Leon
    25
Everything posted by Leon
  1. Nice, we'll see if I can make it. I'm already planning to run the road course with NASA the weekend before so the wife will take some extra convincing if I'm going to make it happen.
  2. Nice, the Trackmasters guys always put on a good event. I've been wanting to take my Z out to one but I need to sort some running issues which is probably just a clogged fuel filter...
  3. In my experience, there is a ton of variability in the body/chassis components, including 40+ years of wear and tear. My old 260Z aligned perfectly and that was a car that had been salvaged due to a rear impact. I had to mill slots into the transverse link mounts on this current car to get the toe even. Swapping to different strut housings evened out the camber.
  4. I would never swap out an N54 over an LS. That's one of the worst motors BMW has made, given its durability record.
  5. Welcome, fellow Bay Area Z owner. I don't see why not
  6. Just take the free-play out of the pedal and give it a bit more. It doesn't take much. You'll know you did it right when you pop the line and it doesn't start dripping.
  7. I run a stock 225mm clutch on a 10lb Fidanza on an L28 that makes 195whp without any issue, it's the perfect combo of rev-happy but completely streetable. It's not the clutch, if it was installed correctly. There are tons of posts on checking your clutch stack/release bearing height. First thing I'd do is climb under the car and check if there's free-play at the clutch fork. You don't want it pre-loading the release bearing. Also, no amount of boost pressure is going to keep the throttle plate open, the forces acting on the butterfly are equal and opposite.
  8. My previous struts had the brake line bracket cut so it could be bent out of the way and the brake line could be extracted without disconnecting it. I don't recall exactly but I think my lines are just hanging now that I've sectioned the struts, perhaps I should revisit that...
  9. Also, why do you need to disconnect brake lines? Why not disconnect the calipers and hang them on bungee cords?
  10. Use a pedal depressor and slightly depress the pedal. It only needs to be pressed enough to cover the reservoir ports. You'll lose a few drops plus whatever's in your caliper. Disconnect your battery so your brake lights don't drain it.
  11. I spy Ben's sweet Z build. Looking forward to watching the film, if not live then a reply.
  12. The dual-master non-assist setup in my race car has far better feel than any assisted brake setup. A light pedal is harder to modulate, in my experience.
  13. Here are my settings, using only camber plates. The car handles perfectly to my taste, breakaway is very neutral. I don't have any rear toe adjustment otherwise I would've dialed it down.
  14. Feel free to create a post with specific questions. If you're after finding a mechanic, then I'm of no help unfortunately.
  15. Right on, I've been running the Works Mitsubeastie in Lemons. It's slow as hell but the most fun I've ever had on track! I'll be sure to say hi if I ever see an S130 in the paddock. I may come up to Sonoma next Saturday for the Speed Festival in case you plan to be around.
  16. Nice, I've run Lemons four times now but all at Sonoma. We keep wanting to build a car and run more of the West Coast races but having the time to do so has prevented such ventures. Came really close to buying a $400 IROC Z Camaro lol! The E36 is probably the perfect chassis for low-buck enduros. It's cheap, easy to work on, has great parts availability, and is fun to drive. It would be cool to see the ZX at a track event sometime. If there are ever any old Z's at the days I go to, they're always S30s. I run mostly with NASA but also Trackmasters and Speed Ventures. Once in a while, I'll do a day with some other random club. Let us know if you sign up for any!
  17. This is likely my favorite current build thread, really enjoying the deep dives into everything from gearboxes to ECU definition files. Your pragmatism and ingenuity are fun to watch. Keep up the good work and keep sending it.
  18. I didn't cut any coils off, it turns out the 260Z spring perch is lower than the 240Z. https://www.classiczcars.com/forums/topic/38373-240z-eibach-springs-in-260z/
  19. Rob at Z Car Garage in San Jose is a dealer. The first picture is outside his shop and the black car is the OSG build they did.
  20. Thanks Brady, appreciate the kind words!
  21. I don't have any personal experience but there's a few running around with NASA on the West Coast that I've seen. They seem pretty quick and fairly inexpensive to run. https://nasaspeed.news/columns/class-syllabus/spec-z/ https://www.turnology.com/news/valkyries-350z-wins-at-the-25-hours-of-thunderhill/
  22. Looks like it's time for an update! I finally installed the struts we sectioned last year, got the ride height and alignment settings dialed, and installed the Watanabes. The ride is so much better now that I have some bump travel in the suspension, this was a huge step to refining the car. I installed fresh seals and bearings but the brakes were swapped over from the old uprights as I didn't find any good rear disk kits that fit 15's. It would've been nice to make my own conversion but I just haven't had the time. Alignment spec, for my record keeping. I'd prefer less rear toe but otherwise it's surprisingly even! Getting closer to being "done"... Next on the list of cosmetic updates is installing that NIB Nismo Compe steering wheel handle. There are plenty of little things to do and loose ends to tie up. For the sake of not forgetting: change the oil and check valve adjustment reseal carbs and intake manifold, smoke test indicates possible leak at cold start units and carb-to-manifold gaskets fabricate and install longer throttle rod for throttle cable, set pedal stop connect manifold vacuum to distributor install Mallory FP install wideband and finish the tune fix tach and speedo tidy up distributor wiring fix tail-lamp bulb housing install a PCV catch can replace the water bottle radiator expansion tank with something more fitting install a speaker so I can listen to the radio install misc missing fasteners on bumper trim, front air dam, interior trim replace center console connect cold-start mechanism and re-mount choke bracket (if I need to) track down some sweet period-looking bucket seats put together a rear disk kit for 15's other things My buddies were egging me on after seeing the car to install a BRE trunk spoiler, painted black to match the front air dam. I'd never intended to put one on the car but I'll have to at least consider it.
