HowlerMonkey
  1. Recirculating the blowoff valve from right in front of the throttle plate to the turbo inlet got rid of that "rich dip" in idle speed that happens when I closed the throttle. If you're venting to the atmosphere, your MAF doesn't know that air it just metered didn't go through the engine so you end up with a rich condition at drop throttle that stalls the car.
  2. Some guy named Sanford Silverberg holds the SCCA ITS track record at milwaukee with a 280zx........at least he used to.
  3. Anyone know if there a spec on the limit of how much you can trim off the stock valves?
  4. Take care when "retorquing" old head bolts as you could end up snapping one off since you don't know the condition of them. I would start with a setting on the wrench of a little less than what the factory recommends just to see if you get any movement and carefully feel while you are tightening. If you find one that is starting to turn more than the others or just doesn't feel right, you might want to remove that one and replace it before it snaps off. Overheating an engine can cause the aluminum cylinder head to expand and actually squeeze a gasket thinner........then at normal operating temps. afterward, the head is not fully torqued.
  5. Should be identical 60mm to the 240sx since they used the same engine except in tranverse mounting. It's easy to go to a pull and pay yard and compare them as I usually see both cars there whenever I go.
  6. I second a good high flow cat as long as you have some sort of shroud between body and cat. For some reason the path through the monolith get's rid of all the raspiness and you get a mellow rumble at idle. If you want to muffle further, a simple straight through at the bumper will suffice and a dual chamber muffler will quiet it down to stock levels. After driving J-ported rotarys all through the 80s, I like my cars super quiet now.
  7. I picked up a porsche 924 cheap to flip back in 1988 and it would overheat only when driving around at neighborhood speeds. I figured it out when I walked past the bumper in shorts and felt the warm air coming out the front. It seems the early 924s had fan motor connectors you could easily connect 180 degrees off.
  8. I use infinti M30, Z32, and maxima (VE30DE) ecus on my L engines. You could also run the early 90s maxima vg30 ecus and harnessing because they are near identical to the M30 setup except that you don't get a nissan consult port with them. The M30 ecu is the easiest of the three because you only have to swap the optical disc in the existing L28ET distributor while it takes a bit more work to do it with the other 2 since the disc is a different size requiring more than simple snapping things together like lego. "easiest" doesn't mean "easy" since you will have to ensure you have the proper wires going to the proper places to satisfy the ecu, injectors, fuel pump......etc.
  9. Spend a bit of time looking and know that the one best deals come when you aren't ready. I spend years looking for cars and they seem to fall into my lap when I'm not looking. As far as condition of car, it depends on what your area of expertise is. For me, interior and body to a certain extent is important because mechanical stuff is my specialty. Reject any car that has rust around the windshield or leaks around the windshield.......unless you are good with rust repair and auto glass. I bought a pristine 1987 300zx that had 300,000 miles on it but I've seen beaters with less than 100k on the odometer. Look for any fatal flaws of the body such as rust in the floors.
  10. That's good to know but it is important people know the voltages will be slightly different. We run our race car near 15 volts to help fire the coils under crazy amounts of boost.
  11. The toyota MR2 has a "sequential manual" box but it's simply a corolla/celica box that has servos to do the shifting and clutch. It's not really "sequential" as you see in motorcycle or racing car boxes.
  12. One thing to consider is the voltage. In our standing mile car, we are able to simply use the tuning software to set the charging voltage and I believe you might need to have whatever regulates your alternator modified to charge at the battery's happy voltage. If the battery you chose runs more than 14.1 volts, remember that S130 and Z31 electronics such as climate control and a other systems react to voltages higher than it expects by shutting down or glitching. Do the research first so you don't end up posting an angry and misinformed review if things don't go well because you didn't do the research.
  13. Yep.....fix it if you're running the stock J-tube because it's there to relieve pressure that builds when you lift the throttle under boost. It's there for the benefit of turbo longeivity. If you're running an intercooler system, you could get away without that valve if you have a "blow off valve" plumbed in but I run both the factory valve and a blow off valve set to recirculate to the turbo inlet.
  14. Yes they are. The Z31 300zx has the engine quite a bit forward of the firewall so compared to the fs5w71b from a S130, the shifter will be a bit further from the bellhousing flange......but not as far as the Z32. I don't know the exact measurement but it should be the same or extremely close to the fs5w71c from the non-turbo as far as shifter location. I guess you could call it medium distance with the pathfinder Fs5r30 being the short distance and the Z32 being the long distance from bellhousing to shifter. One thing to know if you're contemplating adapting a VG30 engined car's trans to the L engine is that there were more than 1 starter locations so and that the pathfinder transmission bellhousing shape does not fit the Z32 transmission adapters. I'm not sure whether the adapters fit the Z31 version of the FS5r30a transmission.
