jhm
Super Moderators
    27
Everything posted by jhm
  1. Hey all, I've got a pair of the rotor spacers you need when doing the Toyota caliper upgrade to the front brakes. These are from Silvermine Motors; and have never been run on -- only installed once for mock-up purposes only. These are the spacers for "280Z hubs" (which also includes most 260Zs); the 240Z hubs were different thickness and therefore require different thickness spacers for the caliper swap. Please ensure which front hubs you have before purchasing! Full description can be found at: https://www.silverminemotors.com/datsun/datsun-280z/brake-kit-individual-parts/spacer. You would pay $80 plus $10 shipping for these new; you can buy mine for $50 shipped anywhere in the U.S. Thanks for looking!!
  2. If you’re intent on switching to CVs, that’s a pretty nice price for a bolt-in solution. They look an awful lot like the units that Fritz McKellar used to produce at Datsun Restomods; but sadly has discontinued his production line. I had always planned to buy a set from him when my half-shafts decided to crap out on me...but I’m still waiting for that day, even after multiple years of hard track use. Before purchasing, I would check with ZCarDepot to enquire if they have a recommended HP/torque limit on these axles, to ensure suitability with your setup and intended usage.
  3. I agree with @rturbo 930.....if you plan to upgrade the front brakes, I'd go with something other than the Toyota calipers. Those things weigh a ton and it's all unsprung weight. There are numerous options/kits out there that incorporate aluminum calipers and vented rotors. Also, if you ARE upgrading the front brakes, why would you want to keep solid front rotors? Those are actually the biggest achilles heel of the OEM system, as they are prone to overheating when subjected to sustained, intensive use. Since you've already swapped the rears for discs, I'm assuming that you've also gone with a bigger MC? If not, that should be on your near-term list. I know your question is focused on brakes and suspension, but have you upgraded your seats? That alone can make a huge difference in driving pleasure and comfort. Lots of good choices from Recaro, Sparco, etc....and there's a couple good threads here on seat swaps. Your combo sounds super nice -- I hope you're enjoying it!!
  4. Hey Aydin, I'd be interested to see your airbox if you don't mind posting some pics at your next update. Tried downloading the movie clip you included, but my laptop didn't like it (possibly because it's an ancient POS, and I'm too cheap to buy a new one.) You might be able to use V-band clamps on the header if you stagger them on the two pipes (i.e. one slightly fore or aft of the other)? Just a thought for your consideration.
  5. Good tips from @NewZed on the rear brakes. Most of the OTS drum brake shoes from parts stores are so-so at best. Fortunately, Porterfield produces a nice shoe that fits our rear drum brakes....you can check them out here: https://www.porterfield-brakes.com/Products/?YearSelected=1972&ModelSelected=240Z&MakeSelected=NISSAN&selectManufacturer=Porterfield Brakes
  6. When you say "very firm peddle"....I'm wondering if you are getting power assist from the brake booster. Why do you say the "booster seems good" -- have you actually tested it, or had someone else test it? It's not uncommon for the check valve to either be installed backwards or to malfunction. Either condition will result in little/no assist from the booster, so I'd start by checking that first. Also, as @NewZed suggested...harder compound pads won't function properly until they get some heat into them. It is for this exact reason that I will often run organic, or softer, compound pads in my street cars. (And vendors like Carbotech and Porterfield both make a wide range of excellent brake pad options for the S30.)
  7. I would check with Jamie at River City Speed....he works on everything, from mild to wild. He's currently building a turbo LS, tube chassis S30 for his own personal use. He has done work for many members here, including some of our SysAdmins. https://www.facebook.com/Rivercityspeed
  8. jhm
    Utah 260z
    Welcome, and thanks for sharing. If you're starting with a relatively rust-free shell, you are WAY ahead of the game. Hope you enjoy the journey, and please continue to post updates as the journey continues. HybridZ contains a wealth of info; so chances are someone has encountered just about every challenge/issue that you will face along the way....sometimes you need to do some digging to find the answers; but they're usually there somewhere! Cheers.
  9. River City Speed in Richmond, VA; owned and operated by Jamie Taylor. I don’t think he has a website, but does have a page on FB.
