    33131
    5167
    Rice
    Rice
  1. Past hour
  2. ordered a 9" air cleaner and I decided I didn't want it chromed AND the sniper to be polished, so I took it to a local guy and had it blasted and powder coated gloss black to set off the sniper a bit. the bottom ring is only powdered where it can be seen, as it won't fit on the mouth of the sniper if the powder is on there...too thick. I think it will look ready good and contrast the polished stuff.
  3. This thread is ancient so I'm just posting in case others come along in search of a solution. If you install the MSD 8920 as indicated by the OP and the tach only reads 200 rpm, here is what fixed it for me. At issue, reverse the wires to the tach. Connect B/W wire to red going to the 8920 and connect G/W to 12V switched. After this my tach was happy.
  4. Yesterday
  5. I used to run this: https://www.thezstore.com/product/6551/tension-rod-t-c-kit-70-8-87-240z-260z-280z-280zx-300zx It worked pretty well. I have since gone to rod ends and a clevis.
  6. NO!!! Actually it seems well suited to a billet solution and I can't compete with billet solutions. The only reason I can play in this arena with my equipment is leveraging my pattern making abilities.
  7. Hello everyone, I’ve been looking all over but haven’t really found the answer I’ve been looking for. I just bought my first Z (1977 280z 5 speed) and noticed I have two different keys and no spares. I suspect the door locks have been changed at some point. As you can imagine I would like to open everything with only one key. Does anybody know where to buy a full lock kit with matching keys? So that’s for the doors, hatch and ignition. Or can I rekey the original locks? I can’t seem to find matching locks online but I did find lock sets for Datsun 720, 510 and 280zx. Does anybody know if I can make one fit a 1977 280z?
  8. Actually it's rubber in the back, poly in the front. The front bushing takes the force under braking on the Z's, under compression, and is the one that you don't want compressing too much, making the steering squishy. But the poly should not have split. It does take a lot of side forces as the rod moves up and down with the suspension. But usually it causes the rod end to fatigue and break off. Seems like you got a bad batch of polyurethane. Bad chemistry, or a knockoff.
  9. Last week
  10. I have a 280z that I recently finished building. On the tension rods I installed brand new bushings. Rubber on the front side and poly on the back, as I believe was recommended by several people here. Torqued the nut to 40ftlbs. I was just under the car for something else and noticed that the rear bushings on both sides are split very badly. This is after only about 10 miles of driving. Wondering how this could be. I will switch the rear bushings to rubber but still want to know how this could have happened. Comments welcome
  11. Just got home with the car and finally took it a good run around the block as the registration is suspended at the moment. The seller told me it didn't pass inspection as the car was running rich. I did notice there was a wideband sensor and a crank angle sensor installed but not connected to anything. Maybe it was used to tune the engine? The car isn't perfect but I did get it for a pretty good price. The bodywork isn't all straight, I suspect it had some damage to the rear at some point in time. The hood latch cable has popped out of place so the hood won't open anymore (why did I close it all the way). The passenger door isn't lined up properly, it only closes with force and the bottom rear part of the door sticks out a bit. And the car sweats some oil (pretty much everywhere). But all in all I'm happy at the moment as it has new wheels and tires (got the original wheels with almost new tires with the car) and it drives pretty good even though it's running rich. Clutch and brakes work very good and even all the electrical works. I did notice some nice goodies too. The car has some kind of aftermarket suspension I think and a brand new wooden steering wheel with NRG adapter. It is indeed a 5 speed and has the R200 rear end. I'll look some more into the forum and will probably start a build series documenting the car as I have no documentation what so ever.
  12. Who said anything about stock??? Its turbo'd but the the overdrive in the auto is .686 and a 3.7 rear end. It goes 80mph at 3k with the ac blowing cold and will stay cool even in 100 deg heat. But thanks. I think im gonna just have to buy one to try
  13. I'm sure I'm far too late, but taking a magnet with to check for structural bondo is a good thing to do. You never know what someone has hidden behind paint.
  14. Welcome to the forum, and congratulations on your new purchase. She looks like a beauty...the late-model 280 with a 5 speed is a desirable combination for a street car that gets driven often. While not as functional as the usual heavy 5mph bumpers, the thin bumpers are much nicer looking IMHO. I'd be interested to know what differential the car has (an R200 would be nice, but certainly not necessary). Unless you're planning to upgrade the front brakes and get a larger master cylinder (and track the car), rear disc brakes are really not necessary. The stock aluminum drum brakes on the rear are more than adequate for any street driving...and even the occasional auto-x or time trial event. There are several good discussions here on how to maximize performance from the stock rear drums. Lots of good forums and groups on social media for the S30; but another forum I like is ClassicZCars.com, especially for information on original restorations. Good luck with your planned mods & upgrades, and please keep the updates coming!! 👍
  15. Hello everyone! I'm new to this forum and today I'll be picking up my very first Z. It's a silver 1977 280z coupe with a 5 speed manual gearbox. Any recommendations of what I should be looking for? I bought the car site unseen at an auction. Yeah I know, not the greatest idea but I got a good deal on the car. I do know from a dealer I saw the car at a while back that the frame rails might have some rust spots but the seller listed the car as "free from rust and structural damage". Luckily the seller won't get his money until we bother agree the car is as advertised so I can still low-ball the shit out of hem. (The seller was bragging to the dealer how he would make a massive payday trough the auctions the dealer told me. But guess what, he lost money on it) My plans for the car are to just get it road worthy for now and then upgrading it over time. I was thinking about rear disk brakes, ITB's with new engine management and some carbon fiber body parts like the hood, fender flares, spoiler and aero bumper. After the cosmetic upgrades I'll be painting the car Nissan Midnight Blue as I just love the color. And yes the car is loosely inspired by the anime Wangan Midnight I saw when I was a kid. Call me a week but it was my first interaction with the S30 chassis and I loved them ever since.
