NewZed
71
Everything posted by NewZed
The 260Z pump is a low pressure pump for carbs. EFI came with the 280Z in 1975. You need a high pressure pump with the appropriate FPR. And you should be measuring fuel pressure before you even try to start the car, to be sure things are right. Unless you've done some plumbing and added a return line, you could get too high fuel pressure (from your new EFI pump) due to back pressure from a too small return line. I haven't done what you're doing, these are just odds and ends I've picked up from the forum.
Might be someone from here, but looks like an interesting collection of parts waiting for assembly if you have the extra cash - http://portland.craigslist.org/mlt/pts/3127405643.html
Just a guess but I think it could apply - any chance that your diff and transmission shaft centerlines are not parallel? Misaligned. A common cause of speed-related vibration. I've not measured the play in the R200 shafts but after working with several I've developed the opinion that the fit is kind of loose, and contributes to the remaining clunkiness of the Z drivetrains, in general. The splines on the R200s I have don't fit super-tight.
Have a bunch of wiring questions for my 280Z
NewZed replied to dpuma8's topic in S30 Series - 240z, 260z, 280z
You have bitten off a choke-size piece of work. This might help you out with the combo switch wire colors. Apparently there were several combo switch versions used over the years. http://atlanticz.ca/zclub/techtips/electrical.htm Edit and p.s. - I saw your question about "transistor unit". You should read through the FSM to figure out how your engine and control system works before going too much further. If you're asking if you need a transistor unit, you have a lot of reading to do. Read the Megamanual site also. http://www.megamanual.com/index.html -
After the early 240Z (adjustable rod) the slave cylinders are the same for the L engine transmissions. They might even be the same cylinder, but with a different rod for the early ones. Looks like you have two problems, at least.
80-83 has the evenly spaced 1-4, plus 5th gear. No idea if it would keep you on boost or not. The ratios of the transmissions, by year of the car they were used in, are listed in various spots around the internet, on web sites and in forums, and in the FMSs of each year.
The "wide ratio" 5 speed has the same 1-4 ratios as the 4 speed. 1980-1983 has the evenly spaced 1-4.
freckin intake / exhaust manifold heatshield
NewZed replied to jomz shakes's topic in S130 Series - 280ZX
Have you tried to work around the shield to get the nuts and/or bolts off/out? That was a good suggestion. Posts #7 and #8. Or keep grinding. -
It could be the fuel pump cutoff switch if it's a 75-77 car. The switch is bypassed at Start, generating enough fuel pressure to start the engine, then the engine dies when the pump loses power. The switch is adjustable by bending the rod under the AFM cover.
This web site is pretty handy - http://www.carpartsmanual.com/datsuns30/DatsunZIndex/PowerTrain/TransmissionControl/5Speed/tabid/1718/Default.aspx Shows late 4 speed and 5 speed forks as the same. Also 3-4 fork is the same as 1-2. Edit - seems like you'd have a 2nd gear problem too, if it was the fork. Maybe the shift rod or the ball bearing detent in the adapter plate? If I understand things, the check ball and detent notch hold the rod which holds the sleeve.
You should study up a little bit (a lot) on your car's electrical system. You're missing a basic understanding of the system. No offense, but it shows, for example, wires melted due to "feedback". Wires melted because you shorted the battery directly to ground. Twice, and on purpose. If you don't have a multimeter, you should get one (after some reading). Anyone with a meter would have checked that white wire for battery voltage when they saw the sparks, probably before they tapped it to ground. You can test everything before connecting, to save yourself the burned wires. Now that you've burned some wires, you should use a meter to see if any of the neighboring wires have had had their insulation burned off and are now shorted to other wires or to ground. Plus there are some questions about why your fusible links didn't blow instead of burning the wiring. yours might be missing, shorted or replaced with the wrong wire. Good luck. Don't mess with it until you have a meter and know a little more, or find a friend that does. Cars have burned to the ground due to wiring mistakes.