  10. I have done gravity bleed, with good results, but not on my Zs. (Speed bleeders make the job so much easier and quicker.). One thing I learned about gravity bleed technique is to only do one corner at a time, otherwise one corner could start sucking air from another corner. First time I did it, I thought I could save some time by doing both rears at the same time but that ended up being a mistake. Hope this helps. P.S. Check out Race Ramp wheel cribs...they are really nice.
  11. Great info....thx for sharing, @MetalMagoo!
  12. I’ve used the stock balancer on a couple of swaps; currently using this one on current swap: https://www.summitracing.com/parts/SUM-161350 No, the timing marks have never been accurate for me. I have always measured it mechanically and adjusted the marks as necessary.
  13. Looks nice. I’ve used HyperCo springs for years w/o any complaints. GLWS. May want to post this in our “Parts for sale” sub-forum?
  14. Yes, should work....provided offset is compatible (or can be made compatible with spacers). I'm assuming it is, as Edan seems to be producing those 5-lug hubs specifically for compatibility with the Z31 5-lug, if I read his literature correctly. I'm sorry I don't have first-hand experience with that swap to confirm 100%. I do, however, have the attached handy spreadsheet of tech data on Nissan rotors that I snatched off of one of the 510 forums I belong to -- may come in handy for you, or others, in the process of upgrading the stock brakes. Nissan Brake Rotors.xlsx
  15. As confirmed by @Miles, the Toyota front brake upgrade is still very much relevant and a popular swap. If you haven't seen the thread in the FAQ section, you can find it here (even though it was initiated in 2005, most of it is all still relevant and a wealth of information): https://forums.hybridz.org/topic/39435-help-what-brake-options-are-available-for-s30-z-cars/ Kit vs piece it together yourself: Several vendors offer a variety of kits, from mild to wild, and many of them offer individual pieces of their kits if you prefer to pick-n-choose. A few of these vendors include T3, ArizonaZCar, SilvermineMotors, ZCarDepot, ZCarGarage, Milkfab Engineering, MSA Auto, etc. I would check them all out before making any decisions. You can generally save a money by piecing things together yourself, but lots of folks would rather just buy the kit and get it installed asap....really boils down to your own preferences. On my current 260, I recently pieced together my own front brakes using universal Wilwood 4-pot aluminum calipers with 11.5" vented discs from a Saab 93....it involved a lot of research and some custom fab, but I'm an engineer by training and personally enjoy that process. Good luck with it.
  16. Good god....that thing is disintegrated. Even if it were free, you'd be getting yourself into an long, expensive restoration; and you still may never be happy with the final result. Is there a particular reason you want a 2+2? Many folks (myself included) feel that the 2-seater S30 has some of the best lines ever penned, and the 2+2 just doesn't quite hit the mark in the styling department. (Not to say that there are some really nice 2+2s out there....just be sure of what you're getting before you buy it.) I would seriously consider the expense and effort of purchasing a car from the west coast of the U.S. and having it shipped. From what I've seen regarding purchase prices of used sports cars in Europe, that would be the cheaper route and you would have so many more cars to choose from in decent condition. My two cents, FWIW...
  17. You are correct in that JTR (and others) recommend a 15K ohm resistor in the blue line between the original ignition box to the tach (and I have done that on some previous swaps with acceptable results). HOWEVER.....IIRC, in my last SBC swap I just ran the line directly from the HEI to the tach (original gauge) and it worked fine...no additional resistance needed in the feed wire. I did have to calibrate the tach, using the small calibration screw on the back of the gauge. No bouncing needle, reads accurately and easy-peasey. This was on an early-version 260. Hope this helps.
