NewZed
    72
Everything posted by NewZed
  1. There are better ways to figure out if you have a diesel. Those are the only things I've seen on an engine with a household-type plug. Could still be handy in certain parts of Texas, I assume. Have fun with the new Z. Read up on the EFI before it has problems, not after.
  2. Just a neophyte, but wouldn't the Schneider guys have some notes on the grind - http://schneidercams.com/270-60F-14_LET6.aspx Still in business and they have a phone number. Just a thought.
  3. I think that the 240SX's came with short-nose differentials. There are adapters available but they're expensive. Take a look under the car, they are obviously shorter than the long-nose. If it's a viscous LSD unit it should have a sticker on it also. http://forums.hybridz.org/index.php/topic/49194-differential-cv-lsd-hp-torque-r160-r180-r200-r230-diff-mount/ http://www.modern-motorsports.com/catalog/product_info.php?products_id=74&PHPSESSID=913b505897594e5aaabe6608cdf597e9
  4. Sounds like a block heater. Did the car come from up north?
  5. I see a weight on the left and a part description, under a year-of-car heading. What's the issue? Hard to complain about free.
  6. This whole page of posts (and more) is about ignition but the statement above suggests that you have a fuel problem. Have you tried starter fluid (Edit - it worked here - http://forums.hybridz.org/index.php/topic/108541-l28et-240z-swap-wiring-help/page__pid__1015062#entry1015062)? If you do and it starts and revs, then dies, forget about ignition and focus on injector firing.
  7. Maybe your timing light is triggering off of a different plug wire. You might line up the light and sensor on the Unilite for sparking cylinder #1 and see where the timing mark is, engine not turning, just to feel comfortable that the engine is not really firing the #1 plug 50 degrees before TDC. You should be able to get within a few degrees I would think, if you know when the Unilite breaks the coil circuit (trailing or leading, etc.). If you do that and things are close, then you can focus on getting the timing light to read the right wire. If you do that and things are still way off then you can continue being confused.
  8. It took 5 seconds for the first enormous picture to load and it was fuzzy and out of focus. Could be a factor for the low response rate. Plus the fact that those connectors are probably common to numerous years. And you've offered no clues that it's even a Nissan harness. Poor capitalization and formatting doesn't help either. Effort returned is generally proportional to effort put in. Add a little more and you'll probably get a few guesses.
  9. Which one and what does "burned joint" mean? Did you have a short between two components in the ECU or an open circuit? Pass on a little good information for the next guy.
  10. I'm no expert but I don't think that you have a good blend of parts for a well-functioning turbo engine. The stock EFI won't handle a turbo very well, and the Stage 3 cam is an NA cam, for example. The stock injectors won't supply enough fuel unless you crank up the fuel pressure, which will make everything rich off-boost. It would probably never run right. This thread is worth reading - http://forums.hybridz.org/index.php/topic/50208-the-ultimate-l28et-guidewhat-you-need-for-350whp/
  11. It's just a guessing game without a timing light. The timing of the spark is determined by the orientation of the reluctor (six-pointed piece on the top of the shaft) to the pickup coil. The orientation of the rotor just determines which plug gets the spark.
  12. I have some Tokicos (but they're red) and the part number stamped on the spring has an F and an R at the end to signify front and back. 5022-F and 5022-R. I think that MSA sells blue springs like those. They might be MSA. That doesn't really help you though, does it? Still, I would expect some ID numbers on them.
  13. It seems to follow then that bracing the core support would make the car more rigid. Does the core support flexing come from overall chassis flexing or just the weight of the front end hanging on it? And I assume/guess the flexing is seen mostly at driving extremes since the stock radiator is solidly mounted. Does the flexing contribute to early failure of stock radiators? I just replaced mine and wondered as I installed it. Collecting ideas on simple ways to get a stiffer chassis.
  14. People were probably waiting to see if it was the four cocktails talking or something more. If you put your Trailblazer shoes on don't be an Oden and fall apart before you really get started (it's a Portland reference).
  15. I don't know exactly what "does not work" means in your case, but I had a tach that stopped working after I did some ignition work (swapped my 1978 Z coil for a Z31 coil). The needle would just dance around at ~1000 RPM, obviously getting some impulses from the coil but not able to use them. I attached a condenser/capacitor to the negative post of the coil on the theory that I had some electrical noise on the blue wire to the tach. It fixed the problem, tach works perfectly and has for ~6-8 months, but I couldn't go very deep in to why.