I don't think that the 240s have the resistor since they don't have ECUs or use the same kind of tach. On the 280s the resistor is bundled in to the wiring up by the relays and fuse panel under the glove box. It's a 2.3 kOhm resistor, kind of odd looking with a male and female bullet connector on the same end. Hard plastic rectangular body, about 1 cm x 2 cm (it looks like the drawing in your wiring diagram). If you have the 280Z wiring you might be able to find it and wire it in. Or get one from Radio Shack. Note that I haven't seen a bunch written about this so I could be totally off base. I've had two cars that wouldn't run without it, or the tachometer, installed though, even though the wiring diagram shows the Pin 1 wire as a separate circuit. I'm thinking it might drop the voltage to the ECU or condition the signal so the transistors work right. I'm not an electronics expert, it could be an artifact of two old cars that I had.
The "signal" to the ECU runs on a wire from the negative post of the coil to Pin #1 at the ECU. Have you measured continuity from the coil to Pin #1? Also, some 280Z ECUs (the ones I've worked with anyway) need to have the the tachometer, with its in-line resistor, installed or the ECU won't work right. I'm not sure how that's handled with the L28E swap. I have an engine on a stand, with 1978 ECU, with the resistor installed, but no tachometer, on a branch off of the line to Pin #1. You might look at that as a possibility, if you're sure that Pin #1 is connected to coil (-).
Electric fan affecting electric fuel pump?
NewZed replied to Datz350's topic in Gen I & II Chevy V8 Tech Board
You answered your own question "one of the power wires on the electric fan had been melted to the plastic wire cover. After separating it the fuel pump cut on". So, in your custom-wiring case, the answer is yes, the fan wiring has something to do with the pump. But it doesn't need to. Your wiring has all been installed by someone with their own ideas of what might be right. Melted insulation and hot wires indicate that they were wrong. The best thing to do is to tear it all out and start over, or have someone help you do the same. It's only two simple electrical devices, it's not complicated. You'll be surprised at how easy it is once you dig in to it. There's no simple one-wire solution for you. -
Please help me identify what needs replacing! Gnarly Gear Grinding
NewZed replied to MazerRackham's topic in Drivetrain
Is that grinding or just the shift lever rattling? Looks like the lever bushings might be gone, they're plastic and known to disintegrate. -
Replace entire driveshaft, or just u-join? What is easier?
You said it was brand new. It should be shiny and look new and probably have stickers or painted on ID numbers. Do you think it might be a fake? Or is it a brand new aftermarket? For $15, it might be worth buying just for a long metal tube. Got pictures? -
Injectors that don't squirt comes up about every week or two. Almost impossible not to find a thread describing solutions if you search "not getting fuel" or "injectors don't fire" or "engine starts then dies", etc. The Engine Fuel section in the 280Z and 280ZX FSMs all give a good description of what causes the injectors to squirt. Easy reading and worth doing at at least once. Not kidding.
That would be a great deal if it's real. Somewhere from the 240z to the 280Z they started staking in the u-joints, making them irreplaceable without some machining. And $15 is about the price of one cheap u-joint. It would be cheaper, easier, and most likely better, especially if they are Nissan factory u-joints. -
L28et swap dies less than a minute.
NewZed replied to xShodaimex's topic in Trouble Shooting / General Engine
Does the wire to L have 12.6 volts (battery voltage) with the key at Run? That wire powers the windings that create the internal magnets that are required for charging. The wire to S needs 12.6 volts also, to sense the voltage for the regulator to control the voltage. And, of course, the thick white wire should have 12.6 also, since it is the charging wire. And the case needs to be grounded, either directly or through the E terminal. You can measure all three with a voltmeter the key at Run, and the grounding with an ohm-meter or test light. If you don't have those, something's wrong with the wiring. If you do have those, you might have an alternator problem. -
There might be an inline fuse in the wire to the pump that has blown. If the wires are getting hot, then the fuses are getting hot and that's how they function, they melt to save the wires. Overall, it sounds like someone did a poor job of wiring in your fan and fuel pump. 71 didn't come with an electric pump, I believe, so yours must be a custom installation. You should probably start from scratch, using the right wire gauge, relays and fuses, before something melts and/or catches on fire. You just got the car? Some details on what you're working with would be interesting. -
Noob to turbo swap into a 240z ignitor harness separate?
