1971 240z ITB install
DuffyMahoney
  • 3 weeks later...
Next hurdle is a hidden vacuum log for my ITB. My plans for a billet clamp won’t work with the stock hardware. But a simple cushion clamp should do the trick. Next is welding 3x 1/4 hose barbs onto my 5/8 OD aluminum pipe. It’s been threaded to -6 orb on each end. With the plan to use iac at some point.
  • 3 weeks later...
  • 3 weeks later...
Final touches on this new R35 coil bracket design. Next is laser cutting for final test fitment. Joseph Monti did a great job with this design, the boot angle was all his idea.  Previously the coil boots had a huge curve in them, which we both hated, this splits the difference (22.5 degrees).  I also disliked the coil head angle I had originally decided on.  This new coil head angle keeps the wiring nice and secured.
Looking good!  I have your original one, might have sell it and get this one :).  There is more to it than laser cutting, right? The shape appears like it would have to be milled or casted.  When do you expect to start selling them?
