30
Everything posted by Zetsaz
Checked multiple dealers they had as well as amazon. Jegs seems to be the cheapest from what I've seen. Some guys on the jalopy forums who have lots of experience with it on multiple vehicles seem to say that it covers more area than they claim. @jpndave, I'll definitely take you up on using the stuff you have and buying you new stuff when I figure out how much it covers. If the interior really is this much smaller than some people have said, I might end up using only 2 gallons of the ceramic to get the right coating. Regardless, your 4 gallons will be more than I need and I'll happily order you a new batch of however much I end up using.
I can never seem to find accurate measurements of interior, and don't care much for over-estimating when ordering product or coming up short. Went ahead and took some rough and conservative measurements of the interior and added them up. Not that these measurements cover floors, roof, "trunk" space, doors and firewall, but do NOT cover the rear quarters. I did my best to measure things not accurately per se, but conservatively. Leaving room for error and extra material. Here's a sheet where I did my rough sketch. Not that I assumed the doors were square from their largest measurements, which I tried to do for everything. I included the transmission hump as part of my floor measurements. Everything was estimated on the high end. Total estimate after converting sq in to sq ft was 65 sq ft. Does that sound right? Some other threads I've read have said used over 100! Have I done some measurements wrong or is this just because of the wasted material from cut and stick types of insulation? I think 75-80 sq ft would be fairly accurate to cover a portion of the wheel wells and quarters. I used the Lizard Skin Coverage calculator and came up with 3 gallons of ceramic insulation and 3 gallons of sound control. Price total is close to $500 without their applicator. If I got this route, thankfully @jpndave is close and has used it before. For the cost of that much material, I'm definitely leaning towards just insulating with the ceramic heat material to cover everything, then down the road using the Dynamat Dynalite or another semi-lightweight, but much cheaper alternative to the LizardSkin Sound deadening. You can come to your own conclusions of what materials will be most cost effective for you based on these rough measurements or the estimates others have given of as high as 100sq ft or more if you're not being very careful about how you cut the mats.
A musician's therapist (The $300 Z)
Zetsaz replied to Zetsaz's topic in S30 Series - 240z, 260z, 280z
Before and in progress shots of the OEM fuel tank I've been trying to clean. I was conflicted about cutting into the new shell since it has solid metal all around. I was getting frustrated that OEM tanks were so expensive and I couldn't find any in junkyards. Was lucky enough to find this fairly straight but rusty (as they all are) tank out of New México. Ordered a POR15 sealing kit for it, but trying to get as much as possible cleaned up with the chain like some other guys have done on different projects and a LOT of vinegar. I think it's doing a great job. Trying to make sure I only drag the chain around and don't ram into pieces of the baffling. I'm removing the sending unit any time I need to slosh things around and break stuff loose with the chain so I don't break it. Making progress! Goal is to get the new shell on refreshed suspension and working brakes at a bare minimum by the end of July so I can take it to Washington with me and actually make progress. -
Small progress today on getting the new shell moving. Chopped the spindles to mate the coilovers to and split apart the entire suspension. Will be redoing the rear wheel bearings while I have anything apart. Took the rear pieces to a shop a block from my folks' house to have the spindle pins pressed out. Will be pulling them and putting antiseize or swapping out for the grade 8 bolts some people have used instead. Don't want to have to deal with stuck spindle pins down the road and take everything apart again when I decide to upgrade the rear arms. Will need to figure something out for my seat rails since none were replaced when the floors were redone on my new shell. Past owner was going to use racing seats in a lower position so the originals weren't needed. Still deciding whether I want to take the time to make some shorter custom mounts or cut the floor mounts out of the old shell when I'm ready to move everything over.... will have to think it over while I'm finishing the coilover upgrade and brakes. -
Can't help there... closest I've seen to what you're describing is someone welded another piece of 1x2 at an angle from the top mounts. Not much difference between that and what I assume you have other than creating a more fixed point for the "front side" of the fuel tank to sit against and creating short straps.
Regular Car Review has been part of my Monday routine for years now. This one was pretty good, mostly because there were SO many of them and so many had such identical mods haha.
I did the same thing. Going with an original tank now, but if I'd kept the camaro tank I'd just cut whatever you have just outside of where your tank straps/mounts are then weld that to new pieces that run side to side. Essentially you're just shortening the piece you already have mounted to the car then running it to new pieces that go side to side so any impacts don't instantly mess with your tank mounts and cause serous problems.
Ford Super 8.8 irs swap thread. Rear brakes too
Zetsaz replied to Invincibleextremes's topic in Drivetrain
Not directly related, but are you posting your progress on that bike anywhere?- 280 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Would love to! Highly unlikely that I'll be able to do it this summer since I just got that new shell haha.
Clarifying one piece of info.... aside from the axles being thinner, the Rock Auto CVs would basically just allow you to weld in the adapters, grind down the stub axle, and bold them right in?
Depending on how things go this summer, I might be interested in the September dates
Will a 280z 2+2 work as a donor car for a 280z?
Zetsaz replied to nubkidZ's topic in S30 Series - 240z, 260z, 280z
Like others have said, from the doors back just about everything is different. The only thing you can really use at the rear is the lights, suspension, diff, fuel tank, vapor tank, filler neck, filler door... basically anything that's not a body or interior panel. Of the stuff you've mentioned, the dash, front seats, and gauges would be the same. -
S30 RB25DET T4 Twin Scroll Turbo Manifold Design
Zetsaz replied to Jeff9727's topic in Fabrication / Welding
@seattlejester -
Anybody Know Anything About This Z-Car Design Drawing?
Zetsaz replied to wrenchtech's topic in Body Kits & Paint
I got it. If you quote any part of anyone's post they'll receive a notification. You can also tag now like this @wrenchtech -
Progress on my insane VQ35HR 240Z project
Zetsaz replied to markrolston@mac.com's topic in Nissan V6 Forum
One of the best. I love the molded flares and the subtle approach you've taken to the exterior appearance. -
They have two others that are more common, one with a blunt nose, and one with a G nose style front -
That was an old rendering for the Carbon Signal kit https://www.facebook.com/pg/carbonsignal1/photos/?tab=album&album_id=942013415847778 -
Measurements for CD009 and R154 and trans tunnel
Zetsaz replied to seattlejester's topic in Toyota L6 Forum
That mounting point on the top side of the piece I gave you is the original fuse box and the smaller side farther to the passenger side should be the cigarette lighter -
Transmission Tunnel Measurement for 240z
Zetsaz replied to seattlejester's topic in S30 Series - 240z, 260z, 280z
If you don't get a response you can give me what you have from the bolt holes to that piece, and I can add that measurement to another from firewall to the cut we made. -
Glad you're working out the kinks, I have the same IAC setup going into mine when I get to installing MS3X.... should hopefully be able to learn from what you did and not suffer quite as much haha
Your air intake is already a cold air intake if you're running the stock one. If you want more induction noise and maybe less restriction then I guess you could replace the original air box with a cone filter, but realistically the change will be minimal since the stock position is already in front of the radiator in the coldest place you could put it.
That's correct. L should only come one when the key is turned, and S to 12v. Is that the right plug on your top picture? Been a little over a year since I did my upgrade, can't remember all the finer details.
http://www.atlanticz.ca/zclub/techtips/alternatorswap/index.html
I don't have personal experience with it, but most reviews I've read say don't bother. Better than nothing, but not really worth the trouble and cost if you're tearing open your differential anyway. You're better off with an OBX unit. Some light reading: https://mycomputerninja.com/?p=440
