29
Everything posted by jhm
The fan controller should convert the voltage internally. If your car did not have a controller, or if it did not have the correct controller for your fan, it was just running off 12V. What kind of fan is it?
Wonder if it just needed a reboot, essentially? Glad you got it worked out.
The T3 lower mount is just a fancy (more expensive) aluminum version of the stock lower mount. Unless you're going for the bling factor, the stock lower will work fine. And yes, you don't need the retaining straps if you have the TechnoVersions upper mount. (Datsun used a thick rubber strap in the original factory mounting.) Many folks will run just the upper Ron Tyler-style mount by itself....it's surprisingly secure. Others, especially folks putting down crazy power and executing repeated hard dragstrip launches, prefer to tie the two side lower frame structures together with the additional security of the lower diff mount (some guys have actually ripped out their forward rear LCA mounts when not using something like the lower differential mount to tie the two sides together).
5 speed shifter hitting series 1 console 240z
jhm replied to 5 Star Rising's topic in S30 Series - 240z, 260z, 280z
Yes, a common problem when doing the 5-speed swap. I've seen people cut/trim the console and/or swap shifters to address the issue. People will even cut and weld a stock shifter to create their own custom dogleg shifter. And keep in mind that the shifter can be modified both above AND BELOW the pivot point. If you don't find a solution on HybridZ, I would check on ClassicZCars.com. They are usually more inclined to retain the stock sheetmetal and appearance....particularly on early 240s. https://www.classiczcars.com/forums/topic/38196-shift-lever-hits-console-on-1973-240z-5-speed-swap/ -
Hey NewZed, thx for that link to TechnoVersions. I had no idea that someone was still producing an RT-style diff mount. Good info!
https://www.classiczcars.com/forums/topic/26561-honda-wiper-motor-upgrade-for-the-240z/
Another thing to consider....solid diff mounts will transmit WAY more noise to the shell than non-solid mounts. Before deciding that your diff needs internal work, may want to determine if it's just the solid mounts that are causing the noisy running condition. If you decide that you do want to tear into the R200, there's nothing magic about it....but you will need a dial indicator to measure backlash.
Unless you have your heart set on a solid rear end, there's actually a few options for Ford IRS rear end conversions. ZCarDepot makes a kit; there's a guy here building a kit (InvincibleExtremes), and Apex Engineering is planning to release a kit in the near future. If you're definitely set on a 4 link setup, you should check out some of the builds on FB "Swapped S30 Owners Group".
I personally have not done that but have considered something like this previously. I'm assuming that you are talking about a full dash cap, correct (vs a half cap)? Would def be interested to see your results. Incidentally, there's a guy on the S30 Facebook pages who is 3D printing adapters for anyone that needs them when switching to aftermarket gauges. I can find his name if you need it.
Chevy 350 Starter Replacement
jhm replied to Mark Kanoy's topic in Trouble Shooting / General Engine
Is that a question or a recommendation? Glad you got your issue resolved, if that's all it was. As an FYI....the SBC can come with two different size flexplates, and they typically require different starter motor mounting configurations. That may have been part of the issue with your ebay starter. -
Here you go: https://forums.hybridz.org/topic/128951-fs-z31t-axle-adapter-flanges-for-s30-r200-slim-design/ He also advertises on the FB pages under "Mark Nickel".
- 7 replies
- cv adapters
- cv axle conversion
(and 3 more)
Tagged with:
Also, Google search usually works better than the website's Search function. Be sure to include "HybridZ" in your Google search string.
77' 280z Stock volt gauge/LS alternator
jhm replied to mforget's topic in Gen III & IV Chevy V8Z Tech Board
Silly question, but do you have the FSM for your car? Voltmeter wiring can be found on page 35 of the attached. Body Electrical.pdf -
Just to be clear....are you saying that the gauge is not reading at all, and the charge light is not working either? For starters, the gauge can be connected to any hot lead (and ground) in your electrical system, and it should read just fine. You can verify this with a standalone multimeter. And then once the gauge is reading correctly, the charging bulb is pretty much irrelevant IMHO. Sorry if I'm misunderstanding the issue and didn't address your problem. -
Still available.
Just FYI....that JDM ad now reads "No intl shipping". Was that there when you first looked at that kit? (For that price tag, they should be willing to ship to the moon.)
Hello all, got what I needed.....many thanks to the generosity of 72240Z. Thanks also to the others that replied. Admins, thread can be closed or deleted if so desired.
Here is the schematic, if anyone wants it....illustrates functionality in each of the key's positions:
Much appreciated -- no rush at all!
Stock and recommended performance spring rates
jhm replied to Kclank's topic in S30 Series - 240z, 260z, 280z
IIRC, stock spring rates were in the range of 100-140 lb/in? At the risk of gross generalization, most "lowering springs" are in the range of 180-200. If you're wanting stiffer spring rates, most people go with adjustable coilovers. Hope this helps. -
The end link bushing retaining caps from Energy Suspension are flatter than the ones you're using, and may give you the additional clearance you need between the cap and the LCA.
Your question is really so open-ended, it's pretty hard to give an answer that means anything. What are you replacing the stock components with? (The gist of your question implies engine/trans swaps, etc). Also, sounds like you're planning to have a shop do all the work for you...that alone will triple or quadruple the total cost of the project. As seattlejester suggested, you can start your research by reading as many of the "build threads" that other members have posted.....that may give you an idea of the magnitude of work that's required for a full & complete build/restoration. You will also want to make some firm decisions about your goals for the car before you spend a single dollar on it.
Looking for a black plastic rear strut tower cap, as pictured. I only need one, but willing to buy both if the seller is wanting to sell as a pair. Yes, I know there are some available on eBay and new from multiple vendors; but I'd rather give my business to a fellow HybridZ'er if possible. Thanks all.
Thoughts on T3 'Rear Power Braces'?
jhm replied to artishard116's topic in Brakes, Wheels, Suspension and Chassis
Many people using an RT-style diff mount have eliminated the lower front differential crossmember....it's bulky, heavy, and often interferes with a larger exhaust system. If you are wanting to eliminate yours, but are worried about negatively impacting structural integrity (between the left and right LCA mounting points), you can fabricate your own crossbrace from suitably-sized flat bar or angel steel. Not as pretty as the T3 unit (like Jon mentioned), but $140 cheaper.
