24
Everything posted by madkaw
Wonder if my floats are just a tad on the lean side and the prolonged run on the dyno put them over too lean?
The guy has never sent me the email with the sheet
Leon, Same dyno, same operator. He said I was running lean though my Innovate showed around 13+. He ran his sniffer at the tail pipe and said it might show lean, but than said I WAS lean. WOT runs on the highway showed spot on. The car has never run stronger and better. Since last dyno I reduced the chambers to 39cc but now run an ISKY 490/290 vs. 480/274 Schneider. i am going to a different dyno next time because of location , so I will compare. I was running 150 mains and 180 airs during dyno. First run I noticed my AFR peg lean deep into the run. Never happened on the road like that. Something to do with the slow ramp up in rpms? It seemed to take forever to get to 6500 on the dyno. Could he have had a setting wrong?
Been a while , but I guess that's a good thing. Car has really been running well . Went to the dyno and got lack luster results. Basically dyno numbers weren't much different than running SU's - about 150hp. The few Z owners I know can't believe that it's only 150 the way the car performs. Anyhow , I was considering larger chokes. I stated earlier in the thread that I had 34's, but they are just 32's. This Mikuni package was part of a complete street kit. This was meant to bolt on to a stock motor so 32's were plenty. I think those 32's are choking me up a bit and wanted to bigger. None available . So you guys that have machines out your 32 's to a bigger size - tell me about it. I was considering 35mm since my ports are only about that big anyway. Don't know how thin that makes the venturis? Is this something any machine shop could be trusted to do? Also installing a .6mm HG to pump things up a bit.
Your lightweight flywheel experience?
madkaw replied to Newoldschool's topic in S30 Series - 240z, 260z, 280z
240mm flywheel cut down to 17lbs . Very responsive with exedy stage 2 clutch I believe . Very drivable -
Got it figured out I believe. See the pics , but the pintle caps supplied in Pallnets kit work fine -operator error here:) I just didn't have the pintle caps all the way on, they need to be tapped all the way on the pintle until seated. Then you use the spacer and O-ring supplied . I had no odd what I was doing, so it probably would have been more obvious to most. The pintle that came with the injectors is too wide to clear the hole and keeps the O-ring from sealing- gray pintle cap.
NA 3.1L=>head & camshaft questions. No shortcuts, max
madkaw replied to zredbaron's topic in Nissan L6 Forum
Dave is adamant about the poor rod / stroke ratio of the L24 rods. He convinced me to have my crank offset ground. My concern was grinding on the journals would limit rebuilds , but not so since he uses a standard Honda bearing size. He has other magic he also performs with the journals. Can't wait to be there. The sound of your motor was great, but was it about rod/stroke or just a radical cam and open exhaust? Your videos inspired me to want to have a big bore -big cam motor -
That sucks. Now your budget just took another hit. $$ for those crankshafts. Dave have any at Rebello? Just talked to Dave the other day about my 3.2 build. -
Don't know if I can help you with your specific questions - especially the transmission . I thought the zx trans were all vacuum controlled , no ECU control, so that shows you what I know-lol. I think most of the platforms are the same with the MS units, I think any MS would be better than stock ECU. I actually used some of the relays and such from a ZXT for my MS install. All I can say is that when you think you've read enough about MS , go back and read more
And putting MS in parallel with stock ECU- why? Have you read some of the installs on hybridz- like mine on the MS3x?
I'd say by listening to your question you have more learning to do . They probably recommended the SlimJim based on your knowledge . Did I use one- no- but spend days and days studying and Reading MS manuals . Because you know how to solder you can put a circuit board together ? And please use punctuation when posting so we can understand you.
One hot wire for power, don't have heat yet
Just finished 350z power , heated , leather seats. Really like the seats and yes it's tight. Managed to get drivers seat low enough to sit in there with a helmet on. I'm 6'2", so pretty happy with that. Yes they are a bit heavy and yes I would have preferred manual seats , but the price was too good to pass up and the stitching matches my car-lol
The injector does fit in the hole better with the other Oring and pintle . Though the Oring does not go all the way in the injector bore , it does look like it seals at the top. You do have to pull the injector out of there after seating it and the Oring shows a even mark around the edge like it is sealing . There really isn't anymore room for the injector body to seat since it is almost against the bosses on the runner now. The long pintle concerns me because the hole sits off of the injector spray holes. There is a gap between the pintle opening and injector nozzles, so will that impede the spray ? I guess I could run without the pintle caps also?
So I've read on line that folks just change out the pintle and O-ring on a 14mm injector at the manifold side to a smaller Oring to fit a 11mm hole. I bought a 14mm fuel rail from Pallnet and want to use it on my n42 intake. He sent me a "hybrid" seal kit with the rail, but not sure how it works. The pintle cap he supplied is longer than the one that came with my Bosch injector, but the O- ring is the same size , or very close. The O-ring is too big to fit in the manifold hole, just kind of seals it off sitting in the chamfer of the hole. So what am I missing here. It seems the O-ring should be smaller to allow to slide all the way in. I've never messed with injectors so I am an idiot when it comes to this. I did cut off the Bosch pintle cap and the one Pallnet supplied snapped on there, but couldn't use the spacer , just the Oring .
Right now I run a CJ-5 tank in the same location. I didn't need a fuel cell since I'm not racing mine. It is a plastic tank with metal cage. I also wanted to keep the fill point at stock location. Don't want fuel in my hatch. Getting ready to convert to FI and might change out my tank for a fully baffled steel one from Tank.inc . They also sell tanks with various filler necks to keep stock fueling. As far as fuel pump, just ordered a Delco OEM pump for a F-150. External pump with OEM reliability . Fuel inc. sells the tank with Walbro pump for about 400$
Kind of went thru a similar situation with a buddy and his fresh rebuilt L24. After the engine was warm it would rattle like detonation at around 2500-3000 rpm. We did every thing timing including a different dizzy. Tore the motor down for fear of damage. A different engine shop looked at and determined the bores were over honed and left too much piston clearance. The original engine shop tried to save original bore size and bones the sh!t out of it. I think it was like 6-8 thou over spec. Couldn't find any other reason for the sound. Engine is NOT back together yet. The bores looked like crap for what little miles it had on it.
They wouldn't ship?
Comparison different valves quality
madkaw replied to Ssaga's topic in S30 Series - 240z, 260z, 280z
I would also recommend stock ones in good shape! -
Might have luck on eBay . I found old new stock Fuji valves pretty cheap. My machinist didn't like those SI valves . Something about the hardness not up to snuff -
CONFIRMED L28 with RB25 Flywheel and 350Z Clutch
madkaw replied to 83turbo280zx's topic in Nissan L6 Forum
I have both trans - can I help by measuring something? -
Great ! Options!! -
I saw the pics of this head and its just a stock 42 chamber. I thought it was curious that it had this copper sealing on a basically stock chamber. Maybe had high CR pistons and was running race gas?
Not for nothing, but it seems like a lot of work when you can get the stock tach to work pretty easily with a tach adapter. For the most part I've read that the OEM tachs are pretty damn accurate and some can be adjusted. Buy a 50$ tach adapter and wire it and done. It will look stock and match the rest of your gauges if still using OEM. Since I have had my adapter on there it has worked flawlessly with the MS3X. Didn't you post that you couldn't get your tach to work before? Might give the wiring another try. It will a ton easier and faster than retrofitting something else. just saying...
That will have some compresson with the MN47 head.