  15. We're going to inspect the above mentioned everglades jetport soon for LSR feasibility. https://maps.google.com/maps?expflags=enable_star_based_justifications:true&ie=UTF8&cid=6771187789820398104&q=Dade-Collier+Training+and+Transition+Airport&iwloc=A&gl=US&hl=en-US We've got exclusive access to the shuttle landing facility but the costs are unbelievable and use it only for nascar and lemans teams to come over and test as well as our own aero testing since it has smooth, shallow groove, and deep groove concrete portions which offer more traction than any surface other than a well prepped drag strip.
  16. It's possible that the 1992 nissan stanza throttle body might end up being easier to adapt to the L28 intake manifold. I did a comparison years ago and it seemed like a lot less work.
  17. I run my L28et with flattops and taking off from a light with even 40% throttle has me hitting full boost very quickly causing me to drop to about 10% throttle in order to accelerate in a non-aggressive manner. This is with the stock throttle body. A 90mm throttle body flows more at smaller throttle openings than a smaller one so, in my case (flattops), it would be pretty non-fun having to modulate it since it's already difficult. I've been using this setup pictured here for many years and once used something similar when we replaced a Z24 with a L20b webers in a truck. It leaves only one belcrank in the equation as compared to a stock linkage which has more. http://farm8.staticflickr.com/7376/9740858935_ae10ba1772_c.jpg If your 90mm throttle body is unmanageable to drive, you might try a stock porsche 944 cam which I picked up at the local yard for 6 bucks.. http://www.dietersmotorsports.com/tech/2001/images/clip_image002_002.jpg
  18. I've seen guys get debris down the oil supply hole on the deck which then get's pushed by the oil and could be restricting flow somewhere downstream. You would be surprised how much stuff from the 3m wheels people use will go down a hole.
  19. Pulling injector does the same thing without getting the willys from a big shock. So you're saying it only makes the noise on cold start? If so, high mileage L28s do get loose on the rod bearings and will rap on cold start and certain oils may make the condition worse if it takes too long to get pressure on start.
  20. Unplug the 02 sensor and see if it still does it. Easiest test to perform before you decide to clean all the terminals. I've had this happen, unplugged 02 sensor, drove it for a year because it was seized in the turbo elbow. When I plugged in the new sensor after doing some other work that required pulling the turbo elbow, it was fine. If you're driving on the highway with rpms over 3500 or so, the system ignores the sensor anyway. (throwback from 55mph speed limit when car was made)
  21. A "blueprinted" IT motor is far more than what the term "blueprinted" means in this case but also far less than what you can put together for a street motor while still using the stock camshaft. In Improved Touring you can go .025 beyond the service limit of cylinder head thickness as long as you don't increase compression ratio more than half a point. You can port match but not further than 1 inch from where manifold meets the head. You can't assemble an engine from multiple years meaning the engine specs. are for the entire package for the year you are representing as your car. .040 is the maximum overbore from stock. You can't lighten rotating parts beyond what you need to remove to balance the assembly. For pistons, they specify that dome/dish/valve relief configuration, ring groove width and spacing, and pin height relationship be the same as stock and weigh the same as factory pistons if you had to go with non-factory pistons. Valve guides might be open. Compression 70 to 73 are allowed 9.0 while 1974 260z is allowed 8.9 and 1975 on engines are allowed 8.3 I don't remember valve job angles and camshaft timing or specs but it is pretty well policed........if you finish in the top 3. Within the rules, there is a lot you can do to optimize an engine but on the street, the limitations above don't apply. I'm sure a F54 block with the MN47 head using flattops could make some big HP but you have to either run better fuel than california 91 octane, reduce timing below optimal, or find a way to reduce overall mechanical compression ratio.
  22. Funny you mention fused ankle. I will gladly race you with my fused ankle as long as it's on a sandy beach.....which is where I do my interval sprint training.
  23. Found some interesting information on oils and additives as tested at this link. http://www.nastyz28.com/forum/archive/index.php/t-256590.html The post is this year but not fully sure of the year the study was done.......which would mean some might have changed formulation. I was very surprised to see Castrol GTX 20w50 so high on the list.
  24. I'd just like to see what can be done with investing in labor (porting, combustion chamber shaping, and valve reshaping) as opposed to investing money (parts such as camshafts). I don't think an Improved Touring engine would be a good reference to my question since they are limited by SCCA in far more areas than simply the camshaft and I've built ITS 240z engines off and on since about 1986. It would be cool to see how far a stock cam profile that will pass emissions and last 300,000 miles can be taken if you optimize everything except for the cam. This means my question covers any permutation of stock cams, heads, and blocks but with unlimited amount of optimizing everything else. I understand the changes to motor oil have not favored engines that have high psi loads between lobe and cam follower but I'm not seeing undue wear to factory parts in super high mileage engines even with the newer oil formulations in comparison to the many threads showing aftermarket cam or follower failure.
  25. It was more of a question as to whether you thought your car could reach a higher top speed in 1.5 miles on concrete or ashpalt rather than salt. I'm sure come cars can but was interested in whether your large amount of experience with your well developed ride has indicated that it is possible?
