10
Everything posted by socorob
I just got some peel and stick closed cell foam from the hardware store that was the same thickness. Make sure it's closed cell, you don't want a sponge holding water under there.
in opera the extension is called photobucket hotlink fix
Got 315's to fit my set up
socorob replied to Nv_s30's topic in Brakes, Wheels, Suspension and Chassis
I have the TTT rears and was able to adjust everything with them on the car when I did my alignment. -
I have a gen 2 compac and ran the drain hose through the original drain hole on a 78.
My friend has big gaps under where the metal piece that goes across the front under the windshield sits over the dash. They are worse on either end than in the middle. Also, why doesn't it have the inset for the 280Z dash plaque?
2004 gto ls1 swap 1973 240z wiring questions
socorob replied to ben a's topic in Gen III & IV Chevy V8Z Tech Board
http://lt1swap.com/2004gto.htm I just used this to make the stock GTO harness work. -
I have the 04 GTO motor. The alternator is low drivers side, and the AC is high drivers side. Look in V8 section for more info.
Can anyone identify these Z hook style windshield wipers?
socorob replied to socorob's topic in S30 Series - 240z, 260z, 280z
Anco 48-12 are for the straight arm to j hook type of early wiper arms. -
The ls3 has 425-435 no stock, depending what car was the donor.
My friend had a parts car that had these wiper arms with a hook attachment on the end, instead of the crappy wobbly pins. It appears to be an add on. It has different part numbers than the wiper arms with the pins, so I don't know if they maybe came off another car. Anyone know where to get these, or what they may be called to help narrow down my search? 621 LA87 1R 622 LD87 1L These are the numbers that are printed on them. Maybe the ends came off another vehicle?
Saturn Electric Power Steering In A Datsun 280Z
socorob replied to socorob's topic in Fabrication / Welding
I got the saturn motor for 45 from a junk yard, the rest of the prices are online. I didn't keep track, but whatever it was, it was worth it. -
More Caster With Power Steering?
socorob replied to socorob's topic in Brakes, Wheels, Suspension and Chassis
Anyone have an over/under on the final weight? I'm thinking under 2500 if they don't get crazy on the interior.
Did Courtesy parts ever come back? I got some hard to find stuff from them before.
With a few new power steering kits out there, would dialing in more caster in the front be helpful? I just installed power steering and will put on short steering knuckles soon, so will need an alignment. I was going to use these specs from the alignment sticky: Street For 225 to 245 width radial DOT tires try these alignment settings: Front Camber: 1.25 to 1.5 neg Caster: 4 to 5 positive (even on both sides) Toe: 1/16" out or 0 Ride height: 6" to 6 1/2" measured at the front of the rocker outboard of the pinch weld seam. Rear Camber: 1.25 to 1.5 neg Toe: 1/16" to 1/8" in Ride height: 6 1/2" to 7" measured at the front of the rocker outboard of the pinch weld seam. For tire widths over 245 try these alignment settings: Front Camber: 1.25 to 1.5 neg Caster: 4 to 5 positive (even on both sides) Toe: 1/16" out or 0 Ride height: 6 1/2" to 7" measured at the front of the rocker outboard of the pinch weld seam. Rear Camber: 1.25 to 1.5 neg Toe: 1/16" to 1/8" in Ride height: 7" to 7 1/2" measured at the front of the rocker outboard of the pinch weld seam. Would more caster be a bad thing? And what about 0 or 1/16 toe in? I have slight toe out, between that and bumpsteer, my car wanders on the street.
What wheels are those? I love dirty gold wheels.
The reason people think they're supposed to bolt on the outside is the msa moulds are so out of whack it fits over instead of under like they're supposed to. It took a lot to get the msa ones under and they still didn't fit correctly.
http://www.ebay.com/itm/Saturn-Vue-Chevy-Equinox-electric-power-steering-controller-EPAS-/122354361512?hash=item1c7ce364a8:g:I7AAAOSw0cdZfi49&vxp=mtr -
Got it working last night. I only went up and down the street at slow speed, but power steering is wonderful. When I hooked it up, it turned easier right than left. If you remove the cover from the Saturn control box, there are 3 potentiometers. If you turn the one labeled VR1 in very small increments one way or the other, you will find the setting to get it equal. -
BF Goodrich Rival Problems
It's a weekend car with a few autocrosses. I have slicks for track days and autocrosses when I can get someone to follow me in my truck. I would love to figure out how to hook up a trailer like green hornet has. It's been almost a year since the last autocross. The rivals are great for dry days but are like driving on ice in a storm. If I know it's going to rain, I don't drive the Z, but sooner or later you get caught in a pop up storm. It's scary in the wet with Rivals. -
Have you ever used Toyo R1Rs? -
They are almost 3 years old with 4000 miles, give or take, on them. Tire rack said they would pro rate them based on age and treadwear. I only have about 3/16" of tread in the middles of them all left. . I would have to mail them back and pay I think they said $7 a tire charge. I can't decide whether to go back with these or try something else.
