NewZed
72
Everything posted by NewZed
There are pictures and descriptions in the FSM that explain cam/crankshaft coordination. There's a notch and a groove and a timing mark that tell all when combined with general knowledge of #1 cam lobe position. Align and orient four things and you'll be safe, after you get the tensioner back in to its hole.
question about headlight relay mod
NewZed replied to disepyon's topic in S30 Series - 240z, 260z, 280z
Unfortunately, the guy that developed the kit had a 240. Search "Zs-ondabrain" on classiczcars.com. He built the kit that MSA sells. -
You can use a relay between the combination switch and the headlight fuses at the fuse box to take the current load off of the switch. The switch will then only carry enough current to run the relay. The headlights will still ground through the dimmer switch in the turn-signal stalk but at least you'll have one old resistive contact out of the headlight circuit. Your lights might get a little brighter and the odds of the combo headlight switch failing from heat-cycling go down. -
Have you considered putting the original brake parts back on?
- 48 replies
- brake bleeding
- bleed
(and 2 more)
Tagged with:
Shock/strut purchasing without Tokico's
NewZed replied to joshp's topic in Brakes, Wheels, Suspension and Chassis
I've seen reports from several people who run KYB's with lowering springs. KYB puts a warning on the box not to do it but it's not clear what damage might occur. I have KYB's all around, with cut springs in the front and Tokico's in the back. Probably not a good race car setup but it works fine for street driving (for me). Lowering the car makes it handle much better, from the jacked-up stock configuration. -
77 280z cannot start, injectors not functioning?
NewZed replied to ISPKI's topic in Ignition and Electrical
You can check the wiring from the injector plug to the ECU also from the connector. Find the pin numbers from the diagram and just measure continuity between the injector connector and the ECU connector. You've already checked power, the other side of the injector circuit, when you grounded the light bulb. Eyeball the diagram and you'll see that many of those grounds go to a common point. There's one in the EFI harness, it's screwed to the top edge of the intake manifold, where the harness jumps the gap from the body to the engine. This thread illustrates why once you have the ECU connector in one hand and the meter in the other you might as well spend time testing as many of the circuits as you can. Grounding is one of those things that seems so simple it's often overlooked. -
No, just check the intake system and crankcase for air leaks. That includes all of the hoses. The crankcase is connected to the intake system through the PCV system. The ECU meters fuel based on the quantity of air indicated by the AFM. If you have any leaks, the air/fuel ratio will be lean. Even the dipstick tube will allow a leak if the dipstick is not seated. Focus on the things you touched when you removed the valve cover. Old hoses can split when they're handled. If you put any fancy breather filters on the valve cover while you were there, that was a mistake. All of those hoses need to be intact.
Vacuum leak to the crankcase is probable. Check all hoses, including PCV. All air to the intake system must pass through the AFM at least once, including PCV. I'm assuming that you have a ZX, since ZX is in your screen name.
I've had new slave cylinders with machining grit inside. Some times new parts fail quickly. Have someone press the pedal while you watch the slave cylinder. A quick and easy way to distinguish between the hydraulics and the clutch.
You've identified all of the key clues. If you were forced to formulate an answer, what would it be? What would you do to check your proposal? Why am I writing this like a question on an exam?
I've had a 95 Pathfinder for 18 years. 221,000 miles on the engine and it still runs great. The main problems with them that I've heard and/or experienced is: - the driver's side exhaust manifolds tend to crack - they break exhaust manifold studs. Watch traffic for a while and you'll probably see several 90's PF's farting by as they accelerate. - the early engines uses a timing belt that required replacing at 65,000 mile (I think). They changed the tooth design later to go 105,000. It's an interference engine so when it goes, the vehicle typically ends up in the junkyard (check the yards and you'll see many in nice shape with no apparent reason for being there). It's crowded in the engine bay so replacement takes some work. - the cam seals leak at high mileage, as does the water pump. Both are behind the timing belt. Courtesy Nissan has actually put a kit together of all of those parts to do in one big job. - I've heard that the auto transmissions aren't very good and tend to give problems. Many of the nice PF's I've seen in the wrecking yards also had auto's. Otherwise, the rest is pretty durable. Mine only went in to the shop twice, once for the cracked exhaust manifold and once for a busted power window motor (I hit the automatic roll-down with the window frozen shut - my fault). Mine is an SE 4x4 with 5 speed and the auto hubs. But I haven't really used them much. I would ask specifically about the timing belt. If it's not within the 65,000 mile window or close, it's just a self-destruction waiting to happen. Check the front of the motor for oil and water leaks, and abuse the transmission in a test drive.
