Kash
Everything posted by Kash
  1. Have a nice one perfect for a rebuild...$50.00 shipped, let me know.
  2. $25 shipped, let me know...
  3. a little more on the z32TT pistons, pin height, will they sit above or below deck and compression ratio w/240 rods/stroker crank? Will this set-up drop your displacement to 3.0?
  4. You are correct...must have been low on sugar that day.
  5. depends..the zx has a lower 5th gear (better on gas) and the gears are closer while the 280z has a higher 1st gear (quicker off the line).
  6. It's ok to use one piston from another motor (turbo to turbo), just be sure to install a new set or rings and hone the block.
  7. Yeah, the S12 non vented version... Watch out for the slippery slope, I started out with just a simple turbo swap myself, thinking, why would I ever need more than 200hp in a 2800 pounder...but I have enjoyed every moment of it and would do it all over again.
  8. That's going to kill your max boost, send it my way...Great find man!
  9. I hate the search responses but a wealth of info is out there to help you with MS...good luck with the istall!
  10. Little spring oring points in, the flat/ flush side poins out, this allows you to tap it in.
  11. I have trans in great condition for $120 if you need a replacement.
  12. That's because they are in the land down under...has to be Nistune when I pull the trigger.
  13. Are you getting an ecu from the 280zxt? If so, why not a z31 ecu? This way you don't have to worry about the maf circuit.
  14. R34 RB26dett engine and trans...did you say christmas list or tax return:)
  15. The CCW's get my vote as the best looking set of wheels so far...they are perfect!
  16. Anyone has a copy of the pdf write-up to convert from "Pull" to Push type clutch? TIA
  17. Z-ya, that's some excellent work...that diagram belongs in a sticky some where.