  16. I got mega burned by Apex on the rear track attack. Was one of the first buyers of it and back then it didn't even have enough parts to even bolt it to the car. The design of the rear kit is just for looks. Much feedback was given to them in how to improve it, but it was widely ignored. Shame because the cradle design is a good base to start off of.
  17. On my C&R (Jeirco knockoff) I have a two-piece shifter similar to the original Datsun version or a T-5 shifter where only the handle needs to be removed. The C&R has all the linkage on top, so you have more side clearance, but it is exactly the same three-rod shift fork linkage as the Jerico. Bummer the clutch plate is still catching on the flywheel bolts.
  18. Final reference pictures of the rerouted SS -8 and -10 fuel hardline bracketry around the Escort member. I left enough room to run twin -12 but the main choke point is around the massive CD trans. Also for those that asked about the FPG in-tank surge tank bracketry I haven't forgotten have just been busy. The design was finalized along with a custom level sender arrangement and the prototype went for manufacturing a week or two ago so I'll provide more details when I get back to it.
  19. "Oil Can Repair" on Rar Hatch Panel- "Oil Can Repair" on the Rear Hatch Panel is common problem on 240z. The factory tried to solve the problem by adding addition sheet metal around the lock assembly. unfortunately, this(in most cases) was not sufficient to prevent the problem. The problem is aggravated by the push style hatch lock that is utilized. The lock uses a pushing down movement to operate the hatch release. Imagine a 200 plus man forcing his weight on 23 gauge Flat piece of sheet metal opening his hatch. This video shows one method od solving this problem.
  20. Yes I have both. And bleeding the clutch is as simple as opening the bleed screw, let a few drips out, and tighten. The thing that takes longest now is removing that giant shifter and the 3 shift rods. And adjusting shift throws when reinstalling. 3 bolts hold shifter and 2 rod ends per shift rod. I can't find a better way to speed it up. AND I cranked the car Saturday and the clutch is close but still not fully released. So another round is coming.
  21. It was the rear main seal leaking, I removed the transmission and could clearly see the oil around the seal:
  22. The turbo lamik stuff is very trick, and it has a lot of potential. The weight is a downside, but it's low and centered. I have a buddy who just put one in his 2JZ swapped FC RX-7, and he didn't have to touch the tunnel. There are a couple guys on IG as well who have swapped these in with good success. I think compared to the T56's they are only slightly heavier, but much stronger and have nicer ratios.
  23. Transport is booked for next week so this weekend has been misc. final prep. Bunch of random bodywork to minimize filler and some fab/welding, but here's some highlights. I finished clearancing the diff front member for the twin 60mm exhaust. I also clearanced the area around the snout as I will be taking VSS signal for the speedhut speedbox. After some further measurement I'll be vbanding the entire exhaust again as I can gain maybe another 1/4-1/2" ground clearance by reconfiguring the angles over the existing slip joint configuration. As is I think it is similar or better clearance around the diff than the 3" pipe I had tucked there before. Re-fit the AL driveshaft and confirmed my suspicion that the Escort member moved the diff forward ~1/2". Not a big deal but need to remember to re-check the axle plunge depth and shorten the DS if necessary when the time comes. Also marked out where the DS interferes with the factory xmember so will plate in and weld that out later. Finally I've been seeing a lot of very very nicely done s30s in person lately to get an idea of bodywork problem areas and things the owners would have done differently. One area was the rear valence around the exhaust, specifically exhaust was fitted later and required trimming of the rear valence on a finished car. So I went ahead and trimmed out the rear valence accounting for exhaust movement and duplicated the shape on the pass side for symmetry. Worked out a bunch of other fine details as well and at the end of the day it's an imperfect 50 year old car but needing to bash things in or cut things out after a bare metal respray would drive me nuts. It's been a journey but I've met some really cool people and seen some absolutely heavy hitter s30 builds this past few weeks.
  24. Pretty cool https://www.seikowatches.com/us-en/products/prospex/special/datsun_limited/
  25. Looking good. Seems like that's always some of the most rewarding parts of any resto....getting all those hard-to-access areas cleaned up, rust repaired, straightened/strengthened/reinforced, and freshly painted. 👍
