socorob
    10
Everything posted by socorob
  1. I would be more excited if they came out with a 200hp car that got 70 mpg.
  2. The simplest route will be jci. I don't think you have to remove the dash for that, but it only blows as hard as the Datsun ac ever did. The vintage air is great but it's a lot of work. I'm not sure if you go with the johns cars compressor. and use the newer design components up front from ac solutions, if that would make the Datsun AC a little colder or not. The guy from vintage air told me the new stuff up front is way more efficient than the old stuff was. so you get better cooling.
  3. Did these fit into the stock buckets?
  4. I used padded dash filler and flextex. Worked well.
  5. I got msa ones but they fit horribly. My friend said he was replacing the boots on his sons acuras rack and he said those were a perfect fit.
  6. Yeah thanks for those. My problem is one of the metal boots keeps pushing off spark plug 5 and it starts running like crap. And I have another wire that the insulation is split on, so since I need to replace them, I may as well try to get better ones. Are you going to track night on the 3rd?
  7. Thanks! I think I may have an opportunity to use a lift for the next 2 days, so I would like to use that time wisely to swap my heavier springs to the front. and get my ride height and alignment set as close as possible. Then I will try to run down some scales to corner balance the car.
  8. I have been looking at the MSD wires online and saw there were 2 boots. According to the ebay ad, black boots are regular and red boots are hi temp? http://www.ebay.com/itm/MSD-Ignition-32819-32813-spark-plug-wire-set-LS1-LS2-LS3-LS6-LS7-LS9-/151012469582?hash=item23290b6b4e&vxp=mtr Look at the 3rd picture.
  9. I hope I make it too. I am using 5 lugs, but appreciate the offer. If I go, I probably won't do any of the motorsports events because I will have to be able to drive the car there AND back, and I don't have a trailer.
  10. When setting ride height, is it good practice to set it by using a certain control arm angle, by looks, or by _____ for a street / occasional autox, track day car? When I see pictures of Zs, ride heights seem to be all over the place. Is it an aesthetic issue mostly or do you want some certain angle down of the control arms to give a little camber gain?
  11. My wifes suv had thIs problem and it ended up being the tensioner bearing. Napa will sell you just the bearing for a couple bucks if you have a way to press it out. Take the belt off and spin all the pulleys as hard as you can and see if any seems louder than the others.
  12. Did y'all use the metal boots the stock ones had on the msd wires?
  13. any particular brand seem to hold up and not hit the header as much as a stock set?
  14. Anyone know what would be the minimum safe amount? Also does anyone have a rack laying around that they can measure the total length of the threads without the outer tie rods on? Maybe the better question would be what is the maximum amount of exposed threads that's safe? I'm trying to put some more camber in the front and caster, and it seems there's an awful lot of thread showing.
  15. My friend passed by where the new terminator movie was being filmed on his way to work every day and said for awhile they had 2 identical ZXs out there.
  16. Step on is a little exaggeration. The weight is spread more equally across the whole thing, but can have a lot of pressure pushing down.
  17. Supposedly you should be able to stand on a splitter without it breaking. If it generates 200 pounds of downforce at speed then it should be able to support 200 pounds across it. Just some food for thought before you go dragging something down the road.
  18. I have a 78 280z with bad dog rails, and I put a pipe brace from the bottom of the door jamb angles up to near where the struts mount (outside inner fender I guess you would call it). I also stitch welded everything from strut tower to strut tower. Think that would be stiff enough for 300# up front, if not would a triangular strut bar help? I'm new to this, so mainly trying to find a starting point then experiment from there.
  19. Thanks. I was trying to cut the center of the Esses if that makes sense because it felt faster, but the last one where I spun out had a different radius and would catch me out sometimes. These big rivals seem to have held up decently compared to some of the others tires out there.