You could try removing the line to the calipers, pressing the pedal and seeing what comes out. You need to isolate down to sub-systems. Don't forget also that the "pressure" when using the Mighty-Vac method is atmospheric. It's everywhere. So, for example, if the bleeder on the other caliper was open, or if there was a leak there, the vacuum method would pull from there instead of the reservoir. Wherever is easiest. When you use vacuum to pull, it's not exactly the same as using pressure from the MC to push. As for isolating components, I've fabricated small rubber plugs to fit under the fitting for pressure checking. Just stick it in there, tighten the fitting slightly and that caliper or cylinder is locked out. You can use that to test the MC. You could also rig up an old piece of brake line and run it directly from the MC in to a container if you want to see if the MC is pushing any fluid. Or use the bench bleeding ports, that's what they're for. Again, taking the calipers out of the picture. In your video, you have everything in the brake system connected, and you're trying to figure out what's wrong by watching fluid run through a tube out of a caliper. Too many things interacting at one time. Isolate down to something manageable and visible.
- 48 replies
- brake bleeding
- bleed
(and 2 more)
Tagged with:
Tips for modifying,upgrading,or restoring a Z on a budget.
NewZed replied to MJLamberson's topic in Miscellaneous Tech
Start your own thread. Pick a forum in which to post your new thread that has a title related to the topic of your thread. Read some of these threads before going further: http://forums.hybridz.org/forum/68-new-members-forum/ p.s. Never use "lol" again. -
240Z to 280ZX alternator swap charging voltage
NewZed replied to Sweetpoison240z's topic in S30 Series - 240z, 260z, 280z
Didn't Rebello have some advice? What did he have to say? They're doing the 9 yards, right? -
ECU's do go bad sometimes, though not often. They use similar transistors to the ones in the ignition module to drive the injectors. I had one die on me while driving. I got two or three restarts out of it to get me closer to home then it was dead for good. And, recently, someone on another forum has reported the symptoms of a dying ECU. It happens. That's probably where you're at on FSM troubleshooting, "if all these tests pass, replace the ECU". -
Don't know if he has stock or thinks he can get them - http://www.datsunstore.com/lowering-springs-74578-tokico-linear-rate-p-1706.html http://www.datsunstore.com/lowering-springs-7074-tokico-linear-rate-p-1824.html
Does the tachometer show engine RPM while trying to start? Or while it's running on Starting Fluid? -
Nissan calls both heating and cooling of the air in the cabin "air conditioning". The Air Conditioning chapter of the FSM describes all of the odd pieces that have to work right, like the magnet valves (solenoids) and the vacuum reservoir (the big white bottle). Pretty common to lose the vacuum line to the bottle and get no heat.
Jwwinsrt might be confusing Modern Motorsports with Chequered Flag Joe. CFJ has both web sites in his sig but nothing showing that they are two separate businesses. That plus the Canadian spelling is a problem.
Who did the convertible work? You might have more body flex than a typical Z. And typically it's the rear end that sits extra high on the stock 280Z's. You said the fronts of the spring set you'll be swapping in have been cut 1" but what about the back? Lowering made my 76 feel more stable, so that won't hurt, but I cut the backs more than the fronts.
Seems more likely that you knocked some wires around when you were swapping rails, or the stock rail was damaged. The stock rail should flow plenty of fuel unless it had a bad dent or crimp in the tubes from being removed and replaced many times. Or you had a bad FPR and that was swapped along with the rail. Something's not right about your solution. (Sorry Pallnet, this post was probably worth 10 sales).
Pretty common question. Frequently asked. There's a thread for it - http://forums.hybridz.org/topic/52263-newb-project-faq-what-engine-swap-how-much-will-it-cost/ Suggestion to get more responses - get rid of the avatar.
- 14 replies
- help
- 280zEngine swap
(and 1 more)
Tagged with:
We moved past that in to philosophy...
Stop beating around the bush and just say what you know. Are the cross member bolts 3/8-20 or not? I know something you don't know is just a kid's game.
