woldson
Everything posted by woldson
  1. Me thinks that connection needs to be allowed to move.
  2. Thankyou very much guys!!! Not really my brithday, me no likey internet infomation. Nothing with you all, just, well you know... The only pic of me is put up by, crap, what is his name, helped me pull that turbo engine..... Man getting old. Anyhow, thoughts that count, Priceless!!! I'm around 37, b-day is in winter:). Was head engineer in a cable company, prior to that Sonar tech on a trident sub, if that background helps;)
  3. Borrow one like I do. Dam things get in the way, They always tell me keep it for a while if you want........ Ummmm nooo, its in the way, lots of laughs.
  4. If the volumetric efficacy is the same on any given engine and you are producing 80hp per cylinder, then it makes sense that: 1= 80hp 2=160hp 3=240hp and so on. The differences are of course are rotating mass and friction from more surfaces. This dose not change the potential from any given amount of cyls., and the losses will not equal or out perform the gains from more clys. If I'm off base, I know I will hear about it;)
  5. How about just a K&N filter on the valve cover (for intake) and run the crankcase into the exhaust at an angle to help pull air threw the engine?
  6. Search edis, I'm only saying this because if I answer that question you will go DOOHHH! So this way you can do this in the privicy of your own home!
  7. Was the hammer recently calibrated?
  8. It's the Internet.,,,,,,,,,, It won't really credible. Besides this site is an equal opportunity offender
  9. Work on the mechanical stuff before interior and or exterior stuff, i.e. paint. Really though you should do some reading here to get a better understanding of what you want. This way, since your female, I suppose, you won't get a billion ideas thrown at you. Then you can ask more direct questions pertaining to what you want.
  10. This is why woman should not be in combat!! There will be 1600 dead men around on chick. More depending on hotness.
  11. That was pretty smart of you, however, gas will eat radiator hoses! Don't ask me how I know.
  12. Oh boy, ummmmm.,,,,, boy,,,, Get an electrician to look at this for ya. There is a lot involved in doing what you are up to. Even though we use electricity every day, it is grossly underestimated in how dangerous it is.
  13. Go to a parts yard, get a five speed,,, Remove auto, install manual!
  14. Pragmatist (me) Did you fill it halfway, or, just empty half of it?
  15. I hope she makes a full recovery, the dirt bag gets his, severed up cold by the justice system. AND I hope she learned a valuable lesson, STAY away from situations that are most likely to cause great harm. Me don't go to bars anymore, stopped 10yrs ago. (I miss playing pool)
  16. Prayers sent, sigh, no words except, sorry man.
  17. Work on drivetrain and or suspention frist. No point in damaging a beautifully restored car.
  18. Yes, but, freely. Not nearly the amount of force being applied to the rod/cap. As time passes and the problem get worse, if it is rod knock, you will hear it under all conditions. (even starting) By then your very done and need to be fliped.
  19. One thing that I've found in life, the more info I gain the more I will over think the problem. I always check the obvious "on purpose" to avoid having to smack my head later.
  20. Slipped chain would be consistent. Probably not. Ignition moduel, or wiring short is my 2ct.
