madkaw
    27
Everything posted by madkaw
  1. Looks good. I see you are in Edwardsville. I stay at the double tree in collinsville all the time for work
  2. Did you try the z32 trans threads? I thought I was reading about that the other day
  3. I have read a lot of bad poop on the MSD, so sorry to hear about your pain. I will give a shameless plug for my e-12 set-up for sale, it works great!!!!!!!!!!! I don't know about MSD's but from what I have read. I know they are sensitive to voltage issues, so make sure everything relating to charging and grounds is solid.
  4. Silly question but could you have mixed them up? Did you try swapping them?
  5. Hey thanks for the heads up. I just looked at the website and looks like the way to go for a DS
  6. I have ordered another length of fuel rail and I am going to re drill the rail to align with the port holes better. I'm going to shorten all the barb fittings and hope to get total length of rubber lines down to less then 2". I guess Jeff P manifold wasn't a bad idea after all. I just want to get rid of all the hoses across my pretty Mikunis. Hoping to have enough hose between the barb fittings to be able to pinch them shut for syncing. Yes I have read of the filter to modify the signal. MS actually has a set up for ITB speed density tuning. I need to do more reading Need to do more tuning too. Maybe next week I will make it to the dyno
  7. Still plugging away at this. I have been wanting to go to a trans shop for them to give me an opinion about the side play. I know the owner thru a friend so I think I can plan on an honest assessment. I also wonder if I sized the DS too short and it sits too far off the tailshaft allowing for play. I looked at another T-5(out of a car) and tried the DS in it, and depending on how far the splines were meshed was directly related to the play. It seemed that the yoke had to be all the way up on the spline to eliminate play. But what play amount is normal or tolerable? I don't know so i am taking it to a trans guy. Thru searching I have found similiar issues, but usually yoke not properly centered on the DS. My DS was made by a DS shop and I have taken it back for verification of balance.
  8. Still confused of what you are trying to accomplish here. The "tune" is not what's going to be a problem, it's getting the MS properly set-up and working with no glitches. Like said above, having a reliable and understandable rpm signal and proper wiring and a strong understanding of the MS will be your advantage. I'd say once you have tuned with the NA motor and then added turbo mods you will be ready to drop in any motor. Timing will be everything---especially with a turbo motor, so a good understanding of speed density tuning or whatever you are using is priority.
  9. Very Cool! I imagined doing a project like this a while ago, but wasn't sure how one would pull it off. I like your approach, subtle. Watching with interest
  10. Not sure what the OP is asking, but this is sound advice from Metro. Get the MS working flawlessly on the NA first, especially idle and start. You are actually doing what I am doing now. I am installing MS 3 on my L24 witth Mikuni's-then eventually FI turbo. Ignition seems to be the problem with most installs. I will add that there is another option for rpm signal-might check my thread
  11. Well soldering was almost too easy -once I found a method, which was less solder the better. I found holding a small iron against the hole for a bit then tinning the tip slightly and smearing it over the hole worked best. I used a minature fine file and then some fine sandpaper to smooth everything out
  12. Ditch the bumper AND the indents
  13. The dash is at the fabricator now. I left it with him so he can poke and prod it for a while. After showing me the custom dash he made for a race Porsche I was impressed with his skills. We both agreed that te metal frame will stay. It just makes everything easier and more affordable and have a greater mass appeal for the DIYer. I will keep this updated as I started a thread on a FG dash.
  14. Ditch the rear bumper to show off the sexy Z lines!
  15. Wait-the last post said you had the car running poorly and now you are off the dyno?
  16. Because they can be easily cut-out for those who need it, and those who don't(this is hybridz) can have a solid smooth console with just a shifter hole.
  17. Still surprised that the dyno didn't have an O2 sensor to give you AFRs on your run. Every dyno I've seen has that.
  18. Soldered everything in the engine bay. I had a 8 ft harness so plenty of wire to work with. Examples of what you are soldering? I did the complete LS1 coil wiring on the fender
  19. I can't figure out what you are asking? Did you look at my thread? I ran the harness thru the old AC cutouts
  20. I am meeting with the fabricator this week end to talk about making a replacement FG dash for the 240z model only right now. The meeting will be to discuss how we want to make this work as far as structure and materials. In discussions on the phone it seems for now that the original steel backer will be retained to ease fabrication time and to insure easy R&R for a stock fit. Materials will have options. We talked about a standard FG option that would reduce cost and give folks that want a stock looking dash a replacement that is permanent and tough. It could be easily painted with texture painted to duplicate the factory look. Installation would involve removing your existing dash and separating the metal backer and installing it on the new dash. The metal backer(frame) would screw into new FG dash just like the old one.. More then likely the heater panel hole and glove box hole will be blanked and have to be cut out, pretty easy. The CF option would be more expensive and also would have additional add-ons. The add-ons would be in a glove box door that matches and possibly the wiper panel too. We are also going to discuss the center console and a CF option for it. He said that he can use the same mold for either FG option will help reduce cost. This process is just getting started so no prices yet. This dash is being set-up to be an EXACT copy, so there won't be any special options for gauges or such. In needs to appeal to the masses to make this worth while. The racers could easily have the option of leaving the glove box and heater blanked for gauge options or whatever. As stated earlier I am interested in a center console also. More then likely it would retain the original shape but have options as far as gear shifter hole location. It would probably eliminate any smaller holes for the choke levers. Any suggestions to discuss with the console? keep you guys updated
  21. Just trying to find something you've done half assed so it will make me feel better- lol People call me a perfectionist and I couldn't hold a candle to you. It's a shame only a few qualified individuals will understand the level of work your doing. You have to do this level of work for yourself. Very entertaining , thank you for the detail of sharing
  22. When I did my coil test I just laid the spark plug outside the hole and watched the fireworks! I thought wasted COP was only for a set up like mine- wired like sequential but firing like wasted. Now have some fun tuning
  23. madkaw
    Ms3x install
    Also I should add that where I installed the coolant temp will not work. I guess I misunderstood how the coolant circulates. I thought coolant from the engine always circulated in the lines but were bypassed at the heater core when not needed. I only show engine temp when I have the heat on. So I guess I will install a ZX thermostat housing so I can have multiple sensors . This way I can keep my car gauge and also have my MS sensor in the same spot .
