28
Everything posted by jhm
Don't know if this will help you (not sure if you're using the stock radiator, or just the stock shroud), but I'm using a 16" Spal low-profile fan with a Chevy radiator from JTR and a custom shroud I fabbed. I've got one of Spal's programmable controllers running the system. Works great and keeps the motor (SBC) cool in all conditions. If you're running an L28, a single 16" fan should be plenty provided it's properly shrouded and the cooling system is operating properly.
If you don't ever see yourself racing much, then I'd agree that you will probably not need coilovers. I used the Tokico springs and HPs for three years (combination of street and auto-cross) and was very happy with them. They provide an excellent mix performance and comfort. There are many low-budget techniques to further improve performance, like slotting the holes in your strut towers for a tad more negative camber and using the earlier strut top insulators to lower the rear approx an inch. If you still have the stock squishy rubber bushings in your steering and suspension, poly busings are an extremely cheap way to tighten up the ride and handling. If you do decide to get more serious about racing your Z in the future, you will undoubtedly decide that you need more a more performance-oriented setup. The good news is that you don't have to spend a fortune to do it. Used coilovers, springs, shocks, sway bars, etc are always available for much less than buying new. Hope this helps -- happy motoring.
I had wheels like that many years ago; and if I recall correctly, they were American Racing.
These may help: http://thefactoryfiveforum.com/showthread.php?13240-A-spotters-guide-to-Subaru-differentials http://legacycentral.org/library/literature/differential.htm#Which Subarus do I look at to find an LSD http://forums.nasioc.com/forums/showthread.php?t=1969700
Confused here.....are you saying that you've searched for an OEM-like replacement, and can't find one? I did a quick search on several major parts retailers, and many listed in stock. Maybe I'm missing something here? http://www.autopartsexpress.com/beck-arnley-081-0218-drum-brake-shoe?cse=GoogleProductSearch&utm_source=google%2520product%2520search&utm_medium=cse&utm_campaign=Drum%2520Brake%2520Shoe&gclid=CjgKEAjw286dBRDmwbLi8KP71GQSJAAOk4sjlDL6XoplypJYmM-1_sWXqOf3EkkNu0AesGcgVbP5i_D_BwE
- 3 replies
- brake shoe
- brake lining
(and 1 more)
Tagged with:
GC spring rates for 280z w/LM7 + T56?
jhm replied to ComicArtist's topic in Brakes, Wheels, Suspension and Chassis
Yes, should be more than fine, provided you've got struts (i.e. shocks) that are compatible with your springing. I've got a late '74 with an old iron-block/iron heads SBC that I'm running with 224 lb/in front and back. And previously, I was running Tokico 5022 springs, which if I recall correctly, are 185 front and 200 rear. I daily-drive the car in the off-season, and race it pretty regularly summer and fall...mostly auto-x and closed-circuit HPDE. Good luck with it and be sure to post your results for the benefit of everyone else. -
Will these shocks/springs work on my 280?
jhm replied to Nate SERE's topic in S30 Series - 240z, 260z, 280z
If your heart is set on Tokico struts, there are a couple sets on eBay right now (for a 240). -
New? Bolt-in camber top mounts on the market
jhm replied to 1vicissitude's topic in Brakes, Wheels, Suspension and Chassis
Rob- You're saying that the inside of your tires is getting worn? If so, it could be due to too much negative camber and/or poor alignment. Check both. Is this occurring on both the front tires and back? If it turns out that you've got a lot of neg camber and that's what's causing the excessive wear, you'll want to dial in more POSITIVE camber....which is somewhat unusual, but not unheard of. Most people installing camber plates (and coilovers) are usually looking for more negative camber. Hope this helps. r/John -
You *may* be able to use those plates with stock-sized springs and perches, but you'll get no camber advantage over and above what you can achieve by slotting the three mounting holes in the strut tower. I suppose you would get some additional lowering, as well, if that's your goal. What are your objectives here? There may be other, more effective solutions. -
The same manufacturer also produces a "universal" plate for adjustable camber AND caster. I may have to procure a set, just out of curiosity, if nothing else... http://www.ebay.com/itm/NEW-MK1-Universal-Fit-Adjustable-Caster-Camber-Plates-Datsun-280Z-/161148545667?pt=Motors_Car_Truck_Parts_Accessories&hash=item258533aa83&vxp=mtr -
Auction ended with 0 bids....not surprising.
Intriguing-looking product. I wonder if they work with stock-sized springs and top spring hat....the language in the eBay ad indicates that they are only compatible with coilover kits, but the pictures imply that they're a 1-for-1 replacement with the stock strut insulator. -
Came across this info while researching LSD options....great info with lots of pics...enjoy! (My apologies if this is a repost.) http://thefactoryfiveforum.com/showthread.php?13240-A-spotters-guide-to-Subaru-differentials
What wires do I connect an aftermarket gauge to in a 280Z?
jhm replied to dpuma8's topic in Ignition and Electrical
This should help...free FSMs for all years S30. http://www.xenons30.com/reference.html -
Not sure if I understand your question correctly, but an electric choke is typically grounded to itself (somewhere on the carb body) and the hot lead is connected to a switched circuit. My current Holley (4150) with electric choke works fine for me, but I have had electric chokes in the past that I couldn't get to work correctly and I eventually installed a manual system.
Radiator ducting and grill opening blocking
jhm replied to RebekahsZ's topic in Windtunnel Test Results and Analysis
Possibly this thread? http://forums.hybridz.org/topic/56254-after-doing-some-reading-i-blocked-off-the-upper-grill-pics/ -
Unusual Rear Sway Bar Mount
jhm replied to Phantom's topic in Brakes, Wheels, Suspension and Chassis
Good advice, as always, from JohnC....he's the Master! If you are experiencing any interference between the sway bar and the LCA, driveshaft(s), or lower subframe; and don't want to switch to a rear-mounted bar; you can play with adjusting the length of the sway bar end-links to give more clearance where needed. Typically, if you have stock ride height (or even if it's lowered an inch or two), it generally won't be an issue. -
Phantom- Nothing wrong with that bar or mounting config. As said by the others, that's the stock mounting point. I used a set-up like that for a couple years (racing) and had no problems. You can also replace it with a thicker aftermarket bar as well, if the stock bar is too soft. The only time you're going to run into issues with that mounting is when the car is lowered sufficiently so as to cause interference between the bar and your lower control arms....that's when it's time to switch to a rear-mounted sway bar. Until then, you're fine. -
Have that exact same light in my car! http://forums.hybridz.org/topic/83021-aircraft-style-interior-dome-lamp/
Sounds like the master cylinder and/or slaves may need rebuild? Did you replace the seals on the MC when you cleaned it?
In addition to HybridZ, there are some great forums out there for small block chevy owners. I often use these two... http://forum.grumpysperformance.com/ http://www.nastyz28.com/forum/index.php ....but there are plenty others.
No....none that I remember (but it has been a while, to be completely honest). Most of these vendors are pretty good about posting specs, or answering questions via their tech support.
I'm sure there's plenty of vendors out there, but I've ordered wheel adapters from "EZ Accessories" and "TC Sportline"....both offered good prices, quick shipping and decent customer service. No problems at all with fitment.