  16. I think I see the disconnect here. I've been focused on the CAS and how to test that it's sending the proper signal to the ECU/ECCS. That's where I would be if I had Francisco's problem, make sure that the individual components are sending the proper signals or have the proper functions for the ECU to do its "job". You are right, there is a list of tests for a variety of components. But there is none for testing the function of the CAS alone (that I can find). For the 280Z's for example, there is a procedure to measure the resistance of the pickup coil in the distributor to at least confirm that it's not shorted or broken. But for the 1981 turbo system, there seems to be an assumption that the CAS always works, or they just overlooked the fact that it might break at some time. Even the ECCS Analyzer says to have the engine running, to test the CAS. But nothing is mentioned about confirming that the CAS actually works correctly. Adjusting the position is important but only if you know that the CAS works. Anyway, we're kind of in to the philosophy of problem solving now. Personally, I'd like to be able to test every circuit in the ECU individually,pin by pin along with all of the individual components. I love the 280Z FSMs. The ZX FSMs seem to the start of the trend toward the "replace components until engine runs" philosophy that a lot of today's cars use.
  17. You're right CG, the ECCS wiring diagram is there. I missed it, got stuck in the first half of the chapter. Although, I see it's not the typical VR pickup like a Z's electronic distributor. There's power supplied to certain pins, like Pin 40, and two to the ECU alone, maybe powered, maybe not. I still don't see a troubleshooting method, or a way to verify correct function of the components, without the ECCS Analyzer, or more inside knowledge. Good luck Francisco! Would still like to see the EL section.
  18. Edit - Now I feel kind of bad. After referring Francisco to the xenons130 site for the FSM and the Turbo Supplement, I realize that the site download for the Turbo Supplement doesn't contain the most critical document, the EL chapter. Without that chapter, troubleshooting an 81 turbo is very difficult. If someone knows another source for the EL chapter, I'd like to have it myself, for future reference. I have to admit, the 1981 instructions are difficult to decipher. Nissan designed a magic ECCS analyzer and if you don't have it, you have to put your engineer hat on and try to figure things out. And I looked and can't find the wiring for the ECCS or CECU system anywhere. Isn't the 81 CAS a VR type? The basic test is resistance of the pickup coil. More involved would be watching for voltage while running a tooth past the CAS, or spinning the engine. You could at least do some simple tests. You should do them before you install the new parts anyway, otherwise you'll do a lot of parts replacement and probably end up in the same situation. Look at page EF-32 to get some ideas. Find the wiring diagram for the CAS, if you can, and measure resistance across the pickup coils. Make sure that clearances described on EF-32 and -33 for CAS adjustment are correct. Looks like a pain in the butt.
  19. Your pictures seem to show everything except the rust you mentioned, through the door skin and the rotten rails under the car. Maybe I'm not good at looking at internet pictures but I don't see a lot of deep rust damage. Lots of surface rust, but no major holes. My 76 has a row of rust holes along the bottom third of the both doors but the rest of the car is solid. I think that Nissan's design for keeping water out of the doors was poor. The car might be fine except for the doors, and might be a good buy. I don't see where it's "toast" at all. Floor pans and under the battery are common rust spots, that can rust completely away. Check those out. Take a picture of the rusted out frame rails. Look in the spare tire well for rust. Check the fuse box area for rust and corrosion that would indicate water got in that could affect the wiring. You said it runs but does it drive? Things like brake cylinders, calipers, clutch and brake master cylinders, clutch slave cylinder, etc. will nickel and dime you in to the hundreds for sure, maybe thousands more.
  20. The "help asap!" in your title is funny since there's not much useful information in your post. It's a rusty 1973 240Z with a replacement L28 running carbs, for an unknown price. What advice could an expert offer?
  21. Just curious and trying to learn something new. I see some things in your setup that don't seem to fit the average MS II setup and have a few questons. What Nissan mechanical book are you using and what is the number for the maximum that it says you can shave? Is it the stock P90 or P90A head? Have you calculated the compression ratio? Why are you using a 280Z distributor? Is it locked? Do you still have a CAS somewhere? What, exactly, are the timing numbers - initial, advance curves, etc.? If you're using MS II for timing, timing "by the book" doesn't really mean much, unless you're just talking about the static timing. Plus the basic stuff like type of gas being used and if this is for the track or for street. Also, seems like if you could supply AFR and timing curves, they would help out to use for feedback. As I said, just trying to learn something myself. You might be focusing on the wrong thing.
  22. Post 14, the OP, the one whose problems are being discussed, has "MS2357-C $444 Assembled Megasquirt-II with V3.57 PCB". megasquirt 1 is a irrelevant.
  23. Some of the Z's run the Brake Check Lamp Warning Relay power through the regulator. On the 76 cars you can end up with the relay powered all of the time after wiring for the conversion. This will kill your battery in a day or two. You can confirm by listening for the click of the relay, under the passenger seat, when you disconnect and reconnect the battery. 76 has the voltmeter instead of ammeter though, so the wiring may not be the same for the check relay. Something to look out for though if your battery starts dying.
  24. You can see the cable in the bottom of the picture. Looks like it might need a collar fabricated to hold the end of the sheath but if the cable end fits the actuating arm and it will reach you might be able to make it work.
  25. You could have at least copied the replies from your other thread over also. Many auto stores will read your trouble codes for free. (From your other thread). Sounds like a short circuit somewhere, unless the AC system is computer controlled.