  18. NOS may be hard to find, but I'm sure you'll be able to find a good used set. I would check on ClassicZcars.com -- that bunch is very good about saving/preserving original-style parts. I did a quick Google search and saw these on eBay; it's more than you need, but a pretty good price for all those parts if they truly are in good condition: https://www.ebay.com/itm/70S-DATSUN-240Z-280REAR-BRAKE-BACKING-PLATES-LEFT-RIGHT-NICE-OEM-BRAKE-PARTS-/223428019573
  19. Ditto what @calZ said. And depending on which camber plates you select, you will likely have to fabricate some small piece-parts (bushings, spacers, bearings, etc) to make it work with the stock top spring hats (assuming that you're retaining the stock springs or lowering springs of the same OD as stock, like Tokico, Vogtland, or Eibach). It's essential to retain some sort of bearing in the system because of the fact that the front suspension is constantly rotating, via steering action....the OEM thrust bearing provides this function in the stock setup. You may have heard that you can replace the taller 280-style REAR isolators with the shorter strut isolators to lower the rear by 1-1.5"...this is a common swap for anyone looking to lower the rear of the car. The "shorter" isolators are used on the front of all years, and the rear of the early years (up to '73, IINM). Hope this helps.
  20. If you're on any of the S30 pages on FB, I would post there as well. Seems like stuff sells pretty quick there, and you have a very desirable item for sale. GLWS.
  21. I replaced my windshield last year using the windshield seal from Vintage Rubber. I wanted the style seal that omits the metal trim, and Vintage Rubber was the only vendor I could find that offered this style (they call this version the "Cal Style"). I have nothing but good comments about them overall: they responded to my email questions quickly; shipped quickly; and I was impressed with the quality of materials and fitment of the seal itself. Installed it "dry" (i.e. no glue or liquid sealant of any kind) using the "rope" method and it's been leak-free since Day 1. No deformities in the corners and a nice, tight, dry seal all the way around. Whenever I get around to replacing the seal on the hatch glass, I intend to use the Vintage Rubber seal there as well. When doing my research prior to purchasing, I found a bunch of negative feedback on the Precision products as well. Seems like their quality control continually varied.....sometimes you got a good product and other times you didn't. For the door seals, like @Miles suggested, I used the generic auto parts store stuff. I've also bought seals from Steele Rubber Products, and they have a really good application guide and tech info on their products: https://www.steelerubber.com/steele-rubber-home-universal-parts-push-on-weatherstrip Hope this helps.
  22. I think you’ll find that a lot of people will fill that seam for a “cleaner” look....I did it on my last Z (late-version 260). Can’t really think of a major down-side to welding it — although it does make it a bit more unwieldy when installing and removing the assembly as a single panel. The small mounting studs on the sugar scoops often rust and break off anyway.
  23. I'm with @AydinZ71 on this one....I'd rather adjust (or even dimple) the exhaust tubing vs grinding into your diff case. Regarding sources for the mustache bar bushes, I think I used ST last time I did this....no issues with them. I don't know if the rubber OEM-style bushes are still available, but vendors like MSA Auto, Z Car Source, and Z Car Depot would be good place to start. Also, just saw a post on FB about Bill's Datsun Shoppe in OR is having a going-out-of-business sale on a 30-year inventory of OEM and aftermarket Datsun parts....may get lucky by contacting them at(503)656-0756 .
  24. Looks like you've got everything installed correctly. And yes, most aftermarket wheels will have more of a "dish" shape (radially outwards from the hub mounting face) which would allow for more clearance with the brake calipers. But even then, a wheel spacer, between the hub and the wheel, might be needed to provide sufficient clearance. You could probably make your 15" ZX wheels work with spacers, although you may need a wheel "spacer adapter" to get sufficient clearance....spacer adapters have their own lugs, and are a safer alternative to plain spacers if you need more than 1/4" thickness IMHO. Your new 16" Rotas should be fine. Additionally, a larger MC is often required when installing larger calipers -- 15/16" MC is a popular choice and readily available from numerous sources. Finally, if you significantly increase your Front braking power without doing anything to the Rears, F/R brake balance becomes a problem -- the brakes need to be considered as a "system", and significantly changing one aspect of the system can have a big effect on the rest of the system. These issues are discussed in the FAQ thread on S30 brake options -- a good read if you haven't already seen it: I read the brake kit descriptions for all the kits on MSA's website; and it's unfortunate that they don't discuss wheel fitment issues associated with their kits. Didn't see a single mention of wheel fitment in any of their ads. That's kind of a major faux pas on them.
