jonbill
Everything posted by jonbill
  1. its an f54 bored to 88.5, standard l28 crank balanced with the flywheel and clutch, maxpeedingrods l28 rods, Kameari forged pistons. welded p90 head, standard valves, 0.585"/308° cam, Kameari twin idler tensioner, kameari crank damper, zstory exhaust, fajs ITBs, Speeduino EFI. thats probably about it.
  2. my £8k motor doesn't go to 9k. 8.7k turned out to be the limit. I reckon titanium valves and retainers would get it there.
  3. I recall there was a thread on classiczcars.com that might be worth looking up. Also there's zclocks.com if you want someone else to fix it.
  4. It's a great head. but the original chamber size is 53cc, so on an L24 you've got to weld a lot or skim a lot to get a decent CR.
  5. P90A is quite common in the UK and all have solid lifters.
  6. I kept the diesel intake too, it does look interesting (but it's not going on this engine!) I think the diesel may be a bit more common here; the gen 3 Patrol had it for quite a few years I think and sold in good numbers. (although wikipedia doesn't mention it). my blocks are v57 which seem thicker and reinforced compared to the v07 you got. my guess is that it has similar bore material as f54 petrol block, so probably safe to 88 or so.
  7. I have the block back. 2 & 6 went through and have liners. you can see the liner sealant through one of the core plug holes. next job is to open up water holes on the oil filter side of the block.
  8. Yeah I did email them but no reply. I don't blame them; nothing in it for them. I should hear tomorrow how the liners worked out.
  9. Its a bit of a voyage of discovery. The firm doing the boring and liners seem confident the liners will be held ok top and bottom, and they do a lot of them although not on this engine obvs. but I'll only really know if it works when I've run it.
  10. Update on this. 4 cylinders on the v57 block have been bored to 89.5 and are serviceable. front two got too thin and are being linered. The crank has been lightened to 17 kg and offset ground to 84.25 stroke and ia going for balancing with an XTD RB25 flywheel and clutch. Kameari 89.5 pistons coming next week, so its all moving along.
  11. schneidercams.com spring retainers are deeper. http://schneidercams.com/7steelretainer-73004.aspx you might need to check they fit your springs.
  12. first up, you need to get the physical size right- distance between the o rings and diameter of the o rings. if like my Fajs ITBs it'll be 61mm and 14mm. then you have to get the electrical connector right - if your efi comes with a harness, it'll already have connectors, probably uscar or jetronic. then you want to pick the right flow rate. 330cc will get you to around 50bhp/cylinder. I have Bosch 0280156095 which were on european ford focus st170 10/15 years ago and so are quite cheap.
  13. it seems odd to me that it runs fine above 1300 rpm. if something is broken, i cant imagine how it becomes unbroken with a few more RPM. are you sure you haven't got an ecu feature set that turns on or off at 1300, and isn't set right? ego control, idle ignition control, map switching etc?
  14. if its idling at 2000, your first problem is too much air, not too much fuel.
  15. why not leave the ECU running the distributor?
  16. the right looks like it's got positive camber and the left looks like it's got a little negative, suggests something is bent. (assuming standard suspension gear). this thread may have some help. https://zclub.net/community/index.php?threads/rear-wheel-toe-in-on-one-side.23571/
  17. My two major sources of vibration/shaking were tyre wear patterns and worn front wheel bearings.
  18. Hi, I've been doing a load of searching, and there are probably about 1/2 dozen threads about building an engine on the LD28 block and crank and have got a lot of info from them. I'm just embarking on building the engine. Aim is to use the 83mm crank and get the bore out to around 90mm with sleeves, which I think will get to about 3.1 liter. I'm looking to get some feedback on my plan, and possible answers to questions as I go along, or just bored silence So - V57 block (rear sump), V07 crank and I've acquired 6 Isuzu 4ZE1 rods from Maxpeedingrods. They're 150mm long, 26.8 mm wide with 21mm little end and 52mm big end. I'll be using my existing modified P90 head - chamber size is currently 39cc. Questions: 1) by my calc, I'm looking for a piston with compression height around 35 to 36. does that sound about right? Kameari have 35.5 CH forged pistons up to 89.5mm bore - anyone know any others? 2) with a 1mm undersize rod journal, can the crank be offset ground that 1mm and get me 84mm stroke? or doesn't it work like that? 3) Do I need to open up the water holes on the right side of the block to match the head water holes, or plug the head holes? I'm assuming the former, but read a thread maybe suggested the latter. 4) The block doesn't have the water bypass to the pump hole, and it can't be made. I'm assuming this isn't a problem and I don't need to do anything to blank the head here. correct? 5) The replacement liners will need to be brazed in one way or another. Anyone got any details of what does and doesn't work here? 6) I'm planning to use the LD timing cover (modified to get rid of the mounting for the diesel pump). All the threads I read, people used the L20B timing cover - Is the only concern here the distributor? I'm running a distributor-less setup. I don't think L20B timing covers are so plentiful here in the UK. 7) I don't like the idea of drilling my nice P90 head for M12 bolts, I'd like to keep it usable for my F54 block if possible, so I'd like to helicoil the block to M10 and just get longer M10 head bolts. Anything wrong with this plan? That's all I've got for now - all feedback welcome.
  19. I don't think I had to use any power tools I do vaguely recall it took me a little while to figure it out, but it was a couple of years ago now! Maybe there was a lock screw somewhere...
  20. Yes, I have the B&M shifter (I think it was B&M anyway!) The coupler thing came off on mine.
  21. The rubber seal on the body where the gear stick comes through? I just rotated mine 180 degrees and made new screw holes.
  22. jonbill
    Speeduino
    I saw on the Speeduino forum that you have the HEI working. Sorry I can't answer your question about the zxt CAS, although I suspect the info is here on hybridz.org somewhere.
  23. jonbill
    Speeduino
    I dunno what an accel 300 is so can't help, but I bet someone on the speeduino forum would know.