NewZed replied to motomanmike's topic in Nissan L6 Forum
One more perspective here, going back to the question in your first post - the ignitor is "triggered" by the ECU. So there is most likely (I've not seen an L28ET harness so can't say for sure) a wire from the ECU harness directly out to the ignitor. The other wires from the ignitor connect to the coil. The GM HEI module, if used, will also be controlled by the ECU and attached to the coil, in a similar fashion as the ignitor. A wiring diagram will probably make it clear which wires from the ECU control the ignitor. "skittle" over on zcar.com has a writeup on using the HEI module with the L28ET control system, it might also give you some clues. Seems to work, although I do notice his diagram says "ground wire from ECU" for the power wire. http://www.zcar.com/70-83_tech_discussion_forum/hei_ignition_control_module_swap_info_%20turbos_only%20_876981.0.html -
Still can't really understand what you're writing. Your last post implies that fuel pump turns on as soon as the AFM is installed and does not turn off until the key is at Run. That would mean the pump runs constantly with the key Off, draining your battery to death, and the car won't run because the pump turns off when you trun the key to Run. If that's the case, the problem is not your AFM, it's probably a shorted relay. "Prime" is the word ZX people use to describe the 3-5 seconds that the pump gets power when the key is turned to Run. The word "prime" confuses things. The 75-77 AFMs use a switch inside that makes contact when the AFM vane opens, sending power to the fuel pump relay. Some of the 78 AFMs still have the switch but it's not used at the connector. It's easy to adjust with a pair of pliers. Pop the black cover off of the side of the AFM, it's just glued on. Move the counterweight and you'll see how the switch is supposed to open and close. Tweak the metal rod until the switch opens, (fuel pump stops) just as the counterweight and vane are about to hit the stops. You can do the adjustment on the car or use an ohm-meter and do it on the bench. If you do it on the car, the pump should be off with the key at Run, then on when you barely move the counterweight.
What is the FSM spec. for distance fuel should shoot from the fuel line? Black plugs = "lean I suppose"? Doesn't make sense. This looks like a well-crafted troll message. If not, then the first thing you should do is measure fuel pressure with a gauge. It could be the source of all of your problems. Good luck.
From the threads I've seen, especially Heroez's recent poll, only the ZXes had a "priming" feature, and it didn't appear to be tied to the AFM. It seemed to be controlled by a relay or the ECU, depending on which electronic control system you had. Heroez never did tie up the loose ends on his priming problem, and I've only worked with 280Zs so can't be positive, but that's the way things look. Are you saying that you're searching for an AFM that powers the fuel pump for five seconds (which your 76 shouldn't do anyway), and you're going to return one because it doesn't? 5 seconds of pump operation doesn't seem worth it, and you'll probably never get it with a 76, unless I've misunderstood something.
Can't help you with that. That's a basic for automotive work. A skill well worth learning. I'm positive that there are many youtube videos on how to use one. And videos on how to check a coil, check for spark, etc. No offense. Good luck. http://www.youtube.com/results?search_query=using+a+multimeter&oq=using+a+multimeter&aq=f&aqi=g7g-m1&aql=&gs_l=youtube.3..0l7j0i5.402.4845.0.5919.18.17.0.1.1.0.208.2189.5j11j1.17.0...0.0.2mgq8y_QcIc http://www.youtube.com/results?search_query=checking+spark&oq=checking+spark&aq=f&aqi=g4&aql=&gs_l=youtube.3..0l4.20377.26531.0.26898.20.16.2.2.2.1.208.2173.3j12j1.16.0...0.0.Nz2pV8A2lu0 http://www.youtube.com/results?search_query=testing+a+coil&oq=testing+a+coil&aq=f&aqi=g2&aql=&gs_l=youtube.3..0l2.12178.14763.0.16115.14.14.0.0.0.0.171.1344.8j6.14.0...0.0.BN1_7HX2Fwk
