaskets or did someone just give it that name because it's black and looks fibrous, like graphite fiber composites? Edit - some of the parts people refer might just be NLA. There's a 1978 Beck/Arnley 037-3951 gasket, wholesaler closeout, on Rockauto that does not come up on BeckArnley's catalog (above). The "good" gaskets may not be available anymore as normal stock items, only NOS.
  14. It's not uncommon for the adjustment idler pulley bearing to go bad on the S30's. I'm not familiar with what the S130's use for belt adjustment. I also don't know what compressor bearing failure sounds like when you blend R134 with with R12 and its lubricants. From what I've read the lubricant used in R12 is incompatible with R134. If you put enough R134 in, the R12 lubricant will separate and the compressor bearings will fail. Could be what's happening to yours.
  15. I'll bet they're garbage... Are they more expensive Fel-Pro? The Fel-Pro gasket on my engine now is the paper/cardboard style. Weird that you would have the sandwich type from Fel-Pro. And they only show one model number on their site - http://fme-cat.com/overlays/part-detail.aspx?brand=FL&PartNumber=MS%2091034&pt=Intake%20and%20Exhaust%20Manifold%20Combination%20Gasket&lu=1982%20NISSAN%20280ZX&vin=#.UpbIQiff_Fw http://fme-cat.com/Application.aspx?year=1982&make=NISSAN&model=280ZX&cat=Engine&subcat=Gaskets%20and%20Sealing%20Systems&brand=Fel-Pro
  16. The MSA and Victor Reinz gaskets are three layer - polymer on each side of thin steel. I don't know what the polymer is. It's not paper though. Or graphite. I've had both MSA and VR and would bet that MSA just resells Victor Reinz, they look identical and fit the same. Victor Reinz is available on RockAuto.com
  17. Not to kill a sale but, weirdly enough, your local Nissan dealer might be able to get one. Part #10, three part numbers, might be A, B, and C. http://www.carpartsmanual.com/datsunS30/DatsunZIndex/Axle/RearAxleDriveShaft/tabid/1730/Default.aspx http://www.courtesyparts.com/spacer-bea-p-359070.html
  18. There's room for a mirror. Use your left hand to compensate for seeing in reverse.
  19. Trying out some new picture-editing tools. From the usual place.
  20. You might consider cutting your losses (time) and re-installing the old Hazard switch. Looks like you've created a new problem with the Hazard switch replacement.
  21. ALL RELAYS PULSE ON AND OFF. What would cause a pulsing? Flashers. Check those two circuits for shorts.
  22. What's cylinder pressure now? Did you clean a lot of carbon from the piston and combustion chamber? Curious. I've seen signs that the intake valves were getting cleaner on my old engine, that had obviously sat for many years before I got it. They were cleaner when I finally took it out than when I changed the manifold gasket, after about 20,000 more miles. I had seen the same as you and wondered about cleaning up the backs of the valves. They were nasty looking. To Xnke's suggestion, modern gas and hard driving to get lots of flushing on the back of the valve might be the way to go. A good reason to go have some fun. You're cleaning your valves.
