HowlerMonkey
Necropost, I know .........but this might help someone trying to get the stub axle nuts loose at a upull junkyard. It sucks to work hard and come home empty handed because you couldn't get the nut off or damaged something in the epic struggle to remove the nut. You know those rims they weld together to make a "junkyard jackstand"? They are the perfect "vise" to hold anything you can bolt to them. What I do is remove the entire control arm and simply plug the stub axle into one of those "junkyard jackstands" and run a couple of lugnuts from the other side of the wheel to hold it. Now you have a stub axle that will stay put while you jump up and down on your breaker bar. It helps to find one that is turned a little and is under a heavy car. Shop around with the brake rotor for the proper bolt circle before lugging the heavy assembly around.
Tracked the car at Palm Beach International Raceway during "midnight madness" october 12, 2012. L28E (flattops) p90 head, 3n71b automatic, mkIII supra intercooler, 7 pounds boost, stock ecu (untuned), stock L28et injectors, 3.54 R200, 215/60-15. I think some tuning with nistune could get into the 14s because the aggressive M30 ecu timing requires base timing to be backed off.
Please post ECU pin output pictures
HowlerMonkey replied to UH-60ZX's topic in Ignition and Electrical
I remember that none of the many ecus I had on the shelf at the blue streak warehouse for a 280zx had a pin 4 and that checking a customer's car showed that the ecu had nothing to do with cold start functionality. It was controlled by the thermo time switch on the thermostat housing. The main differences in the various non-turbo S130 ecus was the fuel pump scheme. Some had 1 relay, some 2, and some had 3 relays. -
Again.......I have.....with many parts in my capacity as general manager of thier direct competitor. If I had found anything "sub par" I surely would not hold back. Most of the parts used for rebuild come from the original vendor who supplied the OEM manufacturer. If it's not possible to source the same part because they are not available, they go with who has them. This usually means you either can get the part from one supplier or not at all. Just saying they suck is one thing but offering up some pics for comparison would go a long way.
I've done so in my capacity as general manager of thier direct competitor Blue Streak. Since cardone's product line is so wide, there will be multiple facilities involved in parts remanufacture. There will also be a few technicians who take short cuts but it only takes a couple of complaints for the company to eject the lamer. Sure, you can find a company that specializes in a narrow product line range that might do better work on a specific part but, most of the time, your only choice is used or them. Far more common are "installers" who suck and send back a product damaged by said installer over and over at the expense of the remanufacturer.....because they can't fix or diagnose a car. Guys like that compromise the bottom line and force prices higher. That said, 90% of ecus sent in to us tested ok. Usually that customer springs for a replacement under our critical core program and his ecu, after testing ok and remanned, is sent to another customer who has success while the original customer calls to say our replacement ecu is bad because it does the same thing as his original unit.
Can you quantify "junk"?
Last time someone complimented my M30, it was in traffic. I came out the next day to a missing..... rear view mirror, all dash switches, 5x ecus (one ripped from the harness), a drill, a timing light, and even a few french fries cleaned off the floor along with some change from the console.
Nice choice. I feel the sr20det in the 240sx is done to death and that the early Z car is a great marriage to the SR20. You definately have to let us know the miles per gallon figures since they will be pretty good. As far as Alfas go, I really want an alfa milano verde 3.0 to build up possibly for SCCA Improved touring.
We have a set of gauges under the hood where the dyno operator can stand and view them safely while the guy inside the car can pay more attention to keeping the 2,000+ hp under control. Still not safe enough for me......I campaigned for a long harness so the gauges can be brought to a safer distance.
I fail to see this rhetoric posted anywhere by the site owners and moderators or in the rules linked below. http://forums.hybridz.org/index.php?app=forums&module=extras§ion=boardrules
Jwt sells these and it's not super easy to do it but it might be cheaper than the cam itself. http://www.jimwolftechnology.com/customer_part_detail.asp?PartID=500
EZ electric powersteering installed
HowlerMonkey replied to rags's topic in S30 Series - 240z, 260z, 280z
The lexus IS250 and IS350 cars have a power steering rack that isn't much larger than a hydraulic rack. The guys at JM lexus were replacing them like wildfire because customers complained they could hear a noise they hadn't ever heard on any previous car........DUH. Because of huge demand, I would think pricing and availability might be common but we were required to bash them in with a hammer. If you could find a lexus technician with less scruples (you know....the guys who replace them under warranty to earn the labor when nothing is wrong with the car)........you might be able to swing getting one pretty cheap. -
3" Exhaust... for NA modified engine. Muffler options?
