Z Car weights
Had the chance to weigh the Z contingent at the track last weekend. Here are the results. Please post your weights in a similar manner if you have verified it on an accurate scale.
All cars listed have full interior.
1970 240Z L28, 14x7" panasports, basically stock otherwise: 2310lbs
1973 240Z L31, 15x7" enkei, 4runner vented brakes, heavy seats, R160LSD, 5 spd:2420lbs
1972 240z L28T 15x7" enkei, heavy recaros, R200, roll bar, big IC: 2440lbs
1973 240Z L28, 15x6" swastikas, R200, 5 spd, Volvo vented front brakes: 2460lbs
1975 280Z L28, 14x7" turbines, triple carbs, no bumpers, otherwise stock: 2560lbs
Guest ON3GO
1977 280z - L28ET, starion fmic, a/c, rx7 FD seats, no bumpers or supports, full 3in exhaust, 15x8 enkei 92 wheels.. like 1/4th tank.. 2580lbs.
mike
Guest zfan
1971 240Z with 700r4,9.5 converter,385 sbc, aluminum heads, intake,water pump, radiator,r200 lsd, 300zxt axles,motorsport brakes,6 point cage,full interior,17x7 konig rims,drive shaft & axle loops, strut tower braces,amp,sub & box.
And now for the drumroll:...2640 lbs---What a FAT PIG!
No wonder I can't get her into the 10's!
Mike
71 240 Z (built for GT-2)
Glass nose
Glass doors
Glass hatch
lexan windows
Basic cage
280Z engine (9 pound flywheel)
13 inch formula atlantic racing slicks
2 gallons gas
1850 before ballast
75 Tube80Z (built for SCCA soloII EM)
Ford 5.0 Aluminum heads, manifold, etc.
T5 with dog ring conversion
most of above body work
2 gallons gas
1620
1972 240Z
2JZ-GTE Stock turbos
V160 Getrag 6 speed
15 pound flywheel (vs 33lbs)
3 gallons of gas
22 gallon steel fuel cell
3.5" exhaust
Massive intercooler
small battery pc680
Big (-x) griffin rad
14 x 6
14 x 7
interior but no dash
2530 lbs
1973 240Z
gutted
roll bar
all steel body
reinforced floors and footwells, seam welded
Glass windsheild and hatch
5 Gal AL fuel tank, full
L28 N/A motor/triples/headers/2.5" exhaust
R190 4.44 LSD, 5 speed, Tilton flywheel, Quartermaster clutch
2 Kirkey aluminum seats
16X10 Real 3 piece wheels
1989# before ballast, with heavy DOT R tires
71 240z (early)
83turbo motor
240sx 5 speed
fiberglass fenders
fiberglass quarters laid over the rusty quarters
no interior (just a seat and a dash)
old school 14x6 webs
R200
Koni's and ST springs with MSA front and rear bars
sump'd gas tank
2180 with about half a tank of gas and no driver weighed at the last SEZ
Guest zfan
They have scales at Ennis, Tx. NHRA drag strip. If you do not have that option you could go to your local or nearest truck scales. Also to the dumps or to a rock/soil sales place that sells by the pound/load.
Mike
These numbers are very encouraging... Notice those with Roll cages, sub-frame mods and full interiors are still in the sub-2700# range... That is truly amazing. This weight figure is the sole key to the advantage of a datsun Zcar in my opinion.
Mike
Guest bastaad525
'72 240z
L28 motor (F54/N42)
SU's
Headers
nissan 5 speed
R200 diff
ZX radiator
full interior
ZX four spoke "cross" 14" wheels
5-6 gallons of gas
spare tire
large mechanical jack (not 'scissor' jack)
small tool set (approx 10 lbs)
2320 lbs (guessing about 2280lbs 'dry' weight?)
Haven't weighed it since the turbo swap... guessing about 2400 though if I take all the extra crap out.
My 1977 280Z weighed 2800 lbs even with 3/4 tank of gas when it was completely stock except for an '83 T-5. It was 1400 lbs on each end.
After the LS1/T56 conversion it was 2830 lbs - with the extra 30 lbs on the rear. I have not yet had it back on the scale since I aded the roll bar, strut tower braces, the custom interior, and the brake upgrade. Guess I need to figure out where I am now.
My totally stock 1983 280ZX weighed 1430 on the nose and 1450 on the tail for 2880 lbs total. - with 3/4 tank of fuel.
Well.. lets see.
1978 280
12 point chromemoly cage.
16 point adj and not adj bracing (cold rolled steel mostly)
subframe mods for turbo clearance
steering mods for turbo clearance.
17x11 and 17x8 Simmons 3 piece wheels and large rubber to go with it.
R200lsd plus bracing.
1.25" front sway bar
1" rear.
Full interior
VG30ET
power nothing, no air etc
hand made fibreglass body.
All Aluminum front belly pan
All aluminum rear diffuser
Dual 4 point harnesses
Stereo and speaker box.
2900 lbs even.
