madkaw
    27
Everything posted by madkaw
  1. Well since my engine is in the black hole of the machine shop, I thought I would bang out some frustration on my intake plenum. Made some progress, but I think I need to get serious about measuring volume to see where I am at. It seems big and I'm not sure how to math this out with the taper. Any suggestions on some equations or methods of measuring volume on this type shape.
  2. Thanks for showing the process and progress- I am getting educated!
  3. TUNE -TUNE -TUNE I would think the ignition would make a huge difference and also effect the richness issue. Dial her in and go back to the dyno!
  4. I didn't mean 12.9 was lean, but the dyno measure of 13.9 is another story. As far as timing, my l24 showed no significant gain from 33 total and 37 total. With an efficient chamber like the MN47 you might not need much more timing, but get all you can! Didn't the mn47 have the smaller intake valve too? Did you just install cam straight up or did you verify numbers with degree wheel?
  5. Total timing is more important than the fact that you upped your CR. Your 12.9 AFR would not be rich enough to induce backfire so maybe you ARE running a bit lean up top. Might have some tuning to do yet to yeild best results .
  6. How aggressive is your timing with that CR? Did you do any tuning while on the dyno? Were your O2 reading good?
  7. I've always wanted to watch the process. My FG guy is chomping at the bit to do a project for me since he is starting a business and I would like to be involved to watch the process. I was going to have him do the console, but you might have that covered. Once you are to a point to discuss options I would like to see if you would make me one.
  8. So you made a stock replacement but will be able to modify the mold for other options easliy? Sorry for the dumb question but I don't how the molds are modified and how hard it is to make changes.
  9. Where's the freakin cup holder
  10. I hope I have better luck with Schneider than you did. Congrats
  11. As far as the cup holder, I was looking for a more refined look with the cup holder molded into the console. Something permanent that looks like it is supposed to be there. I also pondered making the access panel for the fuse box into a mini gauge pod. Need to examine the amount of room available, but having a removable panel would make mounting and accessing gauges easier.
  12. Yes - the hole needs to move north an inch at least for the T-5. I thought the hole in the chassis under the ashtray would allow to drop the cup holder in there- maybe not. Got to keep it low! Any kind of access panel for the fuse box would work. Be nice to think about a 12 volt receptacle( cig lighter) integrated on the passenger side for charging cell phone! Just some thoughts
  13. Well I needed to move the shifter hole more than anything. As far as the ashtray hole, I was going to see how far I could sink a cup holder into there. 12 oz can diameter would cover most cups and the lower the better for the shifter.
  14. Found an old thread of yours-- sounds like I can't give you any advice:) Good luck and hope it's not a sucky Schneider cam since they are regrinding mine now.
  15. Did you verify damper was dead nuts TDC? I understand the PITA to mount wheel but using the crank pulley is probably not accurate . Do you have a build thread?
  16. I wouldn't be suprised to hear a suggestion for a gauge provision in the console also. I thought the console would be as desired as the clamshell as far as updating for hybridzers. The clamshell is definetly needed and noted.
  17. Couldn't be an ignition issue? Did all other events match cam card-especially intake close?
  18. I was reading your engine link-what's the latest since 2013?
  19. So I was wanting to do a fiberglass/CF dash for my Z, but think I want to start off a little smaller with the FG guy. I think he's up to the dash, but I think a custom console is needed more for me right now and it's a good way to test the waters. My car has the t-5 which doesn't fit any console correctly as far as the shifter hole. And my car doesn't need any of the other cut-outs for choke lever, choke light, ashtray,etc... What I want is a console that deletes EVERYTHING! I want the same basic shape as the original and of course to fit like original. I would like to have a console that someone can put whatever cutouts they want WHERE EVER they want. All I need is a door or somekind of access for the fuse box and a way to secure the shifter boot for where i decide to put the shifter hole.....and I think a molded cup holder! Once a mold is made then it could be made CF or just FG. any thoughts , suggestions, gripes, insight,ect..........................
  20. Please post your build too! 54 flat top?
  21. Very nice. I noticed you still run a strap over the diff?
  22. I can't tell you present ring gaps because all parts are at the machinist. The machinist said I was concerned over nothing after a cursory look. With the block and pistons in hand he will mic everything out. He thought a hone and new rings would make things all better. I argued the markings traveled the length of the bore as if done by a machine, not rings. Maybe I didn't or couldn't see these marks with a cross hatch hone over top of them before? The shop did all the assembly work last time, but this time I will be doing the assembly. These were probably ITM pistons and rings, but can't swear to that either. We did go with SI valves and guides for the head. Still no word from Schneider on the cam. It gets a little old dealing with the lack of customer service anymore. I'll see how this motor goes second time around , I might be shipping to Rebello for the 2.8!
  23. I loved my little 2.4-maybe she will live again! I take the motor by to the builder tomorrow for his analysis on this -it ought to be interesting. I get the feeling he thinks I beat on that motor, but I really didn't. I drove it hard at times, but not abusive.
