HowlerMonkey
Does the boss adapter work with a momo wheel?
It's a timer unit.........most likely for the seat belt warning system.
Pull one from a 280zx in the junkyard that already uses c/v axles? I know the 1984 maxima uses c/v type axles and they are same length as 280zx.
How do you deal with bolting the converter to the assembly? I like the idea of being able to use 200r4 or maybe even 700r4.
My stock L28et (other than flat top pistons from n/a) in front of a stock 280zx turbo 3n71b will break the tires loose for a couple of feet if I simply stamp the throttle at a light if the surface is less than perfect (dry, not wet). This is in a infiniti m30 with 3.54 r200 which is a bit heavier than a z car. It's possible the m30 management system helps and I'm sure the higher compression helps at tip in. What were the results of the compression test?
Magnaflow CA Legal CAT: More Power? Nicer Sound? Less Heat?
HowlerMonkey replied to Connor280ZX's topic in Miscellaneous Tech
At lexus, we get cars with check engine lights and a rattle from the back of the car on occasion. I opened the gas cap on one and it smelled like diesel so I popped off the cats to take a look and found a nice neat hole bored right through the center of the catalyst. The rattle was the chunks of catalyst bouncing around in the mufflers. I'm pretty sure it was only a couple of gallons of diesel which made the car hard to start and smoke a little. I've seen 1990 LS400s with pristine cats. -
Super low budget version would be to find a 1998 Lincoln mark VIII at the junkyard and get the entire engine with all accessories for 250 bucks and then spend another 40 for the harness and fit it yourself. Most I have seen there have teksid aluminum blocks and it's usually the rest of the car or the transmission that ended up the car at the junkyard but you're still rolling the dice at a upull yard.
If your p79 head is complete and has not been disassembled, I would leave it alone and keep it as a spare or simply use it now while you source another P79 you can rob the parts from to complete your p90.
77 280Z Engine swap Ideas?
HowlerMonkey replied to Defiaskilla's topic in S30 Series - 240z, 260z, 280z
Go to a local Z club meetup and get a ride in a 280zx turbo or l28et swapped into a earlier Z before checking out other options. It's so much easier than the other options.- 14 replies
- help
- 280zEngine swap
(and 1 more)
Tagged with:
Open Downpipe - can you live with it?
HowlerMonkey replied to 9/73-E31-260z's topic in Turbo / Supercharger
I've been running various ZXturbos with either a factory cat or an aftermarket cat and it sounds sweet. The nature of the monolith seems to get rid of the "sounds like ass" and leaves just some rumble. -
Datsun 260Z Turbo S15 6 Speed TechnoToyTuning
HowlerMonkey replied to tooquick260's topic in S30 Series - 240z, 260z, 280z
Sweet.......much learning was accomplished that will benefit you and forum members. -
240z l28 + 81 5 spd trans
HowlerMonkey replied to itrjon's topic in Trouble Shooting / General Engine
He's pushing the car into the garage. I seriously doubt the clutch is even part of the equation since you normally push a car in neutral. I would ask him if he turned the driveshaft by hand after sliding it into the transmission but before bolting it to the diff. -
Gauging interest in M30/z32 ecu standalone harness or.......
HowlerMonkey replied to HowlerMonkey's topic in Nissan L6 Forum
That's just it. I have like 15 m30 ecus, and a bunch of z32 and ve30de ecus as well as harnessing. -
Yep.....bought one after having my second snap on digital display timing light stolen in a 13 year period. One thing to do with the harbor freight gun is to test it against a couple of other "advance timing lights" to see if it's close as I had to pull off the knob and move it over one slot to get it perfect.
Yes, the M30 in bmw terms is the 3 liter inline six but there is no relationship other than "m30" and no parts interchange. Early to mid 90s vg30e maxima is the same setup as the M30 except you don't get a consult port.......you get a check connector and there may be differences in throttle position sensor as well. Pathfinder is similar as well and a quick search will net you multiple threads in which people are seeking to replace their pathfinder or maxima ecu with one from a m30. I've done a lot of research into the OBDII pathfinder and quest ecus and I found little support for tuning them as they are a different ecu family. I'm trying not to go down a blind alley but rather one with multiple doors since the pinout of the maxima/z32/m30/j30 use the same ecu connector and many of them have very similar pinouts even when comparing multiple coil outputs with a single coil output. They all are also nistunable other than the J30 which has two prom chips and requires a bit more working and you often need two romulators to tune them. If nistune is not available for the maxima and pathfinder versions of that ecu family, you might be able to tune your car on a M30 setup and dump your finalized "perfect tune" into a rom editor and then paste them into the rom of a maxima where you would then burn it to prom and run the maxima ecu with the values you got from the nistuned m30 ecu. -
So I heard these cars are rated to 27mpg highway?
HowlerMonkey replied to osirus9's topic in S30 Series - 240z, 260z, 280z
The 280z has no closed loop operation but it is possible that it also goes into a pretty rich map at the 3500rpm mark. I haven't hooked one up to an ecu simulator in about 3 years so I don't really remember if it goes full rich at 3500 like later ecus or simply follows the airflow meter and uses a map without changing modes.- 59 replies