HowlerMonkey replied to inline6's topic in Exhaust
Many of the rotary guys use a "power pulse presilencer" which is a stainless steel packed muffler. Rotaries have such a huge overlap that they can't tolerate any backpressure, make big heat, and are super loud. I'm not sure how much it will attenuate sound but I used to use one on each primary pipe and then a huge single chamber muffler after it was collected near the rear of the car. -
Forgot about the H190 in the rear. Since the Z31 300zx has 4 lugs and the wheels bolt straight on the maxima without spacers, it might be that you can get larger brakes simply by bolting on the calipers and hub/rotor/bearing assembly.
By "breaker plate" I mean the movable part where the stator mounts. You should be able to grab it and move it a bit and the spring tension inside the advance mechanism should return it. Also inspect around the periphery of the plate and see if you can see broken parts or a ball bearing ball that has fallen out.
It's possible that the infiniti M30 rear control arms are identical. I can take pics with some measurements of the arms I picked up to do the 5 lug conversion but dad is in town with his plane so it's flying time. If I can, I will take measurements of the front struts to see if they are of similar dimension. As far as the driveshaft, the 240sx and M30 both have two piece driveshafts and the maxima had about 4 different versions so you might be able to find the "front half" that will bolt in to your existing "rear half" of your driveshaft and avoid cutting anything. If you do need to cut, I recommend simply having a driveshaft shop make you a 1 piece shaft with the parts on each end that fit what you have. The aussiebluebirds site has some good information on brakes.
Tire brand and stretched tires
HowlerMonkey replied to lorenzo's topic in Brakes, Wheels, Suspension and Chassis
A 225/50-15 is around 23.9 inches tall vs 25.6 for the 225/60-15. -
True.....the "dot legal" tires used by many racers are usually wider than the pedestrian tire of the same "size". You can go to tire rack and check section width vs tread width which may give you enough information to find a tire that will fit best and also has a treadwear rating higher than 60. -
Maxima wagons are super cool. Don't forget the 300zx four lugs that can be had for free quite often. 225/50-15 work well on that car. This one was a 5 speed with turbo hardware from a 280zx and a R200. I compared the clutch pedal with one from a S12 200sx and they were nearly identical in most every dimension.
There are many guys running 911s with 15x9 with 225/50s because of availability issues. -
Certainly not a pencil.
Original poster should also check whether his breaker plate is stuck in the fully advanced position. He should be able to move it with his hands and be able to see it return to it's fully resting position.
A soft pencil is the wrong material to suggest using because it is soft enough to catch on the spark plug threads with even the slightest amount of angle away from optimum. It's obvious the pencil angled slightly, grabbed the threads, and was folded into the combustion chamber. The proper advise would have been this........ Since your car does run, take off your cap and turn it until it's starting to approach where you currently have the wire for cylinder 1 on the distributor cap. At this point, you should be able to see the piston coming up and near top dead center. Only then do you stick something in the spark plug hole to get it as close as possible to top dead center. I'm also willing to venture that his timing mark on the pulley matches top dead center and that his issue stems from either an improperly indexed oil pump shaft or the plate on the bottom of his distributor has been adjusted full deflection in one direction. Original poster should inspect his distributor and will notice that the metal plate that the distributor hold down nut clamps can also be "re-indexed" to gain a bit more authority in adjustment. If it's already adjusted fully one way, try it in the middle. By using both adjustments, you surely can get the timing dead on whether you have to rotate the wires on the cap one position or re-index the oil pump shaft. It's up to the owner to determine which is worth his time.
Have you ever run diesel oil in your engine?
HowlerMonkey replied to BluDestiny's topic in Miscellaneous Tech
If you're burning enough oil to kill the cats, you are burning too much oil. Most of the Z cars that were made with catalytic convertors as original equipment were also built when oil had high levels of zinc.
